Old 01-09-2019, 04:50 PM   #1
BoSoxJim
BoSoxJim is on a distinguished road
Default 2005 Vue V6 3.5L coolant hose connection help
I had to replace the starter so I disconnected the upper and lower coolant hoses in order to get to it. After finally replacing the starter (a few weeks went by between the removal and replacement of the starter), I am ashamed to admit that I cannot remember which connection was for the upper and lower hoses.
I have attached a picture of where the hoses are supposed to go and was hoping someone could help out a complete idiot. Thanks.
Add to BoSoxJim's Reputation
Rate the quality of this post and help BoSoxJim reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BoSoxJim is offline   Reply With Quote
Old 01-09-2019, 07:32 PM   #2
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
Default Re: 2005 Vue V6 3.5L coolant hose connection help
The Upper Radiator Hose goes to the forward connection - the one closest to the Radiator.
Add to Chazberry's Reputation
Old 01-12-2019, 12:52 PM   #3
BoSoxJim
Thank you very much for your help.
Old 01-16-2019, 04:48 PM   #4
BoSoxJim
Just out of curiosity, what would happen if the connections were reversed?
Old 01-16-2019, 07:28 PM   #5
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
You may not notice any differences as long as radiator fins are clean, water pump is working to specification, cooling fans move sufficient air through radiator (fans typically operate until speed reaches 25 mph or so).
The Honda 3.5 cools slightly different than what I'm used to.
The 3.5 thermostat output hose goes to bottom radiator connection and "cooled" coolant is returned from top of radiator to cylinder heads, to engine block, through water pump and back to thermostat (with constant flow through heater core).
My old GM vehicles circulated coolant reverse of this system. The upper hose was fed by thermostat and connected to top of radiator and bottom radiator hose went to water pump, through the block, then the heads, then back to thermostat.
I don't spend much time on forum but answer private messages (PM email my phone). Include email address if you need pdf extracts. Don't use visitor message - I forget to check those.
Windshield washer hose connection? JohnHupp S-Series Tech 1 08-17-2015 03:03 PM
Coolant connection port CRACK! HELP! Saturn9 L-Series Tech 14 09-29-2014 03:32 PM
Astra oil drops at air hose / engine connection bagonyi Astra General 5 04-29-2013 01:38 AM
coolant leaking at trans line connection fastducky L-Series Tech 1 10-13-2011 02:24 AM
Help Vue 2005 hose AC dacabe Vue General 1 09-11-2010 02:36 AM
