#1 |
![]() Join Date: Jan 2007
2002 L-Series 2.2L Sedan
i posted a few months ago about loose bulbs in the center high mount. now several of the bulbs are burnt out(they're black so i'm guessing this is what that means). someone on the thread about the loose bulbs mentioned something about taking the bulbs out of the bracket and replacing just the bulbs as this was a much MUCH cheaper option. my question is, i found the correct bulbs, but i cannot seem to get the bulbs out of the blue bracket, any help you guys could give me would be greatly appreciated. is there something i'm not doing, i've tried grabbing the bulbs and pulling, and i've tried messing with the little tabs on the sides of the brackets, and i've also tried pushing up through the bottom of the bracket.
2002 L200, black |
#2 |
If they're PC168 bulbs you can buy replacements for lower cost now that they're available in more stores or try this mod; http://www.saturnfans.com/forums/sho...ht=pc168+lamps, post #6.
VCX NANO |
#3 |
![]() ![]() ![]() Join Date: Oct 2001
2001 L-Series 3.0L Wagon
The little tabs on the OEM brackets are spot welded. I just break them off with needle nose plyers before pulling the bulb out.
Jerry N "Politics is the art of looking for trouble, finding it, misdiagnosing it and then misapplying the wrong remedies." Groucho Marx |
#4 |
168 bulb and follow what S3NFO says. The take the new 168 bulb and straighten out the meatal contact wires on the ends and thread through the holder.
#5 |
![]() ![]() ![]() Join Date: Jun 2007
2000 L-Series 3.0L Wagon
OMG this car is easy to work on! 2000 LW2 2016 Impala 1986 GLHS |
#6 |
quick update: after slicing my finger all to heck i got all the little tabs broken off and replaced the bulbs and put them in my car, and stepped on the brakes...nothing. i decided i broke the brackets so i called around to the same autozone where i was told they were 10 dollars a piece last year and was told they no longer carried them. i called o'reillys auto parts and they carried them, for 1.78 per bulb...bracket included. so 6 of them only cost me 10.71.
2002 L200, black |
Bookmarks |
rear high mount brake light | saturnsctwo | S-Series General | 10 | 11-30-2015 06:25 PM |
Center-high mounted brake light bulb number? | ajs_saturn | S-Series General | 3 | 01-28-2008 09:11 PM |
Center High brake light Aura XR | GRP | Aura General | 1 | 04-24-2007 04:13 PM |
Replacing S-Series Center High Mount Stop Light Bulbs | dougVA | How-To Library | 0 | 01-11-2006 12:10 AM |
Center High Mount Stop Lamp (3rd Brake Light) complex problem, please help | jordanb69 | S-Series Tech | 5 | 07-29-2004 09:35 PM |
