Old 02-23-2020, 09:47 PM   #1
rsg3
rsg3 is on a distinguished road
1999 SL
Default License plate screws
Which should I use? Add washers? Frames? Metal or plastic screws? I had to drill out the screws on my wife's Camry plates which was awful.
So after that, I put nickel anti-seize on every screw of the plates for all my cars... but now the screws holding it keep backing out.
Just not sure if I need different screws or different mounting. Totally stock '99 SL, 116k.
I've personally replaced the starter and water pump... so generally tech. capable, and am an engineer, just not sure what the wisdom is on this one. Thought they were generally universal?
rsg3 is offline   Reply With Quote
Old 02-23-2020, 11:00 PM   #2
Default Re: License plate screws
Backing out? Just remove the screw and add in a lockwasher under the screw head & retighten it.
OR switch to plastic nut inserts and plastic screws work well in all weather for a long time, and no rusting of course, inexpensive and don't require lubricant.
Old 02-27-2020, 12:26 AM   #3
TomM96
I had to drill out license plate bolts once...
My preference that application, is steel screws into plastic receivers.
90% of steel/steel or steel/aluminum ... i seat in Locktite if want security;
OR i seat in RTV silicone when torque not essential: the silicone will not back out
and it will exclude moisture from the joint. It is perfect for wheel mounting studs/bolts, and particularly useful for trailer wheels, as it prevents water incursion to the threads.
Old 03-06-2020, 06:28 AM   #4
macbox
macbox will become famous soon enough
macbox's Avatar
1997 SC2
On my 95 SC2, I used a Menards nylon machine screw, part number 201-7787, 1/4-20x1. These work perfectly and won’t rust. I think I also used a small dab of silicone grease on them.
A lot of the other fasteners I found were 6mm x 1.25 thread x 20mm and were the wrong size.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
macbox is offline   Reply With Quote
Old 03-06-2020, 10:09 PM   #5
Zeebins
Zeebins's Avatar
I recently got some M6X1.0 bolts (I forget the length) to replace the old corroded looking ones. The two bottoms bolts are also M6x1.0, but just long enough to reach a nut on the other side to hold the frame and plate together. It helps a lot with the rattling when closing the trunk.
97 SL2, auto, 118K miles
Zeebins is online now   Reply With Quote
Can't remove license light screws termite Vue General 6 09-01-2011 09:52 PM
2004 Saturn Vue license plate screws NewVue2 Vue General 1 09-03-2010 10:10 AM
license plate light cover screws drbob07redline Vue Red Line 1 11-21-2009 08:49 AM
valve body plate, what screws should stay in mehalski S-Series Tech 2 08-08-2007 04:43 PM
Rear License plate light screws robert_vue Vue General 13 01-06-2005 08:07 PM
