Old 12-09-2016, 01:15 PM   #1
Packard
Packard is on a distinguished road
1995
Default removing c-clip or e-clip from brake shoe
On my Saturn 95 sl1 replacing the brake shoes. Hard part is removing and replacing the clip that retains shoes to lever. Tried screwdriver but could not get it it out without damaging it . Its a stubborn clip there are no wholes for a snap ring pliers.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 12-09-2016, 01:36 PM   #2
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
Default Re: removing c-clip or e-clip from brake shoe
I usually take a large flat blade screwdriver, put it against the ends of the "C" (It needs to be against both parts of the "C") and ten tap it with a hammer. It will push the clip out and spread the "C" apart a little as it pushes out.
Add to waiter21's Reputation
Old 12-09-2016, 01:55 PM   #3
trottida
trottida's Avatar
I understand that the C washer is considered a non-reusable part and are expendable since you're replacing anyways. waiter21's method works.
You're referring to the yellow highlighted clips in this photo?
Current rides
:canada:
Add to trottida's Reputation
Old 12-10-2016, 12:24 AM   #4
^+1
If it's time to replace the shoes, it's time to replace the hardware. When replacing hardware...it doesn't matter how it comes out as long as it doesn't ruin how the new stuff goes in and you don't destroy everything before memorizing how it goes back together
I usually put the shoe in my vice and screwdriver/hammer that stupid thing out but a pair of vice grips or other larger sized wideish pliers should work just as well (depending on grip strength).
Old 12-10-2016, 12:20 PM   #5
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Take lots of photos before disassembly!
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Free E-brake button and vent clip awilson506 S-Series Tech 0 10-07-2013 08:09 PM
shift linkage clip/retainer clip? Need to find one. electricbluevue S-Series General 5 11-13-2010 10:30 PM
Question about the parking brake c clip turbobuick33 S-Series Tech 3 12-25-2008 08:59 PM
removing c-clip or e-clip from brake shoe green S-Series Tech 2 12-23-2006 03:19 PM
Special tool for parking brake clip? coleman S-Series Tech 14 04-04-2006 12:53 AM
