Old 02-12-2010, 12:23 AM   #1
LSCCab
LSCCab is on a distinguished road
Default Coffee spilled in shifter console - '08 Outlook
Cannot get shifter out of Park. Took it to local dealer. They said liquid has been spilled and seeped into the shifter linkage and solonoid. Cleaning won't help because it is inside of parts. Parts and labor to fix is $1,250.00. (not covered under warranty). Has anybody had this problem? What can we do now?
LSCCab is offline   Reply With Quote
Old 02-12-2010, 04:06 PM   #2
ARECCE
ARECCE is on a distinguished road
Default Re: Coffee spilled in shifter console - '08 Outlook
That seems pretty high for the repair. Below is the parts that by your description you would need. Have them give you a breakdown of the parts and their cost. Also get a list of the labor and what it is.
1 25778920 SN BASE ASM-A/TRNS CONT $69.02
1 88861426 SN LUBRICANT,SYNTHETIC $ 17.12
1 15879672 SN BEZEL ASM-A/TRNS CON $ 123.18
ARECCE is offline   Reply With Quote
Old 02-13-2010, 08:59 PM   #3
RoadIon
RoadIon will become famous soon enough
2007 ION Red Line
2007 ION-3 Sedan
Nope ............ I do not drink and drive.
RoadIon is offline   Reply With Quote
Old 02-14-2010, 05:23 PM   #4
wolfman
wolfman's Avatar
IIRC there is a way to release the shifter manually, bypassing the BTS (Brake to shift) system. Suggest you consult the Owner's Manual...
wolfman is offline   Reply With Quote
Old 02-15-2010, 12:36 PM   #5
RoadIon
2007 ION Red Line
2007 ION-3 Sedan
IIRC there is a way to keep this type of thing from happening
Suggest you say no to coffee, say no to food, then shut up and drive. If not I just don't care how bad you destroy your auto, or what it cost you for repairs, as long as you don't mame or kill the innocent.
Old 02-15-2010, 03:14 PM   #6
page2171
page2171 will become famous soon enough
page2171's Avatar
That's real helpful...you just trying to run up your post count?
page2171 is offline   Reply With Quote
Old 02-22-2010, 03:46 PM   #7
Way2QWK
Way2QWK is on a distinguished road
I have had this complaint before and this bulletin showed exactly where to clean. Worked like new after. Labor is only .7 This bulletin has pictures but they wont transfer over. sorry I dont know why dealers cant ever find these bulletins.
#09-07-30-002: Console Mounted Shifter Control Binding or Noisy (Clean Transmission Control Assembly) - (Jan 7, 2009)
Subject: Console Mounted Shifter Control Binding or Noisy (Clean Transmission Control Assembly)
Models: 2008-2009 Buick Enclave
2007-2009 GMC Acadia
2007-2009 Saturn OUTLOOK
Condition
Some customers may comment about an intermittent squeaking noise coming from inside the automatic transmission control area and/or the lower console area. Customers may also comment that the shifter is difficult to operate. Inspection may reveal a sticky residue on the external surfaces of the automatic transmission control.
Cause
Investigation has determined that a beverage may have spilled on the console and worked its way into the shifter control assembly causing the moving components to bind and stick. The components within the assembly that are affected include the "rooster comb", detent spring and associated mechanisms.
Correction
Clean the sticky residue off of the external and/or internal shifter components.
Do Not Replace the shifter Automatic Control Base Assembly.
Use the Labor operation listed below.
Do Not Use Labor Operation K5224.
Important: Do not use any solvent based cleaning products as they may attack and compromise the integrity of the composite materials used in the control assembly.
Clean the external shifter control components including the shifter handle, bezel and the moving closeout panel using the cleaner listed below. Verify that the condition has been corrected. If the condition is not corrected, use the following steps.
Remove the left side console extension panel to access the automatic transmission control. Refer to Front Floor Console Extension Panel Replacement - Left Side in SI (1).
Protect the floor carpet panels on both sides of the console base with absorbent towels to prevent staining from the liquid cleaner used in the following steps (1).
Locate the stepped selector section and detent spring on the shifter assembly (Acadia, Enclave and OUTLOOK automatic transmission control shown (1)).
Clean the sticky residue from the surfaces of the stepped selector section and detent spring on the shifter assembly using the cleaner listed below. It may require the use of a small brush to loosen the residue. Keep the direct spray away from electrical components.
After thoroughly cleaning the components, wipe off the liquid with an absorbent towel.
A small amount of compressed air may be helpful to assist in drying the components and surrounding area. Use care not to spread the liquid on to adjacent interior components.
Verify the performance of the mechanical and electrical components after cleaning procedures.
Reinstall the components removed in step 1.
Thoroughly inspect the console base area and carpet for residue and clean as required.
***Saturn Tech and owner of Planet Automotive in Tucson AZ. Specializing in Saturn repairs.
94 SW2- custom intake and ported throttle body
2003 Saturn Vue 3.0 v6
Way2QWK is offline   Reply With Quote
2006 Saturn Vue Leaking Under Center Shifter Console antikaren Vue General 8 07-21-2010 11:37 AM
Spilled Coffee marshall1030 Aura General 7 04-05-2008 03:05 AM
Center Console Shifter Trim Piece oachalon Aura General 3 10-19-2007 11:26 PM
Taking Off the Shifter Console Satman S-Series General 1 09-30-2005 07:54 PM
How much room under the shifter console? MikeF Vue General 1 07-05-2004 04:19 PM
