Old 04-28-2009, 05:47 PM   #1
wolfehunter
wolfehunter is on a distinguished road
Default Plugging the sidewall of a tire?
I've plugged several tires in my life with no problems but they have always been on the treaded part of the tire. I recall being told you can't plug the sidewall of a tire. Is that correct and could someone tell me why?
Thanks,
Scott
wolfehunter is offline   Reply With Quote
Old 04-28-2009, 05:55 PM   #2
saturnsl293
saturnsl293 is on a distinguished road
saturnsl293's Avatar
1993 SL2
Default Re: Plugging the sidewall of a tire?
I've heard that too and wish I could remember the reason why but I want to say it could lead to a blow out or sidewall failure or something like that
saturnsl293 is offline   Reply With Quote
Old 04-28-2009, 05:56 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Thanks,
Scott
I've heard the same thing. Probably because there is a lot of flexing and loads going in different directions on the sidewall. I wouldnt attempt to plug it.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 04-28-2009, 06:16 PM   #4
The flexing of the sidewall will cause the plug to come out. You can put a boot on the inside but it will throw the balance way off and it also tends to fail. A hole in the sidewall is the end of the tire for use on a road car.
Old 04-28-2009, 06:18 PM   #5
Low Saturn
Low Saturn's Avatar
2007 AURA XR
It can be used as a swing on a nice big tree. Or something else that fans of The Shield might remember.
Mike
-1991 Turbo SL2.
Old 04-28-2009, 07:16 PM   #6
nwhamann
nwhamann is on a distinguished road
1998 SW2
2001 L-Series 2.2L Sedan
i work at discount tire and you CANNOT PLUG THE SIDEWALL.
maybe the shoulder if it's a michillin with an extended belt package.
in a steel belted thire there are thousands of steel wire when a tire is puncture in that package the wires are exposed and if you stick a screw driver or probe in there and wiggle it you can hear them. When you plug it, the plug is meant to grab on the ste exposed belt (that's why you ream it, to remove some rubber and expsoe them more.)
now... you CAN plug it... but itll probly blow out on you, put the spare on... if the front is the one with the problem, rotate the full size back tire to the front and put the spare on the back to help you diff in the tranny out.
hope this helps and good luck.
nwhamann is offline   Reply With Quote
Old 04-28-2009, 08:34 PM   #7
mr18436572
mr18436572 is on a distinguished road
2000 SL2
A plug on the sidewall will hold air. But like it has been said, its not recommended for prolonged use.
BTW, I worked briefly at Discount Tire. It sucked
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
mr18436572 is offline   Reply With Quote
Old 04-28-2009, 09:14 PM   #8
wolfehunter
Thanks for the information. Tire is pretty much done for! As a matter of fact we already have one hanging from a tree out front! Wonder if BF Goodrich has any kind kind of warranty for something like this? The tires aren't that old. You guys from Discount Tire have any information?
Old 04-28-2009, 09:44 PM   #9
nwhamann
1998 SW2
unless i sold it to you ; ) or another discount.....
im actually a journeymen electrician but was laid off about 9 mos ago so i got in there from a cousin.
Old 04-29-2009, 11:07 AM   #10
Greg1
Greg1 will become famous soon enough
Greg1's Avatar
1997 SW2
When I ran over a huge file with my BF Goodrich tire the road hazard warranty I bought from the tire shop covered the cost of the tire itself. I still had to pay for balancing, tax and the warranty again. It came to $36 instead of $100.
97 SW2 5-Sp 273k -mine
02 SC2 5-Sp 67k - best friend's
Greg1 is offline   Reply With Quote
Old 04-29-2009, 02:12 PM   #11
wolfehunter
Thanks guys. I bought these from Tire Rack and did not purchase any "Road Hazard" warranty.
Old 04-30-2009, 08:57 AM   #12
92SC2
92SC2 is on a distinguished road
It has to do with the loading of the tires and the flex of the side walls. They're under a tremendous amount of force that is constantly chancing in intensity and direction. You stand a good chance of it losing air, and a decent chance of the side wall failing catastrophically. Think about the implications of that at highway speeds.
92SC2 is offline   Reply With Quote
plugging brake line green S-Series Tech 3 11-03-2007 01:29 PM
2 sidewall blowouts equal 4 new tires! TheSlayer Vue Red Line 0 10-27-2007 12:01 PM
$40 tire vs $150 tire xupthree60 S-Series General 44 04-27-2006 05:45 PM
Plugging Auto-Transaxle Holes PSC2 S-Series Tech 5 12-08-2005 05:44 PM
Question about tire damage after flat tire? Tiger S-Series Tech 8 11-27-2005 05:29 PM
