Old 10-30-2016, 09:42 AM   #1
westwind999
westwind999 will become famous soon enough
1999 SW1
Default Quick question about gas tank removal
Of course I just filled the tank and now need to remove it. What's the best/easiest way to get the gas out without dumping it all over the ground?
99SL2
westwind999 is offline   Reply With Quote
Old 10-30-2016, 10:13 AM   #2
Default Re: Quick question about gas tank removal
You could be like the idiot I bought a '96 SC2 from and cut the rubber filler hose so you can stick a sphion tube into it.
You could also not be an idiot and take the fuel line off the regulator/filter (assuming a '98+ S-Series), put it into a 5gal can and jump the fuel pump relay until the tanks full.
Gas Tank removal Yerboogieman S-Series General 12 08-05-2014 05:46 PM
head removal quick question Cory S-Series Tech 21 03-01-2012 04:28 PM
98+ Tank Vent Removal KingRex S-Series Tech 0 02-26-2010 09:15 PM
quick quick quick question about flywheel. Jinjo S-Series General 3 09-07-2006 10:31 AM
Fuel Tank removal glp103 S-Series General 3 10-17-2005 09:44 PM
