Old 02-13-2011, 02:36 AM   #1
MadPuppy
MadPuppy is on a distinguished road
MadPuppy's Avatar
Default High Mount Center Brake light: PC175
What I would like to know is, can you remove the bulb from the yellow base, or do you have to replace the bulb and yellow base as an entire unit?
MadPuppy is offline   Reply With Quote
Old 02-13-2011, 09:29 AM   #2
Default Re: High Mount Center Brake light: PC175
You can remove the bulbs from the base. This thread is about LED conversion, but you will be doing the same thing, just not using LEDs (unless you are asking, because you are converting - you didn't mention that)
http://www.saturnfans.com/forums/sho...ight=brake+led
Old 02-13-2011, 03:36 PM   #3
MadPuppy
MadPuppy's Avatar
Thanks for answering, and yeah I am converting to LED's. but I think I'm just going to buy some 194/168 twist-lock bases to put the LED's in. Cause I still want to use the original bulbs as backups just in case the heat from the sun does one of the LED's in. And for anyone else that reads the thread: the PC175 bulbs do not come out of the bases, you either have to buy new ones from the dealer or follow the instructions in the link above or buy new bases to put your bulbs in (LED or Incandescent).
Old 02-13-2011, 04:12 PM   #4
Buy them here, it is easier and faster. http://www.superbrightleds.com/
Old 02-21-2011, 03:26 PM   #5
MadPuppy
MadPuppy's Avatar
That is actually where I got my 194/168 twist lock bases from. they do fit the 96-99 high brake mount just fine; only difference is that the aftermarket bases have to be twisted a little farther than the OEM bases to lock in.
center high mount brake light question markymarkmark12 L-Series Tech 5 11-03-2008 02:16 AM
Center-high mounted brake light bulb number? ajs_saturn S-Series General 3 01-28-2008 09:11 PM
Center High brake light Aura XR GRP Aura General 1 04-24-2007 04:13 PM
Replacing S-Series Center High Mount Stop Light Bulbs dougVA How-To Library 0 01-11-2006 12:10 AM
Center High Mount Stop Lamp (3rd Brake Light) complex problem, please help jordanb69 S-Series Tech 5 07-29-2004 09:35 PM
