Old 04-28-2014, 03:36 PM   #1
sstar
sstar is just really nicesstar is just really nicesstar is just really nicesstar is just really nicesstar is just really nice
sstar's Avatar
2002 L-Series 2.2L Wagon
Default Center High Mount Brake Light
Is there a special way to remove the plastic covering on the center high mount brake light (LW) without damaging anything?
sstar is offline   Reply With Quote
Old 04-28-2014, 08:17 PM   #2
pierrot
pierrot's Avatar
Default Re: Center High Mount Brake Light
Nothing special here: carefully pull on the outside edges of the cover to separate it from the lamp assembly. It's attached via clips, nothing else. While the clips hold the cover on tightly, it just takes a certain effort (a little "muscle") to remove it. I've removed mine several times without braking it and I'm confident that you can do the same.
346K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. I fear that I will be correct. I'd rather be wrong.
Old 04-29-2014, 01:55 PM   #3
sstar
sstar's Avatar
Thanks pierrot.
'97 SL2, High Mount Center Brake Light Problem Nebraska03 S-Series Tech 5 09-21-2012 12:00 PM
High Mount Center Brake light: PC175 MadPuppy S-Series General 4 02-21-2011 03:26 PM
center high mount brake light question markymarkmark12 L-Series Tech 5 11-03-2008 02:16 AM
Replacing S-Series Center High Mount Stop Light Bulbs dougVA How-To Library 0 01-11-2006 12:10 AM
Center High Mount Stop Lamp (3rd Brake Light) complex problem, please help jordanb69 S-Series Tech 5 07-29-2004 09:35 PM
