Old 10-02-2011, 06:19 PM   #1
jstrower
jstrower is on a distinguished road
Default 07 Aura Heater problems, Engine Over Heating
I have a 2007 Saturn Aura XR, 3.5 motor. I have no heat and the car keeps over heating. Any thoughts on where to start?
jstrower is offline   Reply With Quote
Old 10-02-2011, 08:39 PM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: 07 Aura Heater problems, Engine Over Heating
you have 3.6v6... maybe thermostat....
Old 10-02-2011, 08:58 PM   #3
greenman
greenman is a jewel in the roughgreenman is a jewel in the roughgreenman is a jewel in the rough
2009 AURA XE
Are you losing coolant?
greenman is offline   Reply With Quote
Old 10-02-2011, 11:12 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Is the cooling fan coming on?
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-03-2011, 12:26 AM   #5
whiteshadow
whiteshadow is on a distinguished road
no heat and the motor is overheating?
have you checked the coolant level?
07 aura xr
98 explorer 5.0
93 miata, not stock
77 f150
im not nice
number of times ban.T
1
whiteshadow is offline   Reply With Quote
Old 10-07-2011, 06:03 PM   #6
jstrower
Sorry, I've been away from my computer. Not sure about the coolant. It was low and I added some back to the fill line. Is the thermostat hard to replace?
Old 10-07-2011, 06:47 PM   #7
greenman
2009 AURA XE
You should never have to top up the coolant. You have a leak somewhere. Either internal or external.
Old 10-07-2011, 09:08 PM   #8
jstrower
The problem just started happening (overheating and cooling fan coming on after engine is turned off). We noticed the floor boards were we in the rear passenger side a couple months ago.
So my next question is where can I find a free guide to change the thermostat and where can I find a free guide to replace the heater core?
The mechanic said it would cost about $600 to replace the heater core. I think I will tackle it on my own.
Has anyone ever done it? Is it hard?
Old 10-07-2011, 11:52 PM   #9
greenman
2009 AURA XE
If the heater core was leaking the interior would smell like dexcool. Does it? Replacing the heater core is a very tough job that entails pulling the dash out. There are other reasons for water in the cabin. You want to be very sure on this diagnosis.
Old 10-08-2011, 10:42 AM   #10
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
keep in mind if you are still under 5/100 thermostat is covered with zero deduct..
Old 10-08-2011, 11:34 PM   #11
jstrower
no, the interior did not smell like dexcool. Also it was the rear floor board that was wet, with no smell. It was wet like 2 months ago and has not been wet since. It just started over heating a few days ago.
So what about the thermostat? Is it hard to change? Can a computer diagnostic tell if the thermostat is bad?
Thanks for all your help.
Old 10-09-2011, 12:24 AM   #12
greenman
2009 AURA XE
First, even if you replace it, you will still have the problem of losing coolant somewhere. How much coolant did you have to add & has adding it helped with the overheating issue?
Hard is a very relative term. Since I have no clue what your skill level is, how can I even begin to answer that? If you have ever replaced one before, nothing has changed except the location...which is above the A/C compressor.
There are no sensors on the thermostat to tell you it's working properly.
Thermostat replacement is covered in both the Haynes Malibu & Chiltons G6 books:
http://www.saturnfans.com/forums/sho...service+manual
aura, heater, heater core, overheat
Heater Problems lori7anne Ion General 4 03-05-2010 12:43 PM
engine heater for an 09 Aura with the 3.6L jimltz Aura General 4 01-08-2010 12:52 PM
2008 XR heating problems bwxr 2008 Vue 13 01-16-2009 03:25 PM
heating and coolant problems 96 sl1 dylanzachgabby S-Series Tech 1 02-26-2008 10:03 AM
Heating and tempurature problems jnk111 S-Series Tech 13 02-22-2008 07:36 PM
