Old 03-04-2011, 09:43 PM   #1
ςατμяη gμψ
ςατμяη gμψ is on a distinguished road
ςατμяη gμψ's Avatar
Happy 2002 Saturn SC2 Air Dam
I was returning from a hockey game the other day and noticed that the air dam under the front bumper of my car was loose and hanging really low on one side. When I washed my car today, I decided to secure it to the bottom of the radiator with two zip ties, which looks like it will be a good temporary fix.
My questions are, how important is the air dam? If I removed it completely are there drawbacks in doing so? Should I attempt to repair it properly or replace it? If the zip ties look like they will hold it in place, is this good enough? Looking at it today after I secured it with the zip ties, it looked pretty good and straight. Thanks!
AEM Short Ram Intake
Disabled DRLs
Cleaned Throttle Body
New Front Brakes and Rotors
New Spark Plugs and Wires
New Battery
Charged A/C
New Michelin Primacy MXV4 Tires
ςατμяη gμψ is offline   Reply With Quote
Old 03-04-2011, 09:49 PM   #2
Default Re: 2002 Saturn SC2 Air Dam
I do not have one, never had one and have never overheated. The function of the thing is to create a partial vacuum behind the fan so you suck more air through the radiator. This is only going to be effective in stop and go city driving. So, if you do not do much of the stop and go city driving you don't need it. It is supposed to be held on by springs so it does not beak something when you run it over a parking bumper.
Old 03-04-2011, 09:52 PM   #3
ςατμяη gμψ
ςατμяη gμψ's Avatar
Dizzy Re: 2002 Saturn SC2 Air Dam
You are fast, my man! Thanks. I think I'll probably just be content with the zip tie fix, although I might replace the white ones with black so it doesn't show from the outside. The air dam is the least of my problems. I need to change trans fluid, antifreeze, fix sunroof, fix minor body damage, etc!
Disabled DRLs
New Battery
Charged A/C
Old 03-05-2011, 12:30 AM   #4
eRic 02sc2
eRic 02sc2's Avatar
it is important. your car may overheat without it. Saturn would not have installed it if it was not functional.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 03-05-2011, 12:40 AM   #5
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
The cooling system can cope without it, but I personally recommend to keep it there.
Neither of my cars had the airdam on them when I got them and I have since found some used ones and reattached them with the dealer supplied airdam springs.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
SLCraig is offline   Reply With Quote
Old 03-05-2011, 12:41 AM   #6
ςατμяη gμψ
ςατμяη gμψ's Avatar
Devil Re: 2002 Saturn SC2 Air Dam
Do you think my zip-ties are good enough or do I need to restore it to factory condition?
Disabled DRLs
New Battery
Charged A/C
Old 03-05-2011, 12:55 AM   #7
ςατμяη gμψ
ςατμяη gμψ's Avatar
Wrench Re: 2002 Saturn SC2 Air Dam
So is my jank zip tie fix good enough, or should I bring it to a mechanic? I would post a pic, but it is dark now.
Disabled DRLs
New Battery
Charged A/C
Old 03-05-2011, 01:31 AM   #8
If you keep it springs would be better. You can probably find replacements at the junk yard. The thing was required on the gen-1 front end design to get adequate low speed air flow but the gen-2 and 3 do not have the same inlet aerodynamics. If you drive in city rush hour stop and go traffic with the A/C on in July and August it helps.
Old 03-05-2011, 01:42 AM   #9
ςατμяη gμψ
ςατμяη gμψ's Avatar
So what do you advise? I mean, seriously, do you expect local mechanics to know what to do on a Saturn SC2 specific problem?
Disabled DRLs
New Battery
Charged A/C
Old 03-05-2011, 02:02 AM   #10
2000mc
2000mc is on a distinguished road
1999 SC1
as i recall theres 4 holes where either end of 2 springs go through, my springs were stretched out and let the air dam flop around when i bought the car. i have a nut and bolt in each of the 4 holes now, think theyre about 1/4 x 1/2long been that way for several years now and havent ripped it off or had any trouble with it.. maybe i'm just a little more carful about what i park the nose over.....
my theories on cooling are at odds w/ oldnuc. i've been running a full grill block since the first time gas was $3/gal to help aerodynamics, and my rad only gets air from what it catches off the airdam. normally i think the saturns would get plenty of air through the grill to stay cool enough w/o the airdam, however alot of GM's cars are designed to be bottom breathers, and a would recommend definitely keeping it on.
2000mc is offline   Reply With Quote
Old 03-05-2011, 02:31 AM   #11
There is a large number, approximately 1 X E10, posts relating to this air dam. I don't think you will find a single post where a true case of overheating was cured by installing the air dam on a gen-2 or 3 car.
Old 03-05-2011, 03:22 AM   #12
frogman
frogman is on a distinguished road
2000 SL2
Yeah I've got a gen 3, removed that dam awhile ago to do something else..... Can't remember what but I never put it back on and never had problems with cooling (canadian summers though)
I think yours is fine (as I've never had problems), others though may not agree
frogman is offline   Reply With Quote
Old 03-05-2011, 11:22 AM   #13
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
its a hunk of useless plastic, it justs get broken, and rebroken, and it drags on the street.
Just toss it.
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
AlexofNazareth is offline   Reply With Quote
Old 03-05-2011, 07:09 PM   #14
rc1488
rc1488's Avatar
+1.
Had cars with it, had cars without it. No difference. Cars see highway and NYC so driving conditions varied and still no issues.
The only reason I would leave it is because during EXTREME wet weather situations where you going through large puddles, it protects the engine & its components.
My '02 does not have it and going through a large puddle on the Saw Mill in NY the engine stalled. I THINK if we had this cover we would have been ok.
Then again if we didn't go through the large puddle we also would have been ok haha
We did make it through btw.
Old 03-06-2011, 02:11 AM   #15
Signmaster
I've had mine off in the past at times and never noticed any difference in cooling, but at the same time it surely isn't hurting cooling either. The way I see it if nothing else it might protect the other section of the air dam tray from debris on the road (and the cat that made ours break the first time).
IMHO if you are going to keep it on use the proper springs, or at least time type of spring or bungee cord setup. Otherwise you can just end up tearing up the larger air dam section if the deflector is mounted too solid.
http://www.trademotion.com/partlocat...&siteid=214643
The dealer part # is 21030793, and a search shows the springs costing $1.30 each. You will need 4 of them if you want to replace them all.
Richpins spring install video
Old 03-06-2011, 02:37 AM   #16
Low Saturn
Low Saturn's Avatar
2007 AURA XR
The only S-Series I think that really could overheat without the air dam would be the 1991-1992 SC / 1993-1994 SC2. There is no direct air flow through the radiator from the front of the car like all other S-Series. That "grill" on the front does nothing. Its not even a grill. Its solid plastic behind it.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-07-2011, 11:59 AM   #17
The only car that I know of that had overheating cured by an air dam was an ex-girlfriends late 80's Trans Am. True bottom breather, no openings in the front of the nose at all. But then again, the big V8 put out a little more heat than the Saturn's 1.9
Old 03-07-2011, 01:32 PM   #18
The Saturn air dam is spring loaded and will tend to fold back at speed to lessen drag. It is a low speed device and as long as you have a clear intake you do not need it. Refer to Low Saturn's post above.
Old 03-02-2017, 10:48 PM   #19
Medtactics
Medtactics is just really niceMedtactics is just really niceMedtactics is just really niceMedtactics is just really nice
Medtactics's Avatar
1999 SC2
If it was bigger I would say fix it as it is for areodynamic porpoises, but as small as it is, it's pretty optional.
Medtactics is offline   Reply With Quote
Old 03-05-2017, 08:40 AM   #20
Signmaster
Six year old zombie thread revival!
But since it's revived, some input beyond that I said back in 2011....
During a period of changed commute and lots more traffic snarls I discovered just how much the air dam can make a difference at lower speeds. On my car, only really in stop and go traffic at speeds less than 25 MPH or so. But in those conditions, having the air dam in place saves a lot of cooling fan cycles, and the car starts cooling from "above normal temp" down to normal even when crawling along at 15 MPH or so.
My car has the smaller straight air dam too. I'd imagine the longer ones would make an even greater impact.
2002 Saturn Vue AWD ryno351 Vue General 3 04-18-2020 04:52 PM
2002 Saturn Vue V6 AWD skyk2004 Vue Tech 10 02-04-2015 10:09 PM
My first Saturn - 2002 SL geedub S-Series General 8 12-24-2007 06:11 PM
2002 Saturn SL1 using oil Gadweller S-Series General 2 05-26-2005 10:39 PM
2002 Saturn SL1 SlapCaddle Classifieds 0 03-13-2004 11:35 PM
