Old 08-04-2008, 01:31 PM   #1
idaw8184
idaw8184 is on a distinguished road
1996 SL1
Default Replacing composite/polymer valve cover with aluminum cover DOHC
I have a question. I currently have a warped composite valve cover on my 1996 SC2 1.9 DOHC and am replacing it with an aluminum cover. My problem is that the new cover has 4 bolt holes in the middle of the cover and my current application on the vehicle has 3 bolt holes. All other bolt holes match up on the cover. Is it possible to plug the "empty" bolt hole or will it not be a problem? Oh, and is the torque setting still 89 inch-lbs with the aluminum cover? Should I use a preformed gasket with some rtv or just rtv?
idaw8184 is offline   Reply With Quote
MJO's guide to replacing valve cover gasket on Aluminum valve covers for S-series mjo How-To Library 2 04-26-2011 01:56 PM
Composite Valve Cover 1.9L question BobbyP S-Series General 3 01-15-2007 08:44 PM
3 or 4 bolts near spark plug holes on DOHC aluminum valve cover David 93 SL2m S-Series General 2 04-01-2006 06:44 PM
FS: DOHC Valve Cover -Composite TedL Classifieds 1 11-24-2003 09:48 PM
