Old 12-02-2019, 08:58 PM   #1
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
Default Wet & Melting Steering Wheel
So I've noticed it for years, but I thought I'd ask...
Is anyone else's steering wheel melting? It gets really sticky in the hot weather - to a melting point with black residue on my hands. In the wet weather, it also absorbs moisture and gets sticky - again with black residue on my hands. To get around it, I hold it with napkins, which creates a nice paper seal after peeling them away in both instances.
I'm sure there's a better solution. I'm not a fan of the old steering wheel covers as they're too big for my small hands. I've thought about some sort of sealer, but wonder what I should use.
Thoughts?
blueknigh7 is offline   Reply With Quote
Old 12-02-2019, 09:09 PM   #2
focusofheart
Default Re: Wet & Melting Steering Wheel
Thoughts?
leather or vinyl?
Saturn 1998 - SL2 automatic
Old 12-02-2019, 09:22 PM   #3
Google steering wheels decomposing for some background info. There's a good chance plastic used in mass produced steering wheels decompose from the combined effects of human oils, ultraviolet exposure and chemicals in the air. Chemicals can come from local manufacturing facilities to have a local effect. Once started, plastic deteriorating may not be reversible, halting what you're experiencing. The easiest remedy is replacing the steering wheel. The most difficult remedy may be attempting to repair, seal or restore it back to factory condition.
Old 12-03-2019, 04:28 AM   #4
focusofheart
If doing a deep clean on your steering wheel with either a degreaser or saddle soap does nothing and you are unable to replace the steering wheel, you might just grab an old style steering wheel cover that was popular about 40 years ago - no sewing, just wrapping the cover on. I used these on several of my cars over the years and felt little difference in the circumference (I also have small hands).
https://www.amazon.com/C-P-R-Classic...5NT9EF1GKZM5DW
If nothing else, it is an inexpensive stop gap until you are able to replace the wheel itself.
Old 12-03-2019, 09:17 AM   #5
trottida
trottida's Avatar
If this is the 97 SC2 in the OP's profile it should have a perforated leather steering wheel.
You can either change your steering wheel to another leather one in good shape or downgrade to the standard plastic steering wheel. You can take one from any sedan, wagon or coupe from model years 95 through 99. I wouldn't think it would cost you that much from a wrecker.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 12-03-2019, 11:59 PM   #6
Wheels are dirt cheap at JYs. Some types of automotive leather wheel decompose this way when the incorrect cleaner is used or the car is driven with a person who for some reason always has automotive grease or oil on their hands.
Old 12-04-2019, 07:38 PM   #7
Bruce Rock
Bruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the rough
2000 SL2
2006 VUE 2.2L
Save the old wheel to use as a fire starter. When I changed out the wheel on my 2000 sl to add cruise, I threw the old one in a fire to remove the outer covering. The white light emitted was equal to arc welding.
Bruce Rock is offline   Reply With Quote
Old 12-04-2019, 09:06 PM   #8
nealt
nealt is on a distinguished road
nealt's Avatar
1997 SC2
1999 SC2
My 97 SC2 was doing the same thing... getting sticky and disintegrating. The more I cleaned it, the worse it got.
What has worked for me is Meguiar's Gold Class Rich Leather Cleaner & Conditioner. It helped stop the disintegration, and also made the steering wheel less sticky, especially between the 10:00 and 2:00 clock positions. I put it on liberally every 6 months and also try not to get the steering wheel wet with sweaty hands.
nealt is offline   Reply With Quote
Something in the steering snapped, steering wheel turns around and around, tires wont BullyCanadian Vue Tech 23 02-11-2020 01:57 PM
Exchanging 2004 steering wheel for 2007 steering wheel Northerner Vue General 0 12-16-2017 09:32 PM
Replacing steering wheel - how do I make sure coil behind steering wheel is ok? vikasevan S-Series Tech 2 12-29-2014 01:32 PM
leather steering wheel question/steering wheel comment 2006 ion2 Ion General 4 04-29-2010 07:27 PM
2003 Vue Steering Wheel Tunk Noise When Turning Wheel kencat Vue General 6 03-05-2010 07:06 PM
