Old 09-11-2020, 09:48 PM   #1
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Default Flaky Rotor
Wondering if anyone else has seen this before (I hadn't). Less than two years on current brake job, noticed stopping power had fallen off. Checked one wheel, noticed good amount of pad left - probably 15-20k and was going to call it quits.
Pulled off passenger side wheel and felt some irregularities on the inner portion of rotor (see pic). Pulled it off and was amazed to see that 50%+ of surface of rotor was gone, appearing to be in process of flaking off.
Think they were Duralast/Autozone rotors with NAPA ceramics this time around. Glad I had set of nice e-coated Wagner rotors and old school semi-metallic Wagner pads sitting on shelf. Lousy stopping power compared to ceramics, but much easier on the rotors.
With 350,000 I always say "this is the last time I'm ever going to have to replace this part..." and probably cheaped out with the Autozone/Napa parts I used. Lesson learned.
MiSaturn is offline   Reply With Quote
Old 09-11-2020, 10:11 PM   #2
Default Re: Flaky Rotor
What did the pad look like?
Old 09-11-2020, 11:57 PM   #3
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Been there, done that, got the T shirt.
http://www.saturnfans.com/forums/sho...&postcount=363
I think some parts are just crap. Too much china.
Old 09-12-2020, 09:46 AM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
I always expect rotors to last one (1) winter driving season and need replacing in the summer, when working on cars is pleasant.
Old 09-12-2020, 10:02 AM   #5
I average about 50,000 miles on a set of pads and rotors. Except that one in the picture above.
Old 09-12-2020, 10:47 AM   #6
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
It is called "rust jacking"
Go to Raybestos website, there is a video about what causes it.
https://www.brakepartsinc.com/raybes...to-videos.html
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 09-12-2020, 11:01 AM   #7
454cid
The rotors that I took off my car looked like that, but the car had been sitting a year so I didn't think too much of it.
I hope the rotors on my truck don't do that.... those are a major pain to swap. The unit bearings have to come off and all the studs.
1999 Chevy K3500
Old 09-12-2020, 04:56 PM   #8
MiSaturn
2002 SL
1993 SL2
Amazingly normal. Might have been some additional wear due to the rough surface, but otherwise no defect on the pad side to speak of.
It looks like the metal started to delaminate, prob due to plain old garbage metallurgy... . Would agree that I've seen more issues with Chinese rotors than ones from Mexico (Brembo) and Japan (whoever makes OE for Subaru). Can't recall last time I found American made ones.
Old 09-13-2020, 11:34 AM   #9
PrestonIII
1994 SL2
1994 SL2
If a rotor only wears on ONE side, the problem is usually a caliper slide that is sticking or stuck.
When this happens, the caliper applies force to the pads when the brakes are applied, but when it's released, one side can't back off the rotor because it's held in place by the slide not releasing. So, one pad wears away while the other looks "normal".
Unfortunately, this seems to be common on Saturn's because of the way the slide is designed, with the pin inside a rubber bushing through the caliper bracket. This design is fairly unique to Saturn. Most other GM cars eliminate the rubber part completely with the pin sliding directly in the bracket (then rust becomes a problem when the seals fail).
Some not-so-knowledgeable mechanics grease the slide with petroleum based grease. This grease causes the rubber bushing to swell up and thus restrict motion of the pin through it, often locking the slide in place. Thus just one pad wears out, and eats the rotor. Always use non-petroleum based grease on brake parts. Lithium is a good substitute.
You can verify a stuck/sticking slide by how tight the slide pin (caliper bolt) comes out when you're wrenching on it trying to remove it. If it's too tight for your wrench to spin easily, then it's definitely too tight to allow the caliper to relax away from the rotor. Replace the rubber bushings (caliper hardware kit). They're an S.O.B. to replace, and they're often overlooked!
If BOTH sides of the rotor wear out, it's likely a frozen caliper, or the owner simply drove the car too long on worn out brake pads.
Preston
Old 09-13-2020, 12:13 PM   #10
00_SL1
00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough
00_SL1's Avatar
2001 SL2
I just replaced two flaky rotors last night. These rotors were new in 2016, and have just around 25,000 miles on them. This Saturn lives outside 24/7, and is a daily driver, and I don't always get a driveway spot to park on so it sits on grass the majority of the time.
01 SL2
04 Silverado
06 Uplander
05 Express
00_SL1 is offline   Reply With Quote
Old 09-13-2020, 12:19 PM   #11
Oddly, I had this problem even though we had replaced the guide pins and bushings, used sylglide, and put it back together correctly. I'm sticking with my theory of crap chinese parts.
I'm not sold on rust jacking either - the inside doesn't get air to dry off? Seems like plenty of air, CF, and heat to dry the rotors.
Crap parts! We need to bring manufacturing back onshore.
Old 09-13-2020, 12:30 PM   #12
00_SL1
00_SL1's Avatar
2001 SL2
Surprisingly the pad wear was pretty even inside to outside. The right side was slightly better than the left side. Didn't get a very good pic of the left, but you can see the right side well enough. The caliper slide bolts have a ton of rust as well, and the right side was hardly sliding at all. It's going to be good to have all of this replaced before winter hits.
01 SL2
04 Silverado
06 Uplander
05 Express
Old 09-17-2020, 02:47 AM   #13
TomM96
I Do think the ceramic pads are too harsh/abrasive.
Good semi-metallic is more like it....
The fotos do suggest either the alloy material (cast iron) is off, or , more likely,
the heat treatment was unsatisfactory.
Years ago, heat treating was somewhat challenging, as sensors/instruments were expensive (now cheap).
I would not be surprised that the Chinese are using cast alloys with very high scrap content... that might well become an active corrosion cell when contacted with salty water. The heat would also activate the corrosive reaction ... which might proceed constantly thereafter.
Normal cast iron is not subject to much/fast corrosion, generally.
Old 09-17-2020, 09:20 AM   #14
Another vote for crap parts!
Old 09-17-2020, 09:34 AM   #15
craftsman70
craftsman70 will become famous soon enough
2000 SL1
1998 VUE 3.5L
I also have to replace rotors at least every 3 years living in the rust belt. I usually don't see the flaking but have on one or two occasions. I really think that flaking is poor quality rotors. I've been buying coated centric and or raybestos rotors which are a little better but as I said, still end up replacing pads and rotors every few years. Seems like the rotors rust out long before the pads are worn out.
craftsman70 is offline   Reply With Quote
Flaky steering kdhunter S-Series Tech 10 10-04-2013 03:08 PM
Flaky Bumpers IONfan2 S-Series General 5 11-03-2008 12:57 PM
Flaky Cruise Control bigseacow S-Series Tech 12 08-21-2008 02:24 AM
Flaky Sunroof Operation ChiliPepperSC2 S-Series Tech 0 10-15-2007 08:11 PM
Flaky Turn Signal/DRL bryceb04 Ion General 0 02-15-2007 09:08 PM
