Old 11-05-2019, 11:08 PM   #1
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Question Will a 2005 Ion engine fit in a 2004 Ion?
Im looking at buying a 2005 but it was manufactured in 10/2005 with 125,000 miles on the engine. I was gona swap in my 2004 with 325,000
Would this engine be a direct replacment for my 2004 Ion?
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddemier7 is offline   Reply With Quote
Old 11-06-2019, 02:01 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Will a 2005 Ion engine fit in a 2004 Ion?
That build date of 10/2005 would make it a 2006, but 2005 & 2006 engines are identical so it doesn't change your situation. The long block should be a direct swap. You will just need to reuse the intake manifold, fuel rail & injectors, and throttlebody from your 2004 because 2005-2006 engines are throttle-by-wire engines.
2007 Ion 2 Quad Coupe 5-speed manual 182K miles
2007 Chevy Equinox LT 194K miles
2018 Chrysler Pacifica Touring L 41K miles
Add to ruley73's Reputation
Old 11-06-2019, 10:30 AM   #3
Citation84
Citation84 has a spectacular aura aboutCitation84 has a spectacular aura about
Citation84's Avatar
2005 ION-1 Sedan
What about the five speed automatic transmission ? Won't an adapter or something be needed for the engine to fit unless it's a manual ?
Add to Citation84's Reputation
Rate the quality of this post and help Citation84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Citation84 is offline   Reply With Quote
Old 11-06-2019, 11:36 AM   #4
ruley73
ruley73's Avatar
No, the engines are the same. The transmissions all mount to the engines the same way. That's why it's so easy to do transmission swaps on CVT models.
Old 11-06-2019, 03:06 PM   #5
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
So ots the 03 - 04 that are direct replacment.
Old 11-06-2019, 03:10 PM   #6
ruley73
ruley73's Avatar
Correct, but like I said before, a 2005-2006 engine can be installed if you reuse the 2004 Intake manifold, throttlebody, fuel rail, and injectors.
Old 11-07-2019, 12:17 AM   #7
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy Re: Will a 2005 Ion engine fit in a 2004 Ion?
1) about how many man hours do you think it would take a weekend warrior to swap the motor, transmission and the air intake / throttlebody over and install everthing.
2) Would I need to evac my A/c unit?
3) Is it easier ro bring motor/trannsmission out through the bottom?
4) would I have to have the dealership re-flash any computers with the new engine instalment?
5) what would that red 2005 Saturn Ion be worth at Copart auto auctions? I think no more than $400. Its 3 hours away where I live so I would plan on driving it home not towing . What do you guys think that Saturn is worth for purchase as is?
Old 11-08-2019, 12:40 AM   #8
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Happy Re: Will a 2005 Ion engine fit in a 2004 Ion?
Good news I bought the car for $200 but bad news with fees it went up to $460
Either way im binging it home tomorrow
Old 11-09-2019, 02:35 AM   #9
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Heart Re: Will a 2005 Ion engine fit in a 2004 Ion?
Drove the car home after a 2.5 hr trip and it runs AMAZING. If you look at the 10th digit the car is actually a 2004 model Ion so someone swapped the door out at some point in time
I cant wait to swap this drive train out and not have ro check my oil level frequently due to my rear main seal leak.
Car fax report confirms this is a low milage car with only 129,000 miles. Whoever ownes hardly drove it.
VIN# 1G8AJ54F94Z206801
Old 11-10-2019, 01:25 PM   #10
Citation84
Citation84's Avatar
2005 ION-1 Sedan
Excellent, thanks Ruley. I thought there might be potential connection problems.
Old 11-10-2019, 01:27 PM   #11
Citation84
Citation84's Avatar
2005 ION-1 Sedan
Great you're going for the save instead of scrapping it. So much waste out there.
My 05 still runs and looks like a late model.
Will 2005 2.2 fit in Ion 2004? bdelacruz Ion Tech 2 04-18-2012 10:11 AM
2004 and 2005 SL2 - RWD or FWD? bsc33 S-Series General 5 01-06-2010 11:22 AM
2004 2005 Cvt Troy Vue General 31 12-20-2006 04:38 PM
2004 and 2005 ...are they the same?? Idouoooo Ion General 3 11-02-2005 11:33 AM
May 2004 vs May 2005 Incentives BUBBLEMAN Vue General 11 05-09-2005 02:13 PM
