Old 09-11-2010, 12:38 PM   #241
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
SRGW's Avatar
1997 SL1
Happy Re: What did you do to your S-Series today...
Changed oil and filter. Got a good deal on oil Mobil Clean 5000 (5 qt. jug) unadvertised special at Autozone $9.99 and a Purolator L20195 at Advance Auto for $3.49. Total cost $13.50 for an oil change!!
1995 SL1 173,500 and go'in strong!!
CHECK YOUR OIL!!!
SRGW is online now   Reply With Quote
Old 09-11-2010, 01:07 PM   #242
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: What did you do to your S-Series today...
Changed the oil on the 1994 SL2 I gave my sons mom last year. Drained exactly four quarts out.
We originally bought this car and rebuilt this engine for my grandfather a little over seven years ago. He drove it until he died in 2006. My brother owned it until 2008 and I had it until the fall of last year when I bought my Aura.
The rebuilt engine has about 80,000 miles on it and it doesnt burn or leak a drop of oil.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 09-11-2010, 08:20 PM   #243
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
Originally Posted by william2001 View Post
Loosened then retightened the bracket at the dogbone link. Hoping to fix a vibration issue at 55 mph, drove it some but can't tell if it helped yet.
That usually helps for vibrations at idle. Vibration at 55-60 is usually due to worn or unbalanced tires.
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh!
Purchased 114k 10/07
Added OEM CC
off-track is offline   Reply With Quote
Old 09-12-2010, 10:09 AM   #244
william2001
william2001 is on a distinguished road
1997 SC1
When I bought the car a couple of months ago the previous owner had a brand new set of tires installed. Assuming of course the tire place balanced them properly. Not knowing for sure I had them rebalanced again. No difference. It almost seems like this car needs that Saturn recommended "powertrain damper kit" I've seen mentioned here. Part of some service bulletin. But I've never seen any members come back and reply about whether it fixed their problem or not. It's always, "parts have been ordered", or "appointment made", then nothing...
william2001 is offline   Reply With Quote
Old 09-14-2010, 09:29 PM   #245
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1996 SL2
I swear the problems never end... I want to smack the previous owner of this car upside the head.
Now I get to replace the radiator because it's got a crack in it. Le sigh.
So today I put coolant in every 20 miles on my way back from a meeting an hour away.
And also a small exhaust issue. (Thank god that something's a small issue).
Still haven't found the right lock button at the pick and pull. I'll go back in after I tackle the radiator.
ratwhisperer is offline   Reply With Quote
Old 09-17-2010, 02:39 PM   #246
ratwhisperer
1996 SL2
New radiator in
Code P0410 - taken care of.
No lock button yet, but all else is good. Feeling major relief.
Old 10-18-2010, 07:16 PM   #247
bumpdraft
bumpdraft's Avatar
1998 SW2
Added a new bracket to hold the front fender / bumper together.
This is why I wanted a plastic car, so stuff like this didn't show!
Before (can you say, "quality of metal?")
After (with a good coat of Rustoleum)
That ground for the battery does very strange things to the driver's side of the frame the bracket on the passenger side was only a little rusty.
I plan to install another ground. - It will run from the big ground bolt at the Under Hood fuse block to the frame on the other side.
two or three lengths of Monster Cable (in parallel) should provide a path of least resistance to the passenger side. (or not??)
Old 10-18-2010, 07:17 PM   #248
adventureoflink
adventureoflink's Avatar
Glad someone dug this up..
anyway, over the last two days, I put in some new door speakers. I also changed my oil today.
Now I'm debating on going back to Best Buy to get two more speakers so I can do the rears.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 10-18-2010, 07:29 PM   #249
Low Saturn
Low Saturn's Avatar
2007 AURA XR
How much do those go for new? I can find tons of rust free ones here. Might be worth me picking up a few if it can save some people some $$$. And make me a few bucks in the process.
Mike
-1991 Turbo SL2.
Old 10-30-2010, 10:01 AM   #250
bumpdraft
bumpdraft's Avatar
1998 SW2
$13.34 each + about $4 for the 4 T-bolts that screw into them.
There's so much stuff you could salvage from your dusty (but otherwise perfect) junk yard Saturns!
You'd have to drill out the rivets.
I used shelf screws to attach the new brackets.
Very hard to reach in there, so I used JB Quick to attach bailing wire to the nuts. Worked very well!
Old 10-30-2010, 10:06 AM   #251
bumpdraft
bumpdraft's Avatar
1998 SW2
Now, back to our regularly scheduled program of rust maintenance in the Rust Belt:
Replaced Brake Pads and Rotors. The squeelers hadn't yet squeeled, so it means the brake pads are still good....right?
What? Me worry?
Hey! Look at me ! I got Rust Jacking! - Just like them Truckers on the Midnight Trucking Radio Network
Q: Does anyone remember when brake pads were "Glued and Riveted?"
Old 10-30-2010, 10:17 AM   #252
bumpdraft
bumpdraft's Avatar
1998 SW2
...That ground for the battery does very strange things to the driver's side of the frame the bracket on the passenger side was only a little rusty.
Here it is
http://www.saturnfans.com/forums/sho...d.php?t=160229
Old 10-30-2010, 10:34 AM   #253
adventureoflink
Not something I did today (did it a couple days ago), but I finally got that right rear seatbelt replaced.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 10-30-2010, 02:41 PM   #254
lewdwig
lewdwig is on a distinguished road
Changed the PCV valve in the '01.
Topped off oil.
lewdwig is offline   Reply With Quote
Old 10-30-2010, 08:25 PM   #255
sousa632
sousa632 is on a distinguished road
sousa632's Avatar
1995 SW2
Took off the egr valve and cleaned it out. The pintle was sticky and it had some carbon buildup. I also cleaned the TB because the butterfly was starting to stick a little. I think I need to replace the PCV valve again as well.
John
96 Tbird 4.6L, 95 Saturn SW2
sousa632 is offline   Reply With Quote
Old 10-31-2010, 08:25 PM   #256
dgreen
dgreen is on a distinguished road
1992 SL1
92 SL1 - New headliner, repaired drivers seat, new carpet, replaced odometer gears, replaced all dash lights, new speakers, restored headlight and tail light lenses, New super bright headlights, installed a new fan control switch and a wash/wax job. It's just like new now!!!
dgreen is offline   Reply With Quote
Old 10-31-2010, 08:39 PM   #257
lost_wreckage
lost_wreckage is on a distinguished road
lost_wreckage's Avatar
1996 SL1
I replaced the lower transmission mount yesterday. It wasn't too difficult except for the defective Pep Boys mount. I had to change it again after the stud broke when torquing the nut. No, I didn't stress it during install, it went straight in.
Oh- I also put in the proper OEM NGK spark plugs. We'll see how those work out!
lost_wreckage is offline   Reply With Quote
Old 11-01-2010, 03:12 AM   #258
bumpdraft
bumpdraft's Avatar
1998 SW2
over the last few days:
Undercoat inside of driver's side lower Engine Cradel
Rustoleum on underbody rust
Reinstalled Front Body Panels
New Sway Bar
New Poly Sway Bar Bushings
New Control Arms
Front Toe Adjustment
Changed Oil
I never noticed this before. All front impacts are recorded** on the back side of the Fascia:
Last edited by bumpdraft; 11-01-2010 at 03:21 AM. Reason: **DISCLAIMER: Image Digitally-Enhanced and does not reflect actual record of driving experience.
Old 11-01-2010, 06:41 AM   #259
Pitcher
Pitcher's Avatar
Replaced the Intake Manifold Gasket!!
The idle went up to 1300 - 2500 RPM's instead of the 750 it was suppose to be! :o When I rev'd the engine way up, it was quite loud; now it's much more controlled and quieter.
A rewarding project.
See the big wrinkle in my Tech Thread........
Owned 4 other S-Series.
Old 11-02-2010, 08:14 PM   #260
mgordon1100
mgordon1100 will become famous soon enough
mgordon1100's Avatar
1997 SC2
I have done nothing with my Saturn today except drive it. However, I couldn't have thought of a better thread to post this in.
I feel lucky, with reading these threads, about my Saturn. I've replaced the clutch twice. Once because of a bad previous owner (new clutch needed at 100K) and a second time because of either a botched job from the first replacement, or a botched job when AAMCO replaced my output shaft seal. They say that they couldn't have caused my clutch to break apart, but it happened when I was driving home from the shop after the seal job.
I replaced the transmission twice, once for my own fault in snow with really bad tires. I was spinning my wheels a lot, so I blame the tires. The second time was a bad bearing on the inside.
Those are the big things.
Everything else was just brake pads and rotors, the vacuum hose from the secondary air pump, spark plugs, and wires. General maintenance stuff. Oh yeah, I replaced the alternator and a starter.
Nearly 200K, and I still use the original CPS and sensors. The fact that I'm almost at 100K on my own with this clutch, just shows me that the previous owner sucked at driving. Also, my last car nearly had 200K with the original clutch when the car was rear ended at a stop light. I bought the car with 30k. Some drivers just think they can drive a stick.
mgordon1100 is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
