Old 12-30-2013, 12:08 AM   #1
dakota1820
dakota1820 will become famous soon enough
2000 SL1
Default a weird 1 second stumble
My 02 has been acting weird and one by one ive fixed the little issues. First issue was a bad plug second was the fixed orfice pcv.
Now the issue I have , if I start the car and let it idle after a couple minutes itll haveba quick cough. The idle will just free fall but only for literally a second. Its quick enough by time you realized it happened its done.
Its done it twice while driving both times I started and left right away. Went to pull out shifted to second and as soon as I hit the gas it would stumble just like say instead of shifting to 2nd you shifted straight to 5th. Its very violent jerk but its only one single jerk then its done. It hasnt done it for a couple days. No cel. I dont even know where to start.
dakota1820 is offline   Reply With Quote
Old 12-30-2013, 03:44 PM   #2
BV22
2002 SC1
Default Re: a weird 1 second stumble
If the lights and accessories dim when the stumble occurs, I'd focus on the battery and its connections. If not, it is most likely something intermittent in the ignition system. Plugs, wires and a clean up of the ground points on the coils and ICM would be a good first step.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 12-30-2013, 06:57 PM   #3
dakota1820
2000 SL1
No light issues. Charging system is good as is all the stuff you mentioned. The icm was actually replaced but I did verify all that stuff is good.
Old 01-04-2014, 10:19 PM   #4
dakota1820
2000 SL1
The car hasnt done it lately until today. Today taking off engine cold, as I was driving it bucked very violently and then was fine..... any ideas?
Old 01-04-2014, 10:59 PM   #5
anmasher
anmasher has a spectacular aura aboutanmasher has a spectacular aura aboutanmasher has a spectacular aura about
anmasher's Avatar
1996 SL2
Mine did that today too, very very cold and it was on the first 1->2 shift. For me it is always a bit rougher when extremely cold out until things warm up a little.
anmasher is offline   Reply With Quote
Old 01-04-2014, 11:06 PM   #6
dakota1820
2000 SL1
It was weird. It's like it had a sever misfire for 1 second. Very strange. I don't know what is wrong with it.
Old 01-05-2014, 12:55 PM   #7
ehunter
ehunter has a spectacular aura aboutehunter has a spectacular aura about
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
1996 SL2
See this:
http://www.saturnfans.com/forums/sho...1&postcount=28
ehunter is offline   Reply With Quote
Old 01-05-2014, 01:02 PM   #8
dakota1820
2000 SL1
So it could be an o2 sensor? I just replaced it with a walker sensor it Seems to switch pretty quick from what I can tell. I have sprayed all vacuum lines with no change In anything .
Old 01-05-2014, 01:17 PM   #9
Search for temporarily blocking off egr valve ports. Cleaning addresses only half the issue while blocking off ports addresses it completely.
VCX NANO
Old 01-05-2014, 01:27 PM   #10
dakota1820
2000 SL1
I read something about using a soda can to block it off. But why? What's the reason behind it? If it fixes it what does it mean is the issue?
Stumble in, Sit down SpaceSheep Introductions & Greetings 0 10-11-2012 06:31 PM
Engine Stumble David R S-Series Tech 21 02-09-2011 05:55 PM
stumble at 55 speed150 S-Series Tech 2 06-26-2008 12:38 PM
SL2 - Engine Stumble martx-5 S-Series Tech 13 04-30-2007 10:25 PM
stumble on take off again gypsy35 S-Series Tech 2 01-17-2006 10:13 AM
