Old 09-03-2009, 01:19 PM   #1
JunkYardSaint
JunkYardSaint is on a distinguished road
Default Remote key: What happens when the battery is dead?
I know this is a stupid question; someone is sure to tell me to just change it - but my problem is that I find no way to open this dang thing though it is surely big enough to fit a small watch battery or something I can't for the life of me see where to put it or how to open this little thing. Aside from that it's getting worn so that the little letters and/or symbols or whatever are getting hard to read or see. I see them for sale on line but how do you get it to work on your specific car or whatever? Maybe my local locksmith can answer my question but while I'm here I figured I may as well ask - if any one knows I'd be much obliged *tips hat
Thanks
Add to JunkYardSaint's Reputation
Rate the quality of this post and help JunkYardSaint reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JunkYardSaint is offline   Reply With Quote
Old 09-03-2009, 02:29 PM   #2
Default Re: Remote key: What happens when the battery is dead?
Not putting the year in your post or profile doesn't help. If the battery dies just replace it or read what follows.
If you have a spare one, use it. They should have a notch to use a coin edge to pry the clam shell covers apart - no screws. Once popped apart remove the push button membrane from the circuit board and use a cotton cue tip with some alcohol to clean all the debris from the board and membrane. Either replace the battery for reuse or buy a new one. Remotes acquire debris over the years and sometimes interfere with the buttons making contact with the circuit board so cleaning it occasionally can restore functions quickly. Replacing the battery and a quick button test near the car will tell you whether the battery or remote has failed. Synchronizing one simply requires pressing the LOCK and UNLOCK button for several seconds until the electric doorlocks cycle; the cycling signifies the bcm receiving, acknowledging the remote, and cycling the doorlocks to tell you that your remote has been synched and is working. Perform the same button pushing with the other remote or press any button to see if it works otherwise synch this remote the same way with the two-button press. Its that simple.
Its a little known secret that OEM remotes will work on almost any Saturn by simply reading the owner's manual on synchronizing these things. if you don't have the owner's manual and need to buy replacements, its still easy to synch the new remotes (OEM replacements only) to your car; follow the instructions that usually accompany them or (use the suggestion above). The remotes aren't the problem (as they only transmit a frequency) as much as the bcm is commanded in a certain way by you to enable it to learn and remember up to four remotes. It doesn't matter if you have one or seven remotes; the moment the bcm is enabled in learning mode, its capable of learning the last four remotes being transmitted, one at a time. This does not require a trip to Saturn for programming when you can DIY. This procedure is only for the regular remote keyless entry systems. The newer, and very expensive to replace, rfid subminiature chip in the key transponder never needing a battery but physical presence to the car to unlock the OEM alarm system may require Saturn or GM intervention. I haven't read up on this yet.
Old 09-03-2009, 05:21 PM   #3
2006 ion2
2007 ION-2 Sedan
sorry fdryer, but you are wrong on at least one point, you cannot program ions for new remotes, you need to go to a dealership, and dealerships often will not program a remote that is not GM bought. I have to say I am impressed with the durability of my remote, it survived me falling on it from 30 ft, followed by a boulder falling on me while being submerged. I bent the heavy duty key ring it was on into a D, but the remote is undamaged.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 09-08-2009, 05:41 PM   #4
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
MOST and I repeat MOST dealers will program your remote at no cost. Take the key ring off and pop the fob open from that end. Remove battery clean contacts and install new battery. It may just work as they do not always need to be programmed after a battery change. The FOB be with you.
Add to SaturnSdn's Reputation
Rate the quality of this post and help SaturnSdn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnSdn is offline   Reply With Quote
Old 03-25-2016, 04:22 AM   #5
johnsonsmith
johnsonsmith is on a distinguished road
My car has been sitting for quite some time and today i tried to unlock the car, but it wouldn't open. I tried opening it with the key in the keyhole and no luck.I call Locksmith coconut creek for my car problem.They visited me at my place and perform their work in about half an hour.
Add to johnsonsmith's Reputation
Rate the quality of this post and help johnsonsmith reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnsonsmith is offline   Reply With Quote
Replacing remote key battery bo130 S-Series General 10 04-15-2017 01:30 PM
Remote Key (Fob) not working after dead battery skyrn Sky Tech 2 09-08-2009 11:49 PM
Car key remote... ARTSA Astra General 12 06-28-2009 11:28 PM
Remote Key acting strange after battery replacement Saturn2000SLTN S-Series Tech 9 04-20-2008 07:38 AM
Remote Key Fobs Arnel S-Series Tech 8 03-28-2004 05:50 PM
