Old 12-16-2016, 11:17 AM   #1
Smokey
Smokey will become famous soon enough
Default Hard Starting Question
1996 SL2 with 140,000 miles. The car will start but I have to press the accelerator to get it going. Normally I just turn the key and it would fire right up. I have kept up with all of the routine maintenance (Iím the original owner). Not sure where to start in trying to diagnose the problem.
Smokey is offline   Reply With Quote
Old 12-16-2016, 11:24 AM   #2
underthehood
underthehood's Avatar
Default Re: Hard Starting Question
If you have not replaced the ECTS sensor this would be a great starting point. It's a very common issue had pretty much same issue on the 96 SL2 I owned. The new sensor is brass so problem solved
Old 12-16-2016, 12:23 PM   #3
Smokey
Thank you underthehood. I forgot all about that particular part. I'm also due for a spark plug change as well so between the two hopefully it will solve the issue.
Old 12-16-2016, 01:47 PM   #4
Macgyver
If those don't seem to help - I suspect low fuel pressure issues. You can check fuel pressure below the throttle body. Fuel pressure should be 30-35 PSI at idle.
Old 12-17-2016, 05:51 PM   #5
marko16
marko16 has a spectacular aura aboutmarko16 has a spectacular aura aboutmarko16 has a spectacular aura about
Clean up the posts at your igniton. The cold and old plugs and wires can cause one or more of those to really corrode as well as cylinder specific conditions. The extra electrical cold load and wasted spark can cause corrosion and should be checked.
marko16 is offline   Reply With Quote
Hard starting midwest S-Series General 2 06-27-2009 12:54 PM
Hard Starting SL jdsdls S-Series Tech 0 06-24-2009 11:53 AM
Hard Starting richamer1 S-Series Tech 1 12-22-2007 01:57 PM
Hard Starting lukecp S-Series Tech 7 08-02-2005 09:26 AM
Hard starting 97' SL2 rudy S-Series Tech 7 03-13-2005 08:44 PM
