Old 07-26-2005, 11:40 AM   #1
Civic&Saturn
Civic&Saturn is on a distinguished road
Civic&Saturn's Avatar
Default Dogbone engine mount questions - 1996 SL2
First of all, yes, I did a search. I got some answers but not a complete picture.
1996 SL2 with 165,000 miles. I replaced the upper torque axis mount in the spring and, as expected, that removed a lot of the vibration. I have the lower transmission mount but have not installed it yet. Since the remaining two "dogbone" style mounts are still the factory originals, I'm thinking of just replacing both of them along with the lower tranny mount.
The first thing I need to know is whether or not the two dogbones are the same part number. And then I might need to know the part numbers, unless the part I found on Saturnparts.com is the correct one: "MOUNT, Saturn, Engine Mount Strut - 1.9L, DOHC" for $77.81 plus shipping.
Next, I don't have an install procedure for the driver side dogbone. I found a passenger side writeup from Wolfman at...
http://www.saturnfans.com/forums/showthread.php?t=31650
...but I could not locate anything for the driver side. I'd need to know the torque specs as well, the way Wolfman supplied them for the passenger side procedure.
Thanks for any and all advice.
Add to Civic&Saturn's Reputation
Rate the quality of this post and help Civic&Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Civic&Saturn is offline   Reply With Quote
Old 07-26-2005, 06:30 PM   #2
Jeremy97sc
Jeremy97sc is on a distinguished road
Jeremy97sc's Avatar
Default Re: Dogbone engine mount questions - 1996 SL2
The driver side dogbone is under the airbox. Remove it and you will see it plain as day.
I must say though, the dogbone mounts rarely are the cause of any vibration, the stocks ones anyway.
Add to Jeremy97sc's Reputation
Rate the quality of this post and help Jeremy97sc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeremy97sc is offline   Reply With Quote
Old 07-26-2005, 08:07 PM   #3
The "dogbone" mounts are really more locating mounts. The upper engine mount and the lower trans mounts hold things up and can cause excessive vibration if they are not good.
Add to ssicarman's Reputation
Old 07-26-2005, 08:29 PM   #4
Civic&Saturn
So do you guys recommend I just install the lower tranny mount and see how things are? The upper torque axis mount has already been replaced.
Old 07-26-2005, 08:51 PM   #5
wolfman
wolfman's Avatar
The "dogbone" mounts only dampen and control torque motion (twisting) of the engine and transaxle in the engine compartment. They are not load bearing and generally do not dampen or amplify engine or transaxle "felt" vibration at all. If you are not getting a notable audible "CLUNK!" when the transaxle is shifted from park to reverse or drive, or under heavy accelration when shifting, the dogbone mounts are probably just fine.
Add to wolfman's Reputation
Old 07-27-2005, 01:30 PM   #6
Civic&Saturn
OK, thanks. I'll just install the lower tranny mount for the time being.
broken transmission dogbone mount siliconvalley S-Series Tech 14 04-04-2009 02:47 PM
Dogbone and trans. mount years? JerryHughes S-Series General 40 02-27-2008 07:25 PM
Transaxle Dogbone Mount Maritime Storm S-Series Tech 6 09-23-2007 08:14 AM
Clicking noise- dogbone mount? Twin_Cam Miscellaneous Tech 14 03-15-2004 11:13 PM
dogbone mount symptoms? jefferson70 S-Series Tech 8 10-18-2003 02:37 PM
