Old 01-09-2019, 06:58 PM   #1
Nancy02
Nancy02 is on a distinguished road
2007 VUE 3.6L
Dizzy 2007 Saturn Vue Door locks keep "locking"
First thing that happened is I couldn't lock my doors with the switches, driver and passenger sides, I can still use the switches to unlock the doors. Then, every once in a while my XM Radio would not work. Yesterday while driving my locks would start "locking themselves". You could hear it. Even when parked and no key in the ignition, it keeps doing it. I tried replacing the fuse that says LOCK/MIRROR, that didn't fix it, although with that fuse out, it does not keep trying to lock itself, unfortunately though, my XM Radio doesn't work with it out either. I pulled out the Relay that says DR LCK and it still did it. (with the fuse in) I also tried unhooking the battery for an hour to "reset the BCM", that didn't work. I can still lock and unlock the doors with the key fob with no issue. Any suggestions? I am currently thinking it is a wire, probably the one where the door opens?
Add to Nancy02's Reputation
Rate the quality of this post and help Nancy02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nancy02 is offline   Reply With Quote
Old 01-09-2019, 11:49 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2007 Saturn Vue Door locks keep "locking"
BCM controls lock and unlock by responding to commands from door switches, keyless entry fob and transmission gear selector.
If lock / unlock function are normal with fob or shifting from PARK IMO one of door lock switches is 90% probable cause.
I'd give a bad wire or internal BCM problem about 5% each.
PM email address if you'd like some procedures to depanel door and test and replace switches.
I don't spend much time on forum but answer private messages (PM email my phone). Include email address if you need pdf extracts. Don't use visitor message - I forget to check those.
far2grumpy is online now   Reply With Quote
Old 01-10-2019, 12:06 AM   #3
Nancy02
2007 VUE 3.6L
Yes, the lock / unlock functions are normal with the fob and shifting from PARK. I sent you a PM, thank you.
Old 01-11-2019, 01:32 PM   #4
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
I had similar door lock issue couple years back while driving. I found the battery in remote leaking. After changing battery it stopped. However mine is 2005 model and no OnStar, my 2 cents.
Add to JefferyC's Reputation
Rate the quality of this post and help JefferyC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JefferyC is offline   Reply With Quote
Old 01-12-2019, 12:09 PM   #5
homerec130
homerec130 is on a distinguished road
2008 VUE 3.6L
Pn my 2006 Vue the locks going funky was one of the signs my sunroof had starting leaking. Water would get into the electrics and the locks would go funky. When it was really bad the alarm system would do what it wanted.
Homer
Paul "Homer" Simpson
15 Ford Fiesta, Gray
06 Vue 3.5L, FWD, Storm Grey (Wife's Ride)
08 Vue 3.6L, FWD, Sunburst Orange - RIP 6T70
Add to homerec130's Reputation
Rate the quality of this post and help homerec130 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
homerec130 is offline   Reply With Quote
Saturn S Series Photo Contest!- April- Car "Selfies" and "Twin Cars"!!! blackbeard S-Series General 18 05-04-2014 11:06 AM
power door locks "possesed?" Jim Waibel Ion Tech 4 11-24-2010 10:23 AM
other tranny locking issue-please grant me knowledge "Oh wise ones" mac99sl2 S-Series Tech 10 01-12-2008 11:57 AM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 10:14 PM
2007 Saturn "Green Line" vehicles to emphasize fuel economy XtremeGrandAm General Saturn Discussion 3 08-05-2005 06:47 AM
