Old 03-22-2006, 08:06 PM   #1
mrbios
mrbios is a jewel in the roughmrbios is a jewel in the roughmrbios is a jewel in the rough
mrbios's Avatar
Default How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pictures
Updated: 03-21-2006
Make: Saturn SW2
Model: SW2
Year: 1997
Body Style: Station Wagon
Miles: 111,000
Age: 9.5 years, one owner.
Location: Southern California (6 years), previously Northeast “rust belt” for 3 years.
Photos:
http://www.wecandobetter.com/images/...humbnails.html
Repair: Maintenance, How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pictures
Benefits:
Less noise and smoother locking unlocking, longer life on power door locks which wear out as locks get more difficult to move.
Torx screws will be lubed so then won’t rust and seize. If that happens the door is much more time consuming to remove.
Remember, the door needs to be removed: 1.) if a side window breaks, lock is damaged or needs repair, rear door inner metal
panel rusts or rots away; fun, you want to install new or replace broken stereo speakers in the doors.
How to proceed: Assuming the car is 3 years or older and maybe rusty.
NOTES:
On Saturn, unlike most cars, you access the door "guts" power lock motors, lever, windows, etc from the outside by removing
the plastic outer door panels.
Preparation:
purchase 5 or more clips and several push button door handle push-pins from Saturn Dealer and have a drill and bits ready to drill
out a rusted bolt. Cordless drill, White Lithium grease Spray ($3 most auto stores) . Torx T-30 & T-?? bits (I bought a whole set
for $12). Needle nose pliers ($3). Razor cutter or Mat knife (safer). Safety glasses - the pressure of the lithium spray can cause it
to splash back in your eyes! It happened to me but I had my safety glasses on.
Working on one door at a time.
1. Loosen with a hand tool / break the large main bolts free Torx bit size T-30. Why do any other step until you determine that
your Torx bolts aren’t so badly rusted that you need to replace the clips they screw into?
2. Finish removal with cordless drill. This saves a lot of time as you will screw and unscrew almost 30 bolts. Place Torx bit in drill
chuck. Remove all Torx bolts. You don’t need to unscrew any interior screws near the handles, etc.
3. Remove the handle as follows: Lift up handle and stick a pry bar or screwdriver etc to keep handle up. Look to right mount
point and split the plastic push button pin. Pull out center piece with pliers and entire pin will pull out easily. The system works
like a dry-wall screw & plastic anchor.
4. Slide handle to Left about 1/2 inch. If it won't move hit it gently.
5. Lift door panel from bottom upward but don't try to remove yet.
6. Grab rubber strip at the base of the window and lift up / back when things are right it will lift straight off then remove the outer
plastic door panel.
7. Optional - front doors - you could remove the mirrors - I didn’t and save some time.
8. Remove the plastic panels bu lifting from the bottom and working top off . The two pins tend to hang on like a hinge.
9. Pull plastic with one hand and cut the old glue with razor cutter. Remove the top 1/2 of the plastic.
10. LUBE: Now spray Lithium Grease on everything the moves. Move the door lock back and forth and spray, lift what's left of
handle manually, roll window, etc. Spray Lock tumbler, door hinges top, bottom inside, out, etc. Spray all threaded holes with
grease etc. This will speed up reassembly.
11. Reassembly: Spray adhesive spray on plastic - follow the old glue as a guide. Spay on metal but keep can spray nozzle no
more than 1 inch off surface so it doesn't spread. Make sure all screw holes etc line up so black plastic won't interfere with outer
door skin. DON'T SEAL ENTIRE BOTTOM EDGE! Water must be able to drain out when it goes between the window and
rubber strip.
12. Place top of door on first - use the plastic that sticks out towards the top front of door as a guide. Keep door pressed in tight
and lift up from bottom. Place a large Torx bolt in the whole closest to the door lock and screw in. Now place on in the opposite
side. Open and shut the door throughout reassembly to make sure things are lined-up correctly.
13. Put rubber strip on and tap gently down to seat.
14. place black plastic vertical piece on. Turn power to lowest setting on cordless drill. You should be able to hold the drill
chuck from moving with your hand. Now install all Torx screws and tighten up. Test door opens and shuts correctly.
15. Done. Optional, you might want to spray degreaser on the overspray, if any, from the lithium grease, and use glass cleaner on
windows to clean off finger prints.
Add to mrbios's Reputation
Rate the quality of this post and help mrbios reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrbios is offline   Reply With Quote
Old 03-23-2006, 01:28 AM   #2
madpogue
1996 SW2
Default Re: How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pict
Hey, ask Charlie to move this to the How-To section.
Add to madpogue's Reputation
Old 03-24-2006, 04:03 PM   #3
mrbios
mrbios's Avatar
Default Re: How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pictures
thanks, I did'nt know about the How-To section. I actually have a slightly improved version below:
Thanks to this forum I didn't know to get the handles off and when I did I thought why not photo and type
Updated: 03-21-2006,
Admin Please make sticky, feel free to use the pictures and this text as you wish for the forum. It may be reworded and updated and or corrected this way there wont need to be tons of replys of corrections.
Posted: http://www.saturnfans.com/forums/showthread.php?t=73445
Make: Saturn SW2
Model: SW2
Year: 1997
Miles: 111,000
Photos:
Benefits:
Less noise and smoother locking unlocking, longer life on power door locks which wear out as locks get more difficult to move. Torx screws will be lubed so then won’t rust and seize. If that happens the door is much more time consuming to remove. Remember, the door needs to be removed: 1.) if a side window breaks, lock is damaged or needs repair, rear door inner metal panel rusts or rots away; fun, you want to install new or replace broken stereo speakers in the doors.
How to proceed:
On Saturn, unlike most cars, you access the door "guts" power lock motors, lever, windows, etc from the outside by removing the plastic outer door panels.
Preparation:
purchase 5 or more clips and several push button door handle push-pins from Saturn Dealer and have a drill and bits ready to drill out a rusted bolt. Cordless drill, White Lithium grease Spray ($3 most auto stores) . Torx T-30 & T-15 bits (I bought a whole set for $12). Needle nose pliers ($3). Razor cutter or Mat knife (safer). Safety glasses - the pressure of the lithium spray can cause it to splash back in your eyes! It happened to me but I had my safety glasses on.
1. Loosen with a hand tool / break the large main bolts free Torx bit size T-30 and the two smaller ones on the upper gloss black plastic piece T-15. Why do any other step until you determine that your Torx bolts aren’t so badly rusted that you need to replace the clips they screw into?
2. Finish removal with cordless drill. This saves a lot of time as you will screw and unscrew almost 30 bolts. Place Torx bit in drill chuck. Remove all Torx bolts. You don’t need to unscrew any interior screws near the handles, etc.
3. Remove the handle as follows: Lift up handle and stick a pry bar or screwdriver etc to keep handle up. Look to right mount point and split the plastic push button pin. Pull out center piece with pliers and entire pin will pull out easily. The system works like a dry-wall screw & plastic anchor.
6. Grab rubber strip at the base of the window and lift up / back when things are right it will lift straight off then remove the outer plastic door panel.
10. LUBE: Now spray Lithium Grease on everything the moves. Move the door lock back and forth and spray, lift what's left of handle manually, roll window, etc. Spray Lock tumbler, door hinges top, bottom inside, out, etc. Spray all threaded holes with grease etc. This will speed up reassembly.
11. Reassembly: Spray adhesive spray on plastic - follow the old glue as a guide. Spay on metal but keep can spray nozzle no more than 1 inch off surface so it doesn't spread. Make sure all screw holes etc line up so black plastic won't interfere with outer door skin. DON'T SEAL ENTIRE BOTTOM EDGE! Water must be able to drain out when it goes between the window and rubber strip.
12. Place top of door on first - use the plastic that sticks out towards the top front of door as a guide. Keep door pressed in tight and lift up from bottom. Place a large Torx bolt in the whole closest to the door lock and screw in. Now place on in the opposite side. Open and shut the door throughout reassembly to make sure things are lined-up correctly.
14. place black plastic vertical piece on. Turn power to lowest setting on cordless drill. You should be able to hold the drill chuck from moving with your hand. Now install all Torx screws and tighten up. Test door opens and shuts correctly.
15. Done. Optional, you might want to spray degreaser on the overspray, if any, from the lithium grease, and use glass cleaner on windows to clean off finger prints.
Old 03-25-2006, 10:09 PM   #4
Katie
Katie is on a distinguished road
1993 SL2
On the 93 (esp if its old), the strip above the plastic panel that you so easily removed on your car requires a pretty good pry from a flat screw driver to remove. Word of caution. Don't pry against the plastic body panel as you will scratch it badly (Don't look at it wrong either...it will scratch too . Place a peice of leather or a thick piece of cardboard under the screw driver before prying.
Add to Katie's Reputation
Rate the quality of this post and help Katie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Katie is offline   Reply With Quote
Old 03-26-2006, 01:34 PM   #5
mrbios
mrbios's Avatar
Katie,
That's a good tip. A few of mine were kind of difficult to move so I slid them back and forth then lifted. I sprayed them with silcone (the magic spray for plastic and rubber parts).
A former roommate has a 1993 and 3 yrs ago it had 180K on it and the car was losing tons of anti-freeze. He had the head gasket replaced. When I saw him a few months ago he was still driving the car and now it has about 210K on it!
Have you had to replace the alternator? He had to replace his ever 2 or 3 yrs.
Paul
Old 04-25-2006, 06:02 PM   #6
proton777
proton777 is on a distinguished road
This is great. Very helpful, thanks. I have been trying to remove the outer driver door panel to see why my power window (93 SC-2) makes an awful noise as it gets to the bottom when opening.
So, two questions. On item #2, do you have any suggestions on getting to the Torx bolt that is at the bottom right corner of the door? It's the one under the hinge. I've tried everything to get that thing out without success. Now it is in pretty bad shape.
On item #3 about the pins that hold the handle in. When you say to "split the plastic push button", are you actually breaking them? They must be broken in order to be removed, and, thus, replaced?
Thanks in advance
Add to proton777's Reputation
Rate the quality of this post and help proton777 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proton777 is offline   Reply With Quote
Old 06-02-2009, 09:19 PM   #7
mrbios
mrbios's Avatar
Default UpdaHow To Remove Inner Door Panel - Step by Step 1996 and newer SW2 SL2 SL1
Updated: 06-02-2009
Make: Saturn SW2
Model: SW2
Year: 1997
Miles: 132,000
Age: 13 years, one owner.
I just replaced the two front factory upgraded speakers with Rockford-Fosgate P1653 6.5" round speakers.
Don't try to remove the inner door panel without reviewing this excellent youtube video by Richpin:
Saturn SW1 SW2 SL1 SL2 1996 and Newer front passenger side door panel removal
Removing the inner door took about 12 minutes. I was able to replace the factory speaker in an average of about 1.5 hours per speaker in the front. The video does not show reassembly - the most trick part for me was reinstalling the two hooks that open and lock the door. I pushed the metal rod throught and used a screw driver to rotate the plastic holder until it locked on the rod.
Old 04-09-2010, 08:37 AM   #8
wjr
wjr is on a distinguished road
1994 SL1
Thanks for all of your input- it was all very helpful. I second the need for the clips and the push pins for the locks- get them ahead of time.
Add to wjr's Reputation
Rate the quality of this post and help wjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wjr is offline   Reply With Quote
Old 04-10-2010, 04:02 PM   #9
mrbios
mrbios's Avatar
Your're welcome and thanks for the positive feedback.
Paul
Old 06-04-2012, 04:03 AM   #10
MariaLittle
MariaLittle is on a distinguished road
Oh Wow! I never knew they fenced in pool areas and locked them. Do they do this at all the value hotels? The most I've ever had was a wrist band at Stormalong Bay and had to present my room card to get that.
[url=http://www.smyrna-locksmith.com]Smyrna locksmiths[/url]
Add to MariaLittle's Reputation
Rate the quality of this post and help MariaLittle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MariaLittle is offline   Reply With Quote
Old 10-10-2014, 05:14 PM   #11
loubell
loubell is on a distinguished road
pic link dead
Add to loubell's Reputation
Rate the quality of this post and help loubell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
loubell is offline   Reply With Quote
Step-By-Step - 3.5L Throttle Body Coolant Bypass (with pictures) burnout Vue Mods 14 01-21-2010 04:12 PM
Intake Manifold Gasket replacement step-by-step hydromech S-Series Tech 1 12-11-2007 10:31 AM
Can I have a step-by-step for fixing stuttering power locks? saturnkimberly S-Series Tech 5 08-26-2007 12:35 AM
Input shaft nut step-by-step procedure MSgtEgress S-Series Tech 4 09-26-2006 06:36 PM
