Old 02-01-2009, 06:15 PM   #1
greensaturn
greensaturn is on a distinguished road
Default 2007 Saturn Vue Automatic Transmission Fluid Change
I have written a how to on changing the transmission fluid on a 3.5 V6 automatic transmission. I tried to post to the how to library but apparently don't have priveleges to do that. If someone else can do this and feels like it they may copy it and post it there. I also have pictures included here too, but don't know how to upload them to the thread. If someone can help there too that'd be cool.
2007 Saturn Vue automatic Transmission Fluid Change
Disclaimer: These are the steps I used to change the automatic transmission fluid on our 2007 Saturn Vue. These same steps may be applicable to other years. However these steps are not all inclusive. There might be a better way. I am not responsible for damage to any vehicle if someone chooses to use these steps and the result is adverse. These are the steps that I used and have had no problems. While I tried to document some detail and pertinent steps that might not otherwise be known, some common sense and mechanical aptitude is required for this.
Vehicle Info: 2007 Saturn Vue 3.5 V6 with 37,615 miles at the time of fluid change. The reason I decided to change the fluid was because we had experienced over the last 10,000 miles or so between 30 and 50 mph the transmission would sort of hunt for the correct gear and would lug down from trying to shift into overdrive.
This task is relatively easy, if you can change oil on your car than you can also change the transmission fluid.
Note: This fluid change was on the Honda Transmission. Z1 transmission fluid was used. I purchased 5 quarts from the local Saturn dealer.
Tools needed are pictured and listed below. Certain common items such as floor jack, oil pan, electrical tape, and paper towels aren’t pictured or listed. But it will state where these items are used in the process.
1. Small hammer – may or may not be needed, I used this to lightly tap the 3/8” driver into the drain plug.
2. Flathead screwdriver
3. 6 inch 3/8” extension
4. 10 mm socket
5. 3/8” driver
6. ˝” 9 inch extension and ˝” 4 inch extension
7. 17 mm socket.
8. 2 ft breaker bar
9. Narrow funnel with 18 inches of 3/8” ID Clear tubing electrical taped to the end.
Step 1. Removal of the air intake tubing. Using the flathead screwdriver loosen the hose clamp holding the intake tubing to the top of the air filter box and the hose clamp holding the intake tubing to the rubber sleeving going to the throttle body. See points below.
Step 2. Remove the bolt holding the intake tubing to the intake manifold using a 10 mm socket. See points below. Once the hose clamps are loosened and the bolt is removed then wiggle the intake tubing to remove it.
Step 3. Loosening the fill plug on the transmission. Locate the transmission fill plug, it is almost directly underneath the back side of the intake tubing just before the tubing bends around to go into the throttle body. Loosen the fill plug with a 17 mm socket connected to both the 4” and 9” extensions and breaker bar. The fill plug was torqued and locktited from factory so I had to give a good snug pull to break it loose. At this point just loosen the plug don’t remove it yet.
Step 4. Loosening and removing the drain plug. Underneath the car on the driver’s side from the front of the car you can see the drain plug for the transmission. It requires a 3/8” driver to loosen it. I had to take a hammer and lightly tap the driver into the drain plug. See the picture below.
Loosen the drain plug; it is also torqued from the factory. I had to apply a bit of force to loosen it. Once it is loose place an oil pan underneath to catch the transmission fluid and remove the 3/8” driver. By hand back out the drain plug and remove it. Take a break and let the transmission drain until it stops.
Step 5. Re-installing the drain plug. The factory drain plug has a magnet on the end of it. When I removed ours it had quite a bit of metal fragments on it. With a clean paper towel wipe of the drain plug so that it is free of any metal fragments or old fluid. Re-install the drain plug and tighten with the 3/8” driver.
Step 6. Remove the oil pan from underneath the car and dump old transmission fluid into a container. I used an old empty 5 quart oil jug, this way I could tell approximately how much transmission fluid came out. When I did this I got just a little bit over 4 quarts. The capacity for this transmission is 4.5 quarts as stated in the owner’s manual. So either there was a little bit left in the transmission that did not come out or it was slightly under filled from the factory.
Step 7. Refilling transmission. To refill the transmission start by removing the fill plug that we loosened earlier. There is a metal washer on the fill plug that will not stay with the fill plug when you go to lift it out. Carefully remove the washer also or it will fall down underneath the car. See picture below.
Step 8. Place the end of the clear tubing attached to the funnel down into the top of the transmission so that the tubing goes in an inch or so. You don’t want this coming out when your adding fluid or it will make a mess.
Step 9. Slowly pour in the first quart of transmission fluid making sure that the fluid is going into the transmission case and not going onto the floor. Then add 3 more quarts. I stopped filling after 4 to check the fluid level.
Step 10. Do an initial check of the dipstick. It can be located just to the left of the battery look down. It has a black handle. Pull it out and wipe it clean with a paper towel. Then re insert and pull back out to check the level. By this point the fluid level should be just touching the very bottom of the dipstick. Reinsert the dipstick. I added another half quart after this and it brought the level to just above the bottom mark on the dipstick.
Step 11. Remove the funnel and re install the fill plug. Go ahead and tighten the fill plug down, you may or may not need to add more fluid later, but the car must be driven around a little to bring the fluid up to operating temperature.
Step 12. Reinstalling the intake tubing. Re install the intake tubing in the reverse order that it was removed. Once this is complete. Take the car for a test drive. I drove for approximately 15 minutes until the coolant temperature was at the normal operating range. Once back another fluid check is needed. Now I’ve always been taught that the fluid on an automatic was supposed to be checked while the engine is running. I tried to do this here but could not get an accurate reading. So with the car warmed up and parked on a level surface I turned off the engine and checked the fluid level. It now registered right at the top mark on the dipstick in the acceptable range.
Summary:
Over the next couple of days do another check or so just to make sure you are not leaking fluid anywhere. I noticed that the transmission shifted slightly smoother than before, it did seem to take care of the “searching for the right gear between 30 and 50 mph” a bit. It isn’t completely smooth like when we bought it new, but it is considerably better.
greensaturn is offline   Reply With Quote
Old 02-08-2010, 10:01 PM   #2
AsbergerCowboy
AsbergerCowboy is on a distinguished road
Default Re: 2007 Saturn Vue automatic transmission fluid change
Just did this and thanks for the detail. The most time consuming aspects for me were locating the fill plug and buying a 12" extension to get to it. The Haynes manual is worthless and Honda Z1 is like butter.. totally solved the "searching for a gear symptom.
AsbergerCowboy is offline   Reply With Quote
Old 04-03-2010, 08:48 AM   #3
dcockrum
dcockrum is on a distinguished road
I just checked ebay for honda z1. For two cases the best price I saw including s/h was $176.
Save a horse, drive a Saturn!
dcockrum is offline   Reply With Quote
Old 04-05-2010, 02:07 AM   #4
Bismarck318
Location: Birthplace of Rust, FKA The Heart of the Rustbelt, AKA The Angry White Planet Ohth
Again, you are all swearing by Honda Brand? (perhps you are correct), what would be bad about Mobil 1 & Valvoline Z1?
Old 04-05-2010, 12:58 PM   #5
mrtube
mrtube is on a distinguished road
I almost want to agree with bismark
I did use Honda Z1. However the fact remains the fluid does indeed burn. Whos to say the fluid is not half the problem?
The worst thing I have seen posted regarding using other fluid is hard shifts.
Fact is, hard shifts suggest clutches slipping LESS. clutches slipping less = LESS HEAT = less burning as well as less wear.
I may try some Mobil 1 fluid my self.
mrtube is offline   Reply With Quote
Old 06-07-2010, 10:37 PM   #6
Chazberry
Chazberry's Avatar
1995 SW2
My drain plug and fluid after 30k mi.
Old 06-07-2010, 10:49 PM   #7
mrtube
You know, I changed my fluid 3 times with the Honda Z1. cleaned the drain plug until it was spotless all 3 times.
I just changed the fluid again 6K miles later just to get a 4th change in. And the plug magnet had crap on it already. Should I not be surprised, or?
Old 06-08-2010, 12:22 AM   #8
Chazberry
Chazberry's Avatar
1995 SW2
My '03 plug didn't have a magnet, but if it did, I wonder what it would have collected by the time I drained this original fluid after 100k mi.?
Old 11-26-2011, 07:48 PM   #9
Bob Vue
Bob Vue is on a distinguished road
Default Re: 2007 Saturn Vue Automatic Transmission Fluid Change
Just dropped 4.5 quarts today on my 2007 Vue, the step by step instructions are spot on!
Bob Vue is offline   Reply With Quote
Old 12-31-2012, 02:04 AM   #10
dietz4ibanez
dietz4ibanez is on a distinguished road
This write up helped me out a ton. Though my 2006 Vue does not have a Transmission dipstick I drained about 4 qts and added about 4.5.
I did not remove the intake tube as I had extensions long enough to reach the 17mm nut on top.
The metal on the magnet was equivalent to that of a vehicle where the fluids were changed at 30k miles, though I fear that this was the first time it was maintained. My view has 128k miles on it.
dietz4ibanez is offline   Reply With Quote
Old 05-16-2018, 06:32 PM   #11
xzn2p3
xzn2p3 is on a distinguished road
I have a 2006 with the 3.5. Do the transmissions require a filter change as well or just fluid.
xzn2p3 is offline   Reply With Quote
Old 05-29-2018, 05:25 PM   #12
Chiliking
Chiliking is on a distinguished road
Hello, I don’t know if folks are still following this thread, but: I’m wondering which kind of fluid to buy and whether this is a CVT tranny or not? Originally the fluid recommended was the Honda Z-1, but they don’t make it anymore. DW-1 is supposed to be the replacement, but it also states on the Honda brand oil (and all others) that it’s not to be used in CVT transmissions. So I’m confused. I appreciate your help and guidance....
Chiliking is offline   Reply With Quote
Old 05-30-2018, 05:00 PM   #13
xzn2p3
I just had mine serviced at a Honda dealer, they used DW-1. Mine has the 5-Speed with the 3.5L.
Old 11-04-2018, 09:31 PM   #14
Arkadiusz
Arkadiusz is on a distinguished road
4. 10 mm socket
5. 3/8” driver
7. 17 mm socket.
8. 2 ft breaker bar
Summary:
Sorry but this is not the correct drain and fill procedure for 100k. you are supposed to do a drain and fill 3x . drain old out . refill with new, drive a few miles to bring up to heat then drain , repeat this 2x and fill 3rd time to specs
This way you get a lot more of the old fluid out . yes 13.5 quarts total Valvoline Z7 synthetic fluid . Then every 40k i just do a simple 1x drain and fill till 200k then repeat
Arkadiusz is offline   Reply With Quote
VUE 3.5L Automatic Transmission Fluid Change David Harleyson How-To Library 54 08-03-2019 03:05 PM
2007 Ion3 4 speed Automatic Trans Fluid Change tobefree Ion Tech 1 04-07-2010 11:04 PM
How to change the automatic transmission fluid? atikovi Ion Tech 5 07-23-2006 11:49 PM
LS1 Automatic Transmission Fluid Change Info 1995-SL1 L-Series Tech 6 10-17-2005 12:38 PM
LS-1 Automatic Transmission Fluid Change 1995-SL1 L-Series General 8 09-23-2005 05:25 PM
