Old 08-24-2010, 04:06 PM   #21
Someclown
Someclown is on a distinguished road
Someclown's Avatar
2002 VUE 3.0L
Default Re: A/C only works on low fan speed
[QUOTE=fdryer;1640660]VTVUE, you'll need to clarify your posts. Someone can correct me if I'm wrong but the interior blower fan normally has nothing to do with the a/c system compressor operation
I dont know one quarter of what you do about A/C fdryer, but I do know
when the interior fan resistor card goes bad the A/C button will not activate, except for on high speed which bypasses the resistor card.
My suggestion to all vue owners is remove the resistor card from the interior fan compartment under the passengers side dashboard and coat it with epoxy before the black paint on the resistor card corrodes and releases itself from the aluminum heat sink and ruins your paper thin circuit board also. The circuit board consists of three strips of thin metal and are different thicknesses to act as resistors on the board for the different fan speeds 0.5 ,0.8, and 1.0 ohms I believe it is ( not much on electrical either), very cheap build, instead of using actual resistors
just my thoughts
Add to Someclown's Reputation
Rate the quality of this post and help Someclown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Someclown is offline   Reply With Quote
Old 08-24-2010, 05:39 PM   #22
far2grumpy
far2grumpy's Avatar
Originally Posted by JBR View Post
I replaced the resistor card and this immediately corrected the problem. Thanks to those who helped. Easy fix. 10 minutes.
JBR ... thanks for your post. You done good.
Your effort confirms - once again - there are circuits on fan-speed resistor card which affect AC compressor run.
I'd sure like to find a schematic for that card.
Old 08-25-2010, 10:30 AM   #23
Someclown
Someclown's Avatar
2002 VUE 3.0L
Hey Far2, if you look in your FSM under HVAC- HVAC system manual- schematic and routing- blower controls, you will find the blower controls schematics and resistor card schematics on that diagram. I carefully scraped the paint off my old one to have a peek at it and like I said previously its only different size strips off wire used for resistance. I will try to repair it with more wire as long as I can find the proper sized wire for the proper resistance.
Hope this helps
Old 06-17-2012, 08:44 PM   #24
talonsaab
talonsaab is on a distinguished road
2004 VUE 3.5L
Is the resistor card a dealer only part or is it available aftermarket?
Add to talonsaab's Reputation
Rate the quality of this post and help talonsaab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
talonsaab is offline   Reply With Quote
Old 07-22-2019, 12:41 AM   #25
closecall1994
closecall1994 is on a distinguished road
Not sure if anyone will find this important anymore but I have a 2003 Saturn Vue with the same issue of A/C only working on low setting..Once you change fan speed the a/c light goes out and the warm air begins to blow.....I replaced the blower motor resistor which cost me 21.83 on Amazon and IT FIXED THE PROBLEM.....Trust me..It WORKS...
Add to closecall1994's Reputation
Rate the quality of this post and help closecall1994 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
closecall1994 is offline   Reply With Quote
Old 08-15-2019, 07:17 PM   #26
MacVue
MacVue is on a distinguished road
I find it very important because it happened with our 2003 also. I will order it up and see if it makes a difference. The same problem, hopefully, the same remedy.
Thanks all!
BTW, would you have a link or brand name from that Amazon resistor?
Add to MacVue's Reputation
Rate the quality of this post and help MacVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MacVue is offline   Reply With Quote
Radiator Fan Only Works on High Speed JuniorTT Ion General 7 06-06-2010 11:03 AM
More Six-Speed Automatics Coming as GM Announces Plan to Close 4-Speed Transmission P Charlie General Saturn Discussion 1 05-13-2008 08:49 AM
Any reason to upgrade to the 2.4 w\6 speed over the current 4 speed? Aratech Aura General 5 05-10-2008 04:15 PM
'01 Speed Chip and Speed Boost? (from eBay) Disturbed_One S-Series Mods 46 02-23-2008 01:11 PM
Danger: High speed thread! Top speed on L300V6 and 2.2 -ecotec? 2k3L300HID L-Series General 64 03-10-2005 11:53 PM
