Old 10-31-2019, 08:41 AM   #1
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
Default Automatic Climate Control project
Hey all,
Finally got my Arduino in the mail and can start my climate control project. There is no particular reason why I need to do this, but it will give me more room in the centre console area after I am done.
My goal for this project: Convert the centre console from the 90s era slider climate control to simple buttons and knobs as we see in newer cars.
All code for this project will be on a public repo: https://github.com/jpsulisz/Saturn-Climate-Control
The plan is for the temperature to be controlled via a rotating knob (switchable from basic heat or exact temperature) and where the fan blows controlled via buttons (similar to how Civic's did it in this era). I am not sure if I want to change the fan control from how it is now as the module is already pretty small and some new cars don't have fan control based in their auto climate control.
Knowing that the car runs everything but cables/wires, I have set up a servo to be run by the Arduino adjusting temperature based on the dial. I have a 3D printer servo coming in to ensure the motor I have will be powerful enough to move the wires.
I plan on remodelling the entire climate control cluster and moving the 3 buttons (ABS, Defroster, and Fogs) with it as the radio will be going on the dashboard. This should provide me with enough room to finally fit my 20 oz coffee cup in the winter.
Here are some photos of what I already have, schematics will be added later as Fritzing isn't working on my computer:
'97 Saturn SL2 @ 140k
r/Saturn_Cars moderator
Add to jpsuli's Reputation
Rate the quality of this post and help jpsuli reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpsuli is offline   Reply With Quote
Old 10-31-2019, 10:37 AM   #2
SC2Sick
1997 SC2
1995 SW2
Default Re: Automatic Climate Control project
If you're in MPLS I'd love to stop by and check this out when you've got it sorted.
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
Old 10-31-2019, 06:01 PM   #3
Hiisi
Hiisi is on a distinguished road
Hiisi's Avatar
Seems to be doable. The only concern is how reliable the mechanical part is gonna be. I would add an option to turn off the climate control and have an old-fashion slider hidden somewhere.
Where do you plan to locate the temp sensor?
Add to Hiisi's Reputation
Rate the quality of this post and help Hiisi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiisi is offline   Reply With Quote
Old 10-31-2019, 08:31 PM   #4
jpsuli
jpsuli's Avatar
For sure, I will be here all year!
Definitely a valid concern, though the only new mechanical portions of the project would be the potentiometer and the servo. I am more worried about the potentiometer as these cheap Chinese ones are hit and miss, so I would need to find a better source for that. The servo would be the NEMA 17 which is rated to work below 175F or above 40F, which would mean I am not driving at least. In terms of a sensor, I feel like placing it near the shift knob would be appropriate as it accounts for the upper and lower body, though I have multiple temperature sensors so I could in theory put it in a few places.
Old 10-31-2019, 10:15 PM   #5
98_Gold_Uranus
98_Gold_Uranus's Avatar
This seems like a very cool project! Looking forward to seeing the end result!
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-01-2019, 04:12 PM   #6
Hiisi
Hiisi's Avatar
Somehow it happened that I was thinking of this project during my lunch break. Wanted to propose some time lag to compensate the latency of the temperature changes etc, but now I see in your code this:
Code:
delay(20);
I would suggest some more sophisticated (nonlinear) way to do it. Instead of a simple delay, it might make sense to make a big initial jump if the difference between desired_temp and cabin_temp is *huge*. I.e. when the car is hot during the summer on the parking and you just got in that 20 sec might be torture
Old 11-01-2019, 04:17 PM   #7
Hiisi
Hiisi's Avatar
As for your concerns regarding the potentiometer, I would suggest drop it at all. Neither rotational nor sliders - they do not work normally. Go with encoder. For example:
amazon
Old 11-01-2019, 04:59 PM   #8
jpsuli
jpsuli's Avatar
Code:
delay(20);
Correct me if I am wrong, but is the jump you are referring to this?
Code:
  else if( difference_temp < -15 )//cabin temp is colder than desired
    myservo.write(180);
  else if(difference_temp > 15 )//cabin temp is warmer than desired
    myservo.write(0);
Where if the temperature difference is above 15 from desired it will go to the max of that the servo can handle.
Thanks for the advice on the encoder, completely forgot about them.
Old 11-01-2019, 05:33 PM   #9
Hiisi
Hiisi's Avatar
Code:
    myservo.write(180);
    myservo.write(0);
Correct! Seems I didn't scroll past the 20 sec delay
Old 11-19-2019, 03:27 AM   #10
jpsuli
jpsuli's Avatar
Quick update:
- Have the dimensions for original climate control
- Waiting for the motors to come in, guess they like being stuck in China for some reason
- Since I am saving for a rebuild, the double din radio will be downgraded to my current single din. Kinda lame but I'd rather have a working car than a fancy radio, adjustments are being made to accommodate that
Should see some 3D modelling this weekend provided the motors actually show
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Automatic Climate Control? V8GoneDOHC L-Series Tech 27 04-23-2010 04:12 PM
Automatic Climate Control? Astra La Vista! Astra General 7 10-10-2009 02:00 AM
Automatic Climate Control darnell89 L-Series General 1 02-07-2008 11:59 AM
Automatic Climate Control darnell89 Relay General 3 01-29-2008 04:11 AM
Automatic Climate Control SATURNFAN13185-2 General Saturn Discussion 2 11-27-2001 12:17 AM
