Old 05-24-2018, 03:05 PM   #1
Agent07
Agent07 is on a distinguished road
2007 VUE Green Line
Question sound blinkers turn signal makes
I catch myself not hearing the turn signal indicator and so forget to adjust the turn signal to OFF. There's a soft sound when I can hear but I am wondering if a fuse or something is not working. Any thoughts?
Add to Agent07's Reputation
Rate the quality of this post and help Agent07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Agent07 is offline   Reply With Quote
Old 05-24-2018, 03:41 PM   #2
Default Re: sound blinkers turn signal makes
Some of the beeps, buzzes, and dinging sounds are generated electronically into a small speaker on the body control module. If you can hear the seat belt buzzer, ignition key reminder when opening your driver's side door or other sounds, the bcm and speaker are still working. There's also the possibility of losing hearing as we age.
The simplest repair may be lubing the turn signal stalk with a spray of lithium grease. The turn signal stalk is still mechanical with a spring loaded detent meant to release the signal stalk and return it to off position when the steering wheel is recentered.
Left Turn Signal makes my dash lights go out ratwhisperer S-Series General 6 10-31-2015 12:14 PM
Turn Signal Clicking Sound Not Working meoge Ion General 6 02-15-2014 09:47 AM
Turn signal blinker sound mcvue 2008 Vue 23 03-25-2008 11:06 PM
2008 Vue..no sound coming from turn signal. tamigood45 Vue Tech 9 10-08-2007 11:37 AM
turn signals - blinkers duffygirl Ion General 30 04-28-2004 06:03 AM
