Old 09-06-2019, 05:21 PM   #1
123olfashiongay
123olfashiongay is on a distinguished road
1996 SL2
2001 SC1
Dizzy Stolen 96 sl2 cut wiring under steering column
Iím completely ignorant when it comes to cars, especially electrical. Once I recovered my stolen sl2 (for the second time) I noticed they had cut wiring under the steering column. My turn signal/hazards donít work, but my tail lights, head lights, and brakes do. Not sure if Iím missing anything or just need to solder and put the wiring back together.
Add to 123olfashiongay's Reputation
Rate the quality of this post and help 123olfashiongay reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
123olfashiongay is offline   Reply With Quote
Old 09-06-2019, 05:30 PM   #2
onlinebiker
Default Re: Stolen 96 sl2 cut wiring under steering column
What kind of jungle do you live in that a Saturn gets lifted TWICE?
I have 9 running cars. (One Chrysler 8 Saturns)
I leave the keys in the ignition of ALL of them - 24/7/365.
Never had a problem.
My theory - anyone crazy (or desperate) enough to risk prison by stealing a Saturn - is somebody I want to avoid at all costs. I would hate to have to shoot some maniac over a $1000 car.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-06-2019, 06:57 PM   #3
toggenburg
toggenburg's Avatar
Maybe the thief just loosened or removed the flasher/turn signal module?
I only see that beige wire cut, but the 2 ends don't look close enough to each other unless there is some slack not showing.
Old 09-06-2019, 08:05 PM   #4
Waiex191
Waiex191's Avatar
Needs a manual transmission!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 09-08-2019, 12:37 PM   #5
macbox
macbox will become famous soon enough
macbox's Avatar
1997 SC2
If itís just one or two wires you should be able to color match and solder them together and wrap with electrical tape. I see two yellow wires that could go together, but I also see a third yellow wire and the picture isnít clear, so make sure to match them them up and test your lights before you solder them. Consider a kill switch or moving to a safer neighborhood.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 09-08-2019, 06:09 PM   #6
Be careful with the yellow wires, GM decided it was a good idea to have yellow be battery power as well as a rear speaker wire and only make them different by size.
Old 09-08-2019, 07:58 PM   #7
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Best anti theft device ever
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
Old 09-08-2019, 10:06 PM   #8
^ At least one theft in recent years didn't result in the car adding to stolen statistics. No sooner than the thieves broke into the **********(put your favorite car with a manual here) they discovered they can't drive a manual. They abandoned the car.......
Old 09-09-2019, 03:16 PM   #9
Saturn Night
She lives in California. They still swipe everything that ain't nailed down in CA because cost-of-living is so high and most are on assistance.
33% of ALL welfare recipients, across the country, live in CA.
Old 09-09-2019, 03:18 PM   #10
Saturn Night
If you purchase a Haynes manual, it will have the wiring diagram which should help you.
As a general rule of thumb, matching the wiring ends with the same colors is a safe way to repair the cut wires.
Old 09-09-2019, 03:52 PM   #11
Same color and same size and the Haynes diagram is useless.
Old 09-10-2019, 07:15 AM   #12
onlinebiker
It is most assuredly not useless.
It is a great tool.
For cardiac diagnosis. If trying to use the Haynes manual doesn't jack up your blood pressure and heart rate - nothing will.....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-10-2019, 08:19 AM   #13
Long edge bound toilet paper.
Steering wheel and steering column problems. HELP!! nhsbaseball24 S-Series Tech 4 04-13-2013 09:42 PM
steering intermediate shaft to steering column bolt flymanansh Aura General 4 02-07-2012 04:40 PM
Steering column spitfire24 S-Series Tech 3 11-29-2008 01:46 AM
rubbing noise steering wheel/steering column on 04 Vue ynotps Vue General 6 03-03-2005 08:59 PM
getting into steering column... psybapunk S-Series Tech 10 08-10-2003 12:24 AM
