Old 09-18-2017, 03:55 PM   #1
RobertGary1
1996 SC2
Default 2nd A1 Cardone pump still very noisy
After speaking with the A1 Cardone support folks I went ahead and tried another of their pumps. Boy its still noisy. Not the low whine you usually hear from air trapped but a very high whine all the time. I guess I'll go back to the original pump. I only changed it because I had to remove it to change the high pressure line. I was getting steering fluid all over the place and can't really tell where it was coming from by the line was the most likely cause.
I spent way too much time on these pumps, pulling vacuum, trying to bleed etc.
-Robert
RobertGary1 is online now   Reply With Quote
Old 09-18-2017, 05:49 PM   #2
Default Re: 2nd A1 Cardone pump still very noisy
They do not get air bound and jacking up the front end and cycling the steering completely purges and refills the system. A whining pump is a worn out pump.
The vanes and vane slots in the rotor wear and then they start getting noisy. Sometimes a bit higher viscosity fluid quiets the noise for a period of time. As only the soft goods are replaced on a rebuild you end up with a possibly leak tight worn out mechanically pump.
Old 09-18-2017, 05:51 PM   #3
RobertGary1
1996 SC2
Wouldn't a rebuilt pump include new veins and rotor? These are basically the same pumps we use for vacuum on aircraft at a fraction of the price.
-Robert
Old 09-18-2017, 08:53 PM   #4
As far as I have been able to determine there are no replacement vane-rotor sets. That is the problem with rebuilts, the main wear component is not replaced.
Clean high quality ATF is what keeps these pumps running for a long time.
Old 09-19-2017, 12:38 PM   #5
T. Thudpucker
T. Thudpucker is on a distinguished road
Do you have a process to do a fluid change?
#1 1999 SL2, RIP
#2 1999 SL2, Operational
#3 1999 SL2 HCE, Operational
#4 2001 SL1, Operational
#5 2001 SL2 10th Anniversary, stored *NEXT*
#6 1997 SL2, Operational
1979 Dodge Adventurer 200
Add to T. Thudpucker's Reputation
Rate the quality of this post and help T. Thudpucker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
T. Thudpucker is offline   Reply With Quote
Old 09-19-2017, 06:58 PM   #6
RobertGary1
1996 SC2
I've not specifically done a flush but at this point i've replaces the lines once and the pump 3 times so I'm sure the fluid has flushed through. The original pump was not noisy, just these replacements.
-Robert
Old 09-19-2017, 06:59 PM   #7
RobertGary1
1996 SC2
Yea, here's the confirmation from A1 Cardone...
"Vanes and rotor are remanufactured but they need to meet dimensional specifications and after that a visual inspection is perform to void bad components are built in"
Not sure what reman'd means. Do they sand them down to smooth them out?
-Robert
Noisy Fuel Pump (in Extreme Cold) Bismarck318 Vue General 0 02-08-2014 04:31 AM
Noisy Idler Pulley NOT the Power Steering Pump snowman PA S-Series Tech 0 07-23-2012 12:03 PM
noisy water pump? sc2dave S-Series Tech 4 05-24-2007 12:56 PM
Noisy new fuel pump aaronsw2 S-Series Tech 3 02-28-2007 12:24 AM
Noisy fuel pump radioouman L-Series Tech 2 11-23-2006 02:42 PM
