Old 02-28-2009, 02:25 AM   #1
wolfehunter
wolfehunter is on a distinguished road
Default 98 SL2 Shifter Linkage?
Pulled in the driveway tonight, put it in reverse (5 speed) and I think I felt my linkage unhook. Transmission is stuck in Reverse and the shifter moves freely front and back without depressing the clutch but no side to side movement. Is this an easy fix and can someone walk me through it? All advice welcome. thanks, Scott
wolfehunter is offline   Reply With Quote
Old 02-28-2009, 02:53 AM   #2
wolfehunter
Default Re: 98 SL2 Shifter Linkage?
Just got done doing a search and I'm hoping I get lucky and just need a shifter bushing as it looks like it is a common problem. sounds like I need to look on ebay if I need one or I saw a post about Toyota siper linkage bushings from Advanced Auto will work in a pinch. the steel one sounds better. also read where someone used a bolt, nut and a few washers. I'll check it out tomorrow night after work and hopefully get to the root of my problem.
Old 02-28-2009, 09:02 AM   #3
aa4lr
aa4lr has a spectacular aura aboutaa4lr has a spectacular aura about
The center console should come up with just four screws removed, two in back, two in front.
If it is the shifter bushing (which is likely), you may be able to do a temporary fix using two or three wire ties to hold the shifter cable end over the ball.
I would recommend the shifter bushing replacements sold on eBay -- either the Delrin or the Stainless bushing -- your choice.
I cannot recommend the Toyota wiper bushings. I tried them for about three months, and the bushing was so tight it worked the end off of my shifter cables. I opted to replace the cables entirely -- a $260 part from the dealer. The cables come with a new shifter bushing.
Good luck!
Bill Coleman
2001 Saturn SC2 Auto (3/13-...) "Yellow"
1999 Saturn SL2 Auto (11/09-...) "White"
1995 Saturn SC1 Manual (9/08-...) "Gold"
1994 Saturn SL1 Auto (7/94-1/04) 144,000 miles "Green"
aa4lr is offline   Reply With Quote
Old 02-28-2009, 12:44 PM   #4
madpogue
1996 SW2
Dorman (aka Motormite "HELP!") now makes a bushing for our cars. Part #14043. No word on the forums yet as to its performance / quality / ease of installation.
Old 02-28-2009, 01:57 PM   #5
metz281
metz281 is on a distinguished road
1997 SC2
dont forget to check the transmission end as well. The clips lose their grip after have the transmission removed several times (for clutch job) and can pop off. Make the shifter feel like a wet noodle. LOL There are 4 clips, One holds the cable to the case, and the other holds the cable end to the linkage, on both linkages. Have an assistant work the linkage and make sure its all hooked up before you rip out the console.
metz281 is offline   Reply With Quote
Old 02-28-2009, 02:14 PM   #6
+1^^^ Check drawing.
Old 02-28-2009, 09:17 PM   #7
wolfehunter
Thank you for the information and the linkage picture. Had my son wiggle the shifter but no go at the transmission end. All clips looked to be in place. Took the console off and found the one cable is unhooked on the passenger side and I found the pieces of the black plastic bushing. Need the car for work Monday so I'm going to try either the HELP part #14043 I saw in one of the posts or the Toyota wiper linkage bushing part #49448 at Advanced Auto tomorrow after Sunday School and Church. Wish me luck! NUC......you're the best!!
Old 02-28-2009, 09:33 PM   #8
The HELP rack now has a specific Saturn shifter bushing. Try to get that one. The others can be difficult to install. Madpogue posted the part number and I did not capture it as I have the steel bushing installed.
Old 03-01-2009, 12:54 PM   #9
wolfehunter
While I have the console tore apart should I be lubricating or servicing anything else in there? We're on our way to a Advanced Auto for the part and taking the family out to lunch. I'll look for the specific Saturn part.
Old 03-01-2009, 01:53 PM   #10
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
1996 SL2
When the care is off you should be able to put it into any gear without using the clutch. Just FYI.
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Fox Slaughter is offline   Reply With Quote
Old 03-01-2009, 03:26 PM   #11
KCdave
KCdave is on a distinguished road
KCdave's Avatar
This one is funny for me. I had forgotten that I patched the linkage for my daughter about 3 years ago.
Enough to get her to the shop for a proper fix.
Guess what?
It's still there and working fine.
Just some vinyl Zip Strips (wire ties)
_______________
5 Speed Manual
KCdave is offline   Reply With Quote
Old 03-01-2009, 04:13 PM   #12
aa4lr
If you can find the 14043 part, then try that. Don't use the Toyota wiper bushing. Order the replacement part off e-Bay. In the meantime, two or three well-placed wire ties will allow you to shift fine for a few days, so long as you take it easy.
I used the Toyota Wiper Bushing for three months and it worked the end off my shifter cables. It's too tight on the shift ball and doesn't twist properly.
Bill Coleman
Old 03-01-2009, 04:51 PM   #13
[QUOTE=aa4lr;1408693I used the Toyota Wiper Bushing for three months and it worked the end off my shifter cables. It's too tight on the shift ball and doesn't twist properly.[/QUOTE]
That is exactly the problem with the Toyota part. It will ruin your factory cable and they are expensive to replace and the afremarket cable is to flexible.
The stainless steel bushing will work just fine.
Old 03-01-2009, 07:47 PM   #14
wolfehunter
They had to order the part at Advanced Auto and it won't be in for 3 days so I took the advice and used a couple of nylon ties for a temporary fix. Threw a couple in the glove compartment for spares and left the console off until I get it fixed. They wanted $21 plus tax for the part so I decided to order the Delrin one off of Ebay for $17 and some odd cents shipped to my door. Says it has a lifetime warranty and aa4lr suggested it as well so I'll give it a try. Thanks for getting me going again.
binding shifter and shift linkage? Melissa_M S-Series Tech 26 12-02-2009 07:17 PM
Shifter cable/linkage issues Slammin96 S-Series Tech 25 10-02-2009 01:16 PM
shifter linkage connection on 98 SL1 abinder S-Series Tech 0 05-26-2009 08:29 AM
'99 SC1 Shifter Linkage Buck4U S-Series Tech 6 03-20-2008 11:09 AM
1997 SL2 Throttle Linkage Lub? Bartolo S-Series Tech 4 12-19-2007 02:11 PM
