Old 08-06-2004, 04:03 PM   #1
thetruth
thetruth is on a distinguished road
Default Recalls, are we alone?
For the week of July 26th, 2004 here are this weeks recalls.
2002-04 Honda CR-V
Problem: Improper driver airbag wiring increases the risk of injury in some kinds of crashes
Fix: Repair wiring.
Number of affected vehicles: 131,000
2000-01 Honda Accord
Problem: Dimmer control fails, causing loss of instrument panel illumination.
Fix: Replace mechanism that controls instrument panel brightness.
Number: 20,000
2000 Honda S2000
Problem: Lenses for the side markers and tailight reflectors were made with the wrong dye and will fade.
Fix: Replace tailight assemblies.
Number: 7,000
2003 Ford Excursion and F-250 through F-550, all with 6-liter diesel engines
Problem: Loose engine ground attachment sends current to alternative path, creating a fire hazard.
Fix: Replace engine ground stud; inspect other components; replace those that show damage.
Number: 84,000
2003 Ford Crown Victoria, Lincoln Town Car (Police and fleet vehicles only)
Problem: Rear wheel bearings and axle shafts wear prematurely; shafts break; vehicle stops.
Fix: Replace bearings, shafts, and seals.
Number: 47,000
2004 Ford Taurus, Thunderbird; Mercury Sable
Problem: Improperly welded power-adjustable seat may not support load during a crash.
Fix: Replace upper support on seat.
Number: 24,000
2004 Ford Ranger
Problem: Imprperly formed center rail flange could cause frame rail to puncture fuel tank in crashes.
Fix: Replace vehicle if frame fails inspection
Number: 1,400
2004 Cadillac CTS, SRX, XLR; Chevrolet Corvette
Problem: A washer on the wrong material allows a lower control arm ball joint stud to disengage from yhe knuckle, disrupting steering and possibly reduce brake performance.
Fix: Replace nut and washer if torque has been maintained; replace stud, knuckle, washer and nut if torque has not been maintained.
Number: 42,000
2004 Chevrolet Impala, Monte Carlo; Pontiac Grand Prix
Problem: Loose front brake calipers interfere with normal steering and braking.
Fix: Tighten brake caliper bolts.
Number: 48,000
2002 GMC Envoy, Oldmobile Bravada, all with electronic air suspension
Problem: Electrical spike from air suspension disrupts powertrain control module; vehicle stalls and may not restart.
Fix: Install wiring jumper harness.
Number: 30,000
2004 Chevrolet Malibu Classic, Pontiac Grand Am
Problem: Improperly welded fuel tank leaks gasoline.
Fix: Replace tank.
Number: 2,900
2005 Subaru Legacy Outback
Problem: Side airbag curtains do not deploy fully or quickly enough.
Fix: Replace modules.
Number: 2000
2005 Chrysler 300, Dodge Magnum
Problem: Loose battery cable fastener at bulkhead stud may cause instrument panel fire.
Fix: Tighten fastener.
Number: 12,000
2004 Jeep Liberty with 3.7-liter engine
Problem: Wiring damage by valve cover studs start fire under hood.
Fix: Place protective caps on valve cover studs and reroute wiring.
Number: 1,600
2004 Chrysler Sebring Coupe, Dodge Stratus Coupe, Mitsubishi Eclipse, Eclipse Spyder
Problem: Gasoline leaks from improperly molded return line fitting.
Fix: Replace fuel pump.
Number: 7,000
2004 Mitsubishi Endeavor with All-Wheel drive
Problem: Rear driveshaft comes loose, may fail.
Fix: Replace driveshaft flange bolts.
Number: 29,000
2002-04 Mitsubishi Montero
Problem: Gasoline can leak from fuel leveling valve.
Fix: Replace valve.
Number: 44,000
2004 Nissan Maxima with glass-paneled roof
Problem: Glass can shatter.
Fix: Replace glass panels.
Number: 32,000
So, are we alone?
thetruth
Add to thetruth's Reputation
Rate the quality of this post and help thetruth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thetruth is offline
Old 08-06-2004, 06:18 PM   #2
bob shanks
bob shanks is on a distinguished road
Default
Ain't that the truth.
Add to bob shanks's Reputation
Rate the quality of this post and help bob shanks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bob shanks is offline
Old 08-06-2004, 07:18 PM   #3
04AWDV6VUE
04AWDV6VUE is on a distinguished road
04AWDV6VUE's Avatar
2004 VUE 3.5L
Default
In addition (I didn't see this in the list), DCX is recalling 800,000+ Minivans because they could catch fire.
I think the VUE Recall is getting so much press because they are trying to link it to the Explorer/Firestone Recall, you know since the recall involves the SUV rolling over.
'04 AWD V6 VUE (current)
'00 SC2 (former)
Add to 04AWDV6VUE's Reputation
Rate the quality of this post and help 04AWDV6VUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
04AWDV6VUE is offline
Old 08-06-2004, 09:41 PM   #4
binkybaby
binkybaby is on a distinguished road
binkybaby's Avatar
Default
And it would take such a drastic maneuver in which in real life the truck would probably roll over anyway to cause this falure......this is the kinda material that would go great on Penn and Teller's BS show.......because the way the media is handling it is bulls?!t because they r anti Saturn from the get go!
-sXe for life-
Former Saturn owner but still a Saturn Fan~!
2010 Toyota Tundra SR5, 5.7L
Add to binkybaby's Reputation
Rate the quality of this post and help binkybaby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
binkybaby is offline
Old 08-06-2004, 11:13 PM   #5
ketch
ketch is on a distinguished road
Default
<sarcasm on>
Honda, honda? They got recalled, NEVER!
<sarcasm off>
"GM-Cars With Character"- as opposed to those w/o, like Toyota!
Add to ketch's Reputation
Rate the quality of this post and help ketch reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ketch is offline
Old 08-06-2004, 11:24 PM   #6
ChrisION
ChrisION is on a distinguished road
ChrisION's Avatar
Default
The MPV got a recall too, regarding the Cruise Control
Oh, and so did the TrailBlazer for the windshield wipers...
Add to ChrisION's Reputation
Rate the quality of this post and help ChrisION reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ChrisION is offline
Old 08-06-2004, 11:28 PM   #7
ChrisION
ChrisION's Avatar
Default Re: Recalls, are we alone?
Originally posted by thetruth
2004 Ford Ranger
Number: 1,400
:o:
ChrisION is offline
Old 08-06-2004, 11:49 PM   #8
DesertPuma
DesertPuma is on a distinguished road
DesertPuma's Avatar
Default
2004 Ford Ranger
Number: 1,400
That one deserved a second look! :o: :o: :o:
OMG!
Now a proud Subie owner.
Add to DesertPuma's Reputation
Rate the quality of this post and help DesertPuma reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DesertPuma is offline
Old 08-07-2004, 01:01 AM   #9
monantony
monantony is on a distinguished road
Default
So to clarify, these are recalls issued my the manufacturers for the first week or so of August alone? These werent recalls last month?
T
Yea the frame rail one, OMG
Add to monantony's Reputation
Rate the quality of this post and help monantony reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
monantony is offline
Old 08-07-2004, 09:16 AM   #10
Pete93SL1M
Pete93SL1M is on a distinguished road
Pete93SL1M's Avatar
Default
Note that Saturn will probably not show up on the next list because it is a voluntary customer satisfaction recall initiated by Saturn. These are all Government-mandated recalls forced on the manufacturers by the NHTSA.
..aka GMinTheDriveway
Former Saturn Sales Consultant
Give me choices in powertrain, great handling and decent MPG and I will buy a Saturn again.
Add to Pete93SL1M's Reputation
Rate the quality of this post and help Pete93SL1M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pete93SL1M is offline
Recalls morpheus2969 Outlook General 13 06-13-2007 01:53 AM
recalls... 4time saturn fa Outlook General 5 03-14-2007 02:14 AM
Recalls Cruel Night Ion General 5 12-06-2004 03:37 PM
recalls uplifta Vue General 18 10-26-2004 06:51 PM
Recalls ******* SilverPlumGirl General Saturn Discussion 9 12-06-2000 07:06 PM
