#4341 |
![]() ![]() ![]() Join Date: Nov 2013
1999 SL1
Removed and replaced my right suspension arm/ ball joint.
the back bolt on the sub frame turned OK, so no problem there. It's all back together now. Now I have to remove and replace both front sway bar bushings. I'm soaking the bolts with Kroil as the Kroil worked really well on the ball joint replacement. Tomorrow I'll use my air impact wrench to rattle the 15MM bolts to see if I can get movement. I do not want to break these off. |
#4342 |
![]() Join Date: Jan 2014
2006 ION Red Line
I ordered EBC front rotors and a set of Hawk HPS pads. Hoping this set will serve me well and put up with my mildly aggressive driving style without over heating and warping within 4-6 months
#4343 |
![]() ![]() ![]() Join Date: Apr 2008
Great! For sure let us know how you like them. I've been wondering about how much better performance they are for our cars.
Proud Owner of an Invincible '98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP + M1 Ext Perf. Oil Filter. Owned 4 other S-Series. |
#4344 |
2006 ION Red Line
For sure! I have a 20 hr road trip planned soon after I instal the rotors and pads. Driving through Detroit and Chicago should prove to be a worthy test....
#4345 | |
We'll see how the muffler holds up with the Black Velvet and paint
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#4346 |
1999 SL1
Installed both front sway bar bushings yesterday. Used the Energy Suspension polyurethane 18.5101G in black. Had to go to the auto parts store to buy a 15 MM deep 6 point impact socket as the cheap one I had split from the torque i put on it. Since I cannot find my impact gun, I just used a 1/2" breaker bar after the application of Kroil the day before and applied anti seize to the threads of the bolts. The bushings came with a small tube of thick silicone grease to apply inside the bushing. All went well until I forgot to remove the tool I used to pry the sway bar away from the sub frame to insert the bushing. I had to loosen the just tightened bolts to get it out.. Doh!
#4347 |
installed a new serpentine belt , the dayco looked good but was stretched went with a Mexican gates.
#4348 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
1997 SL1
1995 SL1 replaced 2 ac compressor o rings, added dye and evac system. Added 2 12oz. cans and 48° at center vent.
![]() ![]() 1995 SL1 215,985 Well Oiled!! ![]() 1997 SL1 50,020 Just A Teenager!! ![]() CHECK YOUR OIL!! ![]() |
#4349 |
Ultra-Detailed the '98 SC2 Red Hot. Inside & out.
Also took the professional buffer to some scratches (from the previous owner of course) on the back bumper below the trunk lid. Not like I like the Red Hot to glow or anything......... ![]() ![]() ![]()
#4350 |
While pulling out of the garage after an oil change, the driver's side mirror on my sister's 02 SL2 got into a fight with a tree and lost horribly.
I replaced that mirror assembly today. ![]()
Purple 1994 SW2 auto. 324k+ miles. Head gasket replaced due to an overheat at ~261k. Timing chain replaced before putting the engine back together. |
#4351 |
Yesterday I replaced the "dog-bone" motor mounts with cheapie parts from eBay. Ugh, not the wisest decision. They look like flat metal wrapped into a dog-bone shape. The factory mounts were all sculpted with gussets and stuff for strength. To make things worse, the replacement mounts didn't even fix all of the jerking/rocking motion that happens in 1st sometimes. It's maybe 30% better. Perhaps I'll see about fitting poly bushings into the old ones in the future. Should have saved my $25 to go towards that. Live and learn.
Oh, and then I changed the oil! |
#4352 |
![]() Join Date: Oct 2006
Changed tranny fluid in the 2001 and 1996, both filled with Torque-Drive. Changed oil in the '96, Meijer dino.
#4353 |
#4354 |
![]() Join Date: May 2015
1994 SC2
I went to check the spark plugs today and there was oil in all 4 wells! The worst was the cylinder 2 spark plug well, which had a fully submerged spark plug. My uncle noticed that the edges of the valve cover looked bad about two weeks ago but I haven't had the funds to replace the gasket yet. I last checked about a week ago and all of the wells were bone dry. Needless to say, I freed up the funds for a gasket, but it won't be in until about Friday. I cleaned off the plug wires very well. As far as I can tell, I won't need to replace the wires. The plugs themselves will all be replaced when I change out the gasket.
1994 Black and Gold Saturn SC2 156k |
#4355 |
Ran my car through DEQ today.
HC = 29 ppm CO% = .0416 CO+CO2 = 14.7 Not too shabby for a 22 year old DOHC with original cat ![]()
1999 SL2 A4 - 100k Mobil 1 + Rislone & Wix 51516 UCL added to fuel fill ups ..... 1993 SL2 SOLD @189k |
#4356 |
Started the process of replacing the right door rear applique.
I was just wondering how I was going to paint the piece when one showed up on e bay. olde one chipped last winter ![]() New one peeling back the wrapper to show that shine-e goodness ![]() All good things come from Canada ![]() I am not sure how many of these remain. An enterprising individual could earn a little extra cash refinishing these trim pieces ![]() Last edited by bumpdraft; 06-17-2015 at 09:23 PM. Reason: FLINT FIREBIRDS are now taking auditions for singing the U.S. and Canadian National Anthem at Hockey Games |
#4357 |
2006 ION Red Line
Today I had to push my car backwards into a parking spot since reverse has left the building, I mean car....
We had just finished a 4 hour drive from Detroit, and we were in Chicago last weekend. Love that city, had a great time! The car did really well in all forward gears at least ![]() I'm debating whether I should fix the transmission, or just get another S-Series. I keep wishing the car was a 5 speed anyways! Back to scanning CL for deals.... ![]() Last edited by SLfun; 06-17-2015 at 09:52 PM. Reason: spelling error |
#4358 |
Waxed Creampuff yesterday & put Meguire's Natural Shine on the dashboard.
Man, this shiny Gold color glows....... ![]()
#4359 |
![]() Join Date: Jul 2012
1996 SC1
1996 SC1
Tuned up, loaded up and going racing. Atlantic Drag Racing Association points meet at Greenfield Dragway, Nova Scotia this weekend.
Green 1996 SC-1, Stock, Sportsman class Drag Racer, 17.97 ET @ 75 MPH. Green 1996 SC-1, 355 Chev, NHRA/IHRA 10.90 class. 1994 Chev ext cab short box 2WD Daily Driver |
#4360 |
![]() ![]() ![]() Join Date: Feb 2012
1999 SC2
Current: 1999 SC2, 198,XXX Past: 1989 Mustang LX, Unknown mileage(JY engine in it when I got it) |
Anyone see the "Judge Judy" episode with the 96 S series today? | dave.sl | S-Series General | 23 | 02-20-2014 04:56 AM |
The S Series would be a great car for the lineup today | VTHokie00SL2 | S-Series General | 46 | 10-01-2012 08:26 AM |
Got the L series recall letter today for rear lights | Garciavision | L-Series General | 27 | 12-22-2005 02:29 PM |
REDLINE Series Announced Today | D C | Vue Red Line | 6 | 04-10-2003 08:14 PM |
Saw the L series DVD system today | Jeff P | L-Series General | 1 | 11-09-2001 09:03 PM |
