Old 07-01-2016, 01:22 PM   #1
cdog999
cdog999 is on a distinguished road
Default 2005 ion 2 battery type 75 or 78
I'm confused on what battery I should get. Walmart says 75 and Sam's club says 78. How could the same company recommend different sizes?
cdog999 is offline   Reply With Quote
Old 07-01-2016, 05:08 PM   #2
cdog999
Default Re: 2005 ion 2 battery type 75 or 78
EDIT: I checked the current battery and it says 75FT. Still not sure why I'm seeing 78 in some places.
Old 07-01-2016, 06:00 PM   #3
I did a catalog check at AC Delco for a battery on your vehicle. It shows both batteries as suitable for the Ion. Personally, I prefer a battery with a larger case if the space is available. I would therefore choose the group 78 battery over the group 75.
332,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Old 07-12-2016, 10:20 PM   #4
lgodave
2003 ION-3 Sedan
To clarify the battery size for the ION changed during its 2003-2007 run so earlier models will have one size while later models another. Some catalogs and reference guides don't properly reflect which size is correct for their vehicle.
In general I agree with going with the biggest battery that will fit your Vehicle. However, if your ION uses the smaller size the existing battery strap/vent tubing may not work properly when "upsizing".
Take measurements of your existing battery/compartment/vents and check the replacement will fit regardless of what the book(s) say.
Old 07-12-2016, 11:17 PM   #5
lgodave
2003 ION-3 Sedan
Your '05 is probably using a 75... its my impression that they switched during the 2006 model year. So some '06s will have 75 and others 78. Anyone with specific details?
Help with charging 2005 ION battery in trunk. les1234 Ion Tech 27 05-25-2020 01:49 AM
What type of motor for 2005 Vue srez Vue General 2 02-28-2013 07:55 PM
Battery Type Question: 2005 Ion gsgmxm5 Ion Tech 25 12-21-2010 12:55 PM
ION 2005 coupe Battery - Grey Cables fou Ion Tech 7 12-13-2009 03:27 PM
2005 ION cutting off with battery light coming on rjamison Ion Tech 0 12-07-2005 04:30 PM
