Old 06-01-2013, 08:39 PM   #1
thewayiseeit240
thewayiseeit240 is on a distinguished road
Default Trailer Hitch Help
Maybe someone would kindly point me in the right direction. I've used search and all on how to install a trailer hitch on a 2000 Saturn SL1 but no luck.
I purchased a Draw-Tite 24620, I hope that is the correct model as well.
I have never installed a hitch before, so I could use some guidance. I have lots of tools to support the job as well, unless there is some special tools that I may be unaware of that may be needed. I hope there is a step by step process and pictures to go with it, if not I will try to create my first write up on it.
thank you again.
Add to thewayiseeit240's Reputation
Rate the quality of this post and help thewayiseeit240 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thewayiseeit240 is offline   Reply With Quote
Old 06-01-2013, 08:45 PM   #2
Default Re: Trailer Hitch Help
Google is your friend.
http://www.draw-tite.com/content/dow...ion/N24620.pdf
Add to ssicarman's Reputation
Old 06-03-2013, 09:13 PM   #3
Haybale
Haybale has a spectacular aura aboutHaybale has a spectacular aura aboutHaybale has a spectacular aura about
Haybale's Avatar
I literally just installed my U-haul/curt hitch today. And I didn't take any during pictures.
It says to drill 9/16 hole, I used under a 1/2 inch.
It is pretty easy.
http://www.uhaul.com/pubshandler.ash...Dm5b8KIFTjZ0EQ
my thread
http://www.saturnfans.com/forums/sho...d.php?t=191303
Ryan
97 SL2 Mack Charcoal 5 speed, 238k miles, bought 11/18/15
98 SL2 Pearl White auto, 190k miles, 11/7/15 RIP
S-series Shop Manual: http://www.saturnfans.com/forums/showthread.php?t=177672
Add to Haybale's Reputation
Rate the quality of this post and help Haybale reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Haybale is offline   Reply With Quote
Old 06-04-2013, 07:16 AM   #4
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
You just hold the hitch up to the base of the trunk, mark the holes, and drill them out!
It might be helpful to use a couple of jack stands or floor jacks to hold the hitch up and make sure everything is straight and square before you mark your holes.
This is a pretty simple hitch installation, but you'll see why this setup can only haul 1000 lbs!
Shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 06-05-2013, 10:56 PM   #5
Rodger
Rodger is on a distinguished road
Sir
In the box is there a note on a sheet of paper ( aka instructions ) or sticker label that says to
add a stiffer set of rear springs ?
The Rear Springs that are with Station Wagon's all have the same "Ride Height" as Sedan"s.
Because of the possible heavier loads Station Wagon's may be used for their rear springs have a
stiffer/ stronger ability.
At a pick & pull you may aquire just The Station Wagon Rear Springs and then swap out your Rear
Spring to The Station Wagon Springs on your Rear Struts ( no special tools are needed ). After you
have finished look in the local paper for a Coupon so that you can get a dis-counted alignment.
The supplied Spec's Sheet states you may have a Max Trailer Tongue Weight up to 200 pounds.
Knowing very few user's weigh this part or know how to do this correctly and because of many
other factors such as "close enough guessing" the 200 pound advise is a lower than a true spec's limit.
As you stand back 10 yards and look at your Car and Trailer Loaded it
should all be straight from the very front of the car to the rear of the trailer.
If there is a "V" you have to much weight on The Tongue.
If The Tongue is in any way higher than the rear of The Trailer it will start
"wiggling and wagging" as early as 25 MPH.
Rodger and Gabby
COS
Add to Rodger's Reputation
Rate the quality of this post and help Rodger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rodger is offline   Reply With Quote
A trailer Hitch on a 96 sl2 bskicrash1 S-Series General 0 04-13-2007 09:48 AM
97 sc1 trailer hitch jasbeck Classifieds 1 06-14-2006 04:14 PM
Trailer hitch? raydog S-Series Mods 2 06-01-2006 03:06 AM
Trailer Hitch Ken A Relay General 1 04-09-2005 06:35 PM
Ion Trailer Hitch? LynnF Ion General 2 06-16-2003 08:44 PM
