Old 01-29-2008, 09:53 PM   #1
Jeffsimpson
Jeffsimpson is on a distinguished road
Default 1998 Fuel Filter - (Fuel line retainers)
Ok... 98 SL2 with 118k on it, figure it's time to change the fuel filter. The FRAM replacement filter I bought didn't come with a bracket, nor the new fuel line retainers.
The bracket I think I'm OK with, I just want to make sure that it's OK to reuse the old fuel line retainers?
If so, is there a trick to getting them off the old filter, and onto the new one?
Thanks!
Jeffsimpson is offline   Reply With Quote
Old 01-29-2008, 10:01 PM   #2
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Default Re: 1998 Fuel Filter - (Fuel line retainers)
See if this helps
http://youtube.com/watch?v=0FqLKzINM6s
yazhere is offline   Reply With Quote
Old 01-30-2008, 06:36 AM   #3
BarnOwl
BarnOwl's Avatar
You can and should reuse them. Look at how they are held on. There a tab on the inside of the connecter that snaps on the ring on the filter. Just spread it a little to get it over the ring.
Old 01-30-2008, 09:42 PM   #4
Welcome to the Board.
Leave the bracker bolted to the car and ease the filter out of it. The hold down bolts rust n place and break whne you try to remove them.
The clips can be reused if not damaged. They are released from from the line by squeezing together the two tabs that you see that are out of the line towards the filter.
Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) WadeNKC S-Series Tech 9 01-07-2010 06:42 PM
3.0L L81 Fuel Filter Quick Connect "RETAINERS"? rayzur9 Vue Tech 2 06-02-2009 03:49 PM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 10:43 PM
1998 SC1 Fuel Filter ayoung002 S-Series Tech 7 12-11-2006 12:41 PM
Fuel Filter for a 2000 SW2 same as a 1998? badtzbuzz S-Series Tech 5 03-10-2005 03:26 AM
