Old 09-06-2019, 06:43 PM   #1
98_Gold_Uranus
98_Gold_Uranus's Avatar
Default Noise coming from under dash
98 SL2
Not sure how long this has been going on to be honest, but today I noticed a very strange noise coming from under the passenger side of the dash, just behind the glove box area. Couldn't really think of how to describe it, so I figured I'd shoot a video lol.
Any one want to throw any idea's out?
https://www.youtube.com/watch?v=D04PYvDlgxw
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-06-2019, 06:53 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Noise coming from under dash
Sounds like a blend door movement, rather than the blower itself.
I don't think they can be lubricated, just replaced.
toggenburg is online now   Reply With Quote
Old 09-06-2019, 06:58 PM   #3
98_Gold_Uranus
Well I did just happen to stumble on this:
http://www.saturnfans.com/forums/sho...culation+motor
Describes exactly what I'm hearing pretty much.
Gives me something to look at.
Apparently there's a rebuild kit for it, guess this gear is common to fail in the recirculation door motor.
https://blenddoor.com/product/gm-ble...r-rebuild-kit/
Looks like a job for my 3D printer and some ABS plastic
Old 09-06-2019, 07:48 PM   #4
98_Gold_Uranus
Quick trip outside to pull the motor (boy that's in a tight spot...). Came inside and popped it open. Sure enough, split gear.
I've got a replacement printing right now
Old 09-07-2019, 12:13 AM   #5
98_Gold_Uranus
Aaaaand, rebuilt
Will throw it back in tomorrow and see if that fixed it.
Can't that it came without issues. The first print looked like hot garbage... Turns out one of my drive belts that moves the printer on one of it's axis's was STUPID loose... a quick adjustment and then 20 minutes later and all was well lol.
THIS is what a terrible 3D print looks like...
Old 09-07-2019, 05:26 AM   #6
BB99SL2
BB99SL2 is on a distinguished road
After watching your video of the noise coming from under dash, my car does exactly the same thing. The noise repeats itself every 15 seconds. I checked that website you posted and wanted to know which plastic gear did you buy? I believe they list 2 different ones, plus a billet aluminum one. Is there a part number? Thanks..
Bernie
Add to BB99SL2's Reputation
Rate the quality of this post and help BB99SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BB99SL2 is offline   Reply With Quote
Old 09-07-2019, 07:07 AM   #7
trottida
trottida's Avatar
Bernie
He didn't buy one, he used a 3D printer and printed one. I believe the design is out there on the web for anyone to download and use a 3D printer to manufacture on your own (or a friend). You'd have to know which material was used in the 3D printer to make sure it is correct for the application.
2012 Ford Focus SEL MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 09-07-2019, 08:39 PM   #8
98_Gold_Uranus
You are correct sir. I 3D printed it with ABS plastic and a solid infill (I mention that because most things you 3D print are nearly hollow at about 20-50% infill since it takes so much plastic to completely fill up a part; this gear is so small, plus it's a load bearing functional part, figured the solid 100% infill would make it stronger as well).
Installed the motor today and all seems well Works great, and it was definitely the source of the sound I was hearing, as it's completely gone now.
This is the file that I found on Thingiverse
https://www.thingiverse.com/thing:3070815
Says it was designed for a Mercedes, but the motor and gear looked identical in the picture, so I took a shot at it, and low and behold it is the exact same gear Even the same gear and motor assembly that's in my 2004 Blazer, that I've replaced the motor in once already for the same problem lol but that was before I had my 3D printer. I printed a second one and put it in my spare parts stash for when the onc in the Blazer inevitably goes out again
I pulled the blower motor off while I was in the area so that I could clean out the evap housing some, and I cycled the recirculation on and off a few times. After observing how the mechanism functions with the door flipping sides as the recirculation is turned on and off, I can see why the noise happens with the failed gear. Whenever recirculation is turned on or off, the motor runs and turns the gears and cycles the mechanism one way or the other. There's a physical stopped that's built into the assembly that stops the final drive gear and output from rotating a full 360 degree turn. The problem is, the motor doesn't actually shut off once it hits that stopped... The stopped stops the rotation, and the motor continues to push against the gearing. So once the gear snaps and looses it's grip on the metal shaft, the gear is free to spin around it. On every rotation, the gear hits a spot where it snags the metal shaft a little, which is what causes the noise to reoccur every 15-20 seconds. Because of the gearing, it's a very SLOW rotation on the final drive gear, that's why there's such a delay in the reoccurring sound. I've noticed that some of the motor assemblies that look nearly identical have an extra 3 pins on the plug and have a blue gear that's attached to a potentiometer in the unit that actually relays it's position back to some on-board computer system that controls the HVAC. I can only assume that with that position information that it actually stops power to the unit and keeps the motor from applying a constant force. Which you would think would prolong the gears life, but apparently not so much, as that link to the gear on Thingiverse, you'll notice that the Mercedes motor assembly has that extra gear, potentiometer, and 3 extra pins for the plug, and apparently it suffers the same fate if people are having to repair them too lol.
Old 09-09-2019, 12:11 PM   #9
Bernie
GM part number in this thread
http://www.saturnfans.com/forums/sho...d.php?t=201722
Since 98_Gold_Uranus put up a link to a Thingverse file, you can find a local school, library, etc.,, that will print these for a small fee.
$1.60 when I did similar, few years ago
http://www.saturnfans.com/forums/sho...d.php?t=223010
Funny about the Mercedes parts in Saturns
http://www.saturnfans.com/forums/sho...8&postcount=13
Old 09-09-2019, 01:03 PM   #10
Waiex191
Waiex191's Avatar
Could be a cover-up. Maybe it is a Saturn part in a Mercedes.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Tapping noise coming from dash by windshield Humy Aura General 1 06-05-2014 11:25 AM
Stopping dash vibration/noise (and removing the top of the dash) PlasticCarsRock S-Series Tech 16 05-19-2010 12:13 AM
Smoke coming from under dash - please help Danc922 S-Series Tech 4 07-21-2009 08:16 AM
Dash pad coming up. silverblueL200 L-Series General 0 09-29-2004 09:38 PM
93 SL2-Dash coming apart Laura01SC2 S-Series General 2 08-23-2000 10:22 PM
