Old 06-17-2018, 10:59 PM   #1
Walkop
Walkop is on a distinguished road
Walkop's Avatar
Default Looking at buying a 2004-2005 V6 Vue, what should I look for...?
Hey all!
Current Saturn owner in Ontario, Canada crossing over from the S-Series tech forums. Looking to purchase a V6 Vue for towing a utility trailer for landscaping/lawn care equipment. Total load likely will rarely exceed 2000lbs.
What should I be looking for? I have a potential buy in a 2005 Vue Redline (auto trans) with 216,000kM (134,000 miles) for $2500 CAD. There's also another 2004 V6 (but no info currently, need to talk to the owner).
I'm definitely interested in the Redline, but know little about Saturn Vues. I've nearly rebuilt my SL2, done almost everything save for the engine and trans, but no experience on post S-series vehicles. Honda engine, what trans is worrisome...? What should I look for in a test-drive...?
Thanks!
Walkop
Walkop is offline   Reply With Quote
Old 06-17-2018, 11:58 PM   #2
RobertGary1
1996 SC2
Default Re: Looking at buying a 2004-2005 V6 Vue, what should I look for...?
I thought the redline didnít allow towing because the rear bumper is too low( unles you cut it)
-Robert
Old 06-18-2018, 07:37 AM   #3
Walkop
Walkop's Avatar
I wasn't aware of any of that... I just did some research. I'm still interested in buying it, it looks like you just need to modify the real facia. Not even the bumper.
The only thing I'm really concerned about is the legality of it. Would it be legal to tow a trailer commercially if it's technically not supported by the company? The Vue itself is designed to tow 3500lbs...but Saturn mentions many times "don't tow with the Redline Vue, you'll damage your vehicle".
I'm in Canada, but I doubt the laws are much different.
Old 06-18-2018, 07:47 AM   #4
VUEmaniac
1997 SC2
I wouldn't be overly concerned about towing if you're willing to cut that small slot. Make sure you periodically dump and re-fill the transmission with fresh fluid. On a FWD VUE, that's usually the weak link in the drive train. On a AWD VUE, it's the RDM unit in the rear (with bearing failures between the two halves of the drive shaft to the rear being a close contender).
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Old 06-18-2018, 08:40 AM   #5
atikovi
You do have to trim the bumper cover but pretty minor.
I don't know the Canadian RL market but $2500 CAD seems pretty cheap. I'd be really concerned with subframe and undercarriage rust at that price. Also, you could spend another $3-$4K on needed maintenance or repairs which is why its being sold so cheap. Timing belt, water pump, valve adjustment, spark plugs, struts, wheel bearings, control arms, tires, brakes etc. add up. You would be much better off importing a rustfree southern car that has been gone through. Umm, I could could help you out in that regard as I'm selling my silver '04 but it's a bit more than $2,500. https://sites.google.com/site/atikov...ue-redline-awd
Old 06-18-2018, 08:58 AM   #6
Walkop
Walkop's Avatar
Thanks for the info!
I also have another option that came up that I'm quite interested in. A 2004 Vue, one driver, older woman, with all maintenance records. 191,000KM, or ~119,000 miles. Leather interior. V6, Honda engine.
Is the transmission only worrisome on the inline 4 models?
VUEManiac, RDM? I'm not too familiar with AWD transmissions, I've never done work on a vehicle with one. Mainly FWD.
Also, atikovi, not necessarily interested but if I had the budget for that Vue I'd be snatching it up in no time. That thing is gorgeous. It's exactly what I'd want to do to my own Vue, right down to the Meguire's. I'm a hobby detailer. Awesome work!
Old 06-18-2018, 12:12 PM   #7
VUEmaniac
1997 SC2
RDM is the rear wheel drive module that drives the rear wheels when slippage is detected with the front wheels. They are pretty fragile and expensive to replace.
Best,
Old 06-18-2018, 08:25 PM   #8
Walkop
Walkop's Avatar
Just thought I'd chime in with an update. I'm pretty much locked into a 2004 V6 FWD Vue, Black. 190,000KM (~118,500 miles). All service records included. Regular oil changes, garaged overnight inside for the winters, new tires, brakes engine and trans all work great - no noticeable issues in a test drive. Some suspension parts may need replacing, but it runs really well. Minimal underbody rust. Just got a new starter and wheel bearing replaced. $1200 CAD ($908USD).
Cons:
  • Passenger mirror glass is detached from the mirror. It's on, but loose.
  • ABS and TCS lights are on.
  • AC only works on 1 or 2. Instantly disables on 3 or 4.
  • Muffler has a rust spot, one layer is rusted through about 2" in diameter. Inner layer is intact.
I'll be on here more often going forward! I do all my work DIY, so Saturnfans is the only real place to be. Glad to join the Vue clan!
Old 06-19-2018, 12:00 PM   #9
rg3
rg3 is on a distinguished road
I have an 04 v6 awd, black too. Timing belt should be done every 100k miles so do that if it hasn't been done already along with the water pump and new coolant. The blower only working on low speeds sound like a resistor problem.
rg3 is offline   Reply With Quote
Old 06-20-2018, 08:40 AM   #10
underthehood
underthehood's Avatar
If it was a resistor it would only work on high.
Old 06-23-2018, 12:07 AM   #11
Walkop
Walkop's Avatar
Just another update. Looks like that deal with the Vue fell through - after agreeing to the sale, the owner texted me saying they decided to sell to someone who messaged them before I did initially.
I contacted another seller nearby. The Vue is a 2005, FWD. It has 211,000KM (132,500 miles), $1250 CAD (~$950 USD). No lights on. Haven't gone out to test as of yet. No info on service records. Not sure if there are any. Woman driver. She said the tires need replacing. Also an inner tie rod. I ask how she knew, and she said her mechanic replaced the outer tie rod and then told her that the inner was shot. I asked which side, and she said she thinks it was both. I already purchased another set of tires on Vue alloy rims, so that isn't a concern.
Any red flags or specific things I should look out for? Should I be concerned about the steering rack at these miles...?
Thanks in advance.
Old 06-23-2018, 08:25 PM   #12
VUEmaniac
1997 SC2
Thanks in advance.
Replacing the inner tie rods isn't a big deal if that's all that's wrong with it. If you buy it, immediately do the timing belt, spark plugs, and have the valve lash checked and adjusted (if necessary). I'd also change ALL of the fluids.
Best,
Old 06-24-2018, 02:19 PM   #13
far2grumpy
far2grumpy's Avatar
The resistor card can cause many strange problems ... the attached SB applies to 02-07 Vue's.
BTW ... the SB explanation is prepared for dealer techs but if you have problems with compressor not engaging at any blower setting replace the blower speed card.
They are commonly available and I paid around $35 for last one I needed.
Old 06-28-2018, 10:43 PM   #14
Walkop
Walkop's Avatar
Another one to add to the Vue saga. Meeting a seller this weekend. Here is the link to the Kijiji ad.
Low KMs (149,000), $2000 CAD, AWD (with a brand new driveshaft), looks like two owners, Blue, no lights on, only the "Low Coolant" lamp. He sent me the VIN number and everything seems to check out. It passed emissions every time in its history. Again, any thoughts on this one?
Old 07-26-2018, 11:23 AM   #15
kevo420
kevo420 is on a distinguished road
kevo420's Avatar
2000 SC2
Just for your info, I'm in Ontario as well.
I have an 05 Vue V6 FWD. I'm just over 352000 km (i bought it with 156000 km) which have mostly been problem free. I'm barely on the boards because i seldom have problems lol.
Change your fluids and keep it maintained. My engine is still strong. Cosmetically it's starting to show its age (worn drivers seat, bit of hood rust, etc...)
You'll go through wheel bearings though, that's usually why the ABS light is on.
kevo420 is offline   Reply With Quote
Old 08-12-2018, 11:44 AM   #16
Sky King
Sky King is on a distinguished road
Sky King's Avatar
1999 SC2
Ok folks, I've been absent from the boards for several years. We always owned "S" cars. 3 SL-2s and 2 SC-2s. My last one was a SC-2 that was totaled by a 8 point buck.
In any case, my wife is looking at a VUE. Based on the VIN it appears to be a 2005 with a 3.5 engine apparently produced by Honda (J35A3 L66) with transmission code "A". I have not been able to determine what the "A" stands for. I don't know the mileage as my wife is out of town and saw this vehicle and I only know what she has told me.
Can anybody please advise what to look for on this VUE? She has always been interested in them since Saturn brought them out.
Thanks in advance for any input
1999 SC-2 280,000 miles -mine now also dead, RIP
1995 SL-2 296,000 miles - my wifes totaled, RIP
1993 Chevrolet S-10 Pick-up - mine
2003 Harley Davidson Low Rider - mine
Sky King is offline   Reply With Quote
Old 08-12-2018, 11:49 AM   #17
atikovi
Timing belt replacement every 100,000 miles so find out if it was done in the last 50,000 or spend $700-$800 to have it done after purchase.
Interested in Buying 2005 Ion 2 near me Pollolapse Ion General 1 02-26-2015 12:56 AM
Considering buying 2005 Relay stemann Relay General 10 03-22-2012 03:41 PM
Looking at buying a 2005 ION 2, anything I should know? Nightwalker Ion General 18 11-25-2009 03:23 PM
buying advice - 2005 Vue Redline rabbit Vue General 2 07-17-2009 08:00 PM
Buying 2004 VUE V6 FWD Bondavi Vue General 4 12-28-2003 05:26 PM
