Old 06-17-2006, 03:48 PM   #1
Default 5th from a DOHC to a SOHC tranny?
I know they mostly (only...) go the other way for economy but 5th is upsetting me. NO POWER. Latly I've been on the interstate more and so it's just bothering me now but going with the flow at 75-80 in 5th gear is fine 'till a hill. Then it drops down to 60-65 and it's just rather annoying. The majority of the power in my SOHC seems to be between 3k and 4k rpms and 5th is under 3k till 85-90mph so if the 5th gear from the DOHC is shorter, would it give me a bit more "hill" power?
Has anyone done this or would it work exactly the same way as the swap the other way?
I'll probably have to read a few threads on the swap, any of them come to mind as good ones?
Old 06-17-2006, 04:16 PM   #2
1993
1993 is on a distinguished road
Default Re: 5th from a DOHC to a SOHC tranny?
I would not do it..i just recently swapped in a 5th gear from a sohc car into my dohc so the engine wouldnt have to scream like crazy just to keep up on the interstate.. With the dohc 5th gear, your rpm's will be at 3100 just to do 70 mph and that sucks, now, with the sohc 5th gear, i can cruise like a cadillac at 75-80 mph and the motor doesnt have to scream like it did..i would swap in a dohc motor before i would switch to a dohc 5th gear..
1993 is offline   Reply With Quote
Old 06-17-2006, 04:43 PM   #3
SOHC needs the power, and the current 5th dosn't have it. I don't go on the interstate very often but when I do I'd rather not drop speed horrably so thats what I'm wondering about.
I know the SOHC's are geared for economy and the DOHC's are geared for performance, thats why the SOHC gear gets put in the DOHC tranny.
Old 06-17-2006, 05:05 PM   #4
1993
Just drop down to 4th when coming to hills, i think the 4th from a sohc is pretty darn close to the 5th of the dohc, so if you did the swap it would be close to having the same 4th and 5th gears..
Old 06-17-2006, 05:10 PM   #5
I thought about that, does cruise control disengague with the clutch? I know it does with the brake but...?
I hope the SC2 I wanna get is in okay condition, I'll get that swapped in.
Old 06-18-2006, 02:10 AM   #6
Well, no, and yes... Early models had a switch. Later models did not, but the cruise module was programmed to "get the hint" that the revs are going up, but the speed isn't, and interrupt itself. You'll notice that, when you drop the clutch, the revs race for a split second, then the CC abruptly disengages.
Old 06-18-2006, 08:50 AM   #7
I wasn't sure what it would do so I didn't want to try it and have it suddenly floor it and overrev the engine.
I'm thinking about doing a VERY long road trip so I'll leave the 5th gear swapping alone, the majority of the trip will be in "flatlander" country so the hill climbing shouldn't be a problem.
Old 06-18-2006, 11:25 AM   #8
amazinghl
Clutch and brake disengage the curise control.
Just downshift when you come to a hill, it's not that hard.
00 Insight 72mpg
Old 06-18-2006, 12:45 PM   #9
I know it isn't hard, I just didn't feel like bothering to manually disnengauge it and all before downshifting. I just didn't know how it worked in this manual and now I do. Thanks for the info.
Old 06-18-2006, 12:59 PM   #10
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
So instead of simply downshifting when you came to the occassional hill, you'd rather open up your transmission and put the new gear in? You're crazy man! Not that I'm against doing projects on cars like this, but I think you're nuts. I'd swap the DOHC motor in with the DOHC transmission and then swap the 5th gear if you like (I know that's going away from your original plan though).
--Tom
Not a Saturn.
Old 06-18-2006, 01:14 PM   #11
I was just wondering if anyone had done it this way, I've read about tons of people that have gone the other way with it.
"occassional hill"?????? Ever been in the north east? It's more like "occassional flat" then "occassional hill".
When the CC is on, I didn't want to harm the engine by hitting the clutch when I didn't know that it would also disable it. If the SC2 I'm looking at has the engine in decent shape it'll get swapped in.
Old 06-18-2006, 07:44 PM   #12
Sounds like southwestern WI.
Yeah, I don't like that little rev spike from the cruise when I drop the clutch. I usu. tap the brake pedal, just enough to interrupt the cruise, then clutch, before downshifting. So the guy behind me sees my brake lights blink, big whoop.
Old 06-19-2006, 08:51 AM   #13
wolfman
wolfman's Avatar
You'll get an increase in engine RPM anytime you downshift... the clutch pedal switch, via the PCM, should disengage the CC if the clutch is depressed, but of course it must be depressed to the same point that it would be in order to start the car...so...you, in theory can downshift without the cruise disengaging with practice and clutch pedal finesse.
Old 06-19-2006, 10:11 AM   #14
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
As other said, 4th in a Sx1 is nearly identical to 5th in a Sx2. Therefore, you would lose a gear, since the 2 are the same. If you really want to do this, just drive your car in 4th gear on the highway.
Old 06-19-2006, 02:45 PM   #15
Ok, so I'll leave the gear swapping alone, I kinda wondered why people didn't do it this way and now I know. I'll just take some time looking over my new SC2 with 70-90k miles on the engine and make sure it's good before swapping the whole thing, including the 5th gears (going the "good" way though) and welding the diff pin just because it's out.
Old 06-19-2006, 09:54 PM   #16
asdf
asdf is on a distinguished road
Has anyone figured out how to get the cruise control working again after you put a different 5th gear in?
And yeah, with any other 5 speed I've driven, you can never maintain speed up a steep hill or really increase your speed. Always have to downshift to 4th or 3rd. With an automatic, it shifts out of overdrive of course.
asdf is offline   Reply With Quote
Old 06-20-2006, 01:57 AM   #17
Has anyone verified that the cruise gives a rat's patoot what size gear it's in? There's no inputs to the PCM or CC module from a manual tranny. It gauges speed via the VSS. For example, is the CC module for a given year, manual tranny, the same between a DOHC and SOHC?
Old 06-20-2006, 02:07 AM   #18
asdf
I think the earlier years aren't affected. I'm guessing it started with OBD-II? The CC monitors the RPM vs. MPH readings for the 5 gears. So it has 5 gear profiles that must match or it refuses to operate (I guess it would think the clutch is slipping?)
It really sucks since 5th gear is all I use CC in anyways. So, it is the only thing stopping me from changing 5 th gear. Mine is a '96
Old 06-20-2006, 02:10 AM   #19
For what years? The '96 FSM shows the clutch switch being only part of the starter circuit, not going to the PCM. And mine certainly doesn't affect the cruise, as I have mine jumpered closed at all times.
Old 06-20-2006, 02:12 AM   #20
asdf
I think it has something to do with that RPM vs. MPH reading again.
As soon as the RPMs raise a little, the CC disengages. That's why you don't have to put the clutch all the way to the floor to hit the switch before the CC quits.
Looking to replace my 5th s series with a vue. Whats the best engine/tranny combo 84conv Vue General 9 01-07-2010 08:21 PM
2002 SL1 5-spd SOHC 5th gear engine noise flythatway S-Series Tech 6 05-30-2008 07:42 PM
only 3rd and 5th after tranny swap nitsua y zarc S-Series Tech 8 03-11-2008 08:39 PM
SOHC or DOHC tranny??? mark_92SC2 S-Series Tech 1 01-05-2006 08:19 AM
MP2 5th gear in MP3 tranny 98greenSC2 Mods and Performance 15 07-18-2005 12:27 AM
