Old 12-21-2005, 11:42 AM   #1
AbbyNN8
AbbyNN8 is on a distinguished road
2003 ION-3 Sedan
Happy '03 Ion and cold weather
Hello, I just got my '03 Ion and want it to last as long as it possibly can. Any tips to keep it running its best??? (Especially things dealing with winter and cold weather right now) Thanks!
Add to AbbyNN8's Reputation
Rate the quality of this post and help AbbyNN8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AbbyNN8 is offline   Reply With Quote
Old 12-21-2005, 11:44 AM   #2
AbbyNN8
2003 ION-3 Sedan
Default Re: '03 Ion and cold weather
o, 1 other thing... I have a weird hum coming from the back of the car... I think the battery because it will stop every so often and then after I open my car door... this happens especially when it is cold. Is this normal? I'm sure it is and I'm just over-reacting, but I would rather be safe then sorry.
Old 12-21-2005, 01:33 PM   #3
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
The hum could be the fuel pump priming. You should hear it too when you turn the key to ON/RUN/whatever it's called on the ION (the position just before START).
As for winter care, frequent car washes (with an under-carriage flush) would be a good idea if they salt as heavily in Ohio as they do in Michigan. Even though the body panels are all polymer, the under-carriage and other components are steel and can rust if that nasty salt is left unabated. Other things to do, are to use the proper weight oil for your engine in the cold months (5W30 probably, some people change to a thicker oil in the summer) and let the car run for a minute or two from a cold start, don't start driving right away (let the oil lubricate things first before putting the spurs to it).
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline   Reply With Quote
Old 12-21-2005, 02:30 PM   #4
PlumSL1
PlumSL1 is on a distinguished road
PlumSL1's Avatar
If your car sleeps outside use gas antifreeze at every fill up. It sucks when your car wont start because of frozen gas lines.
NicK
08 Mazda3
00 Tiburon SE - Sold
96 SL2 - Sold
97 SC2 - Sold
94 SL1 - Driven till death R.I.P
Add to PlumSL1's Reputation
Rate the quality of this post and help PlumSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PlumSL1 is offline   Reply With Quote
Funny Ion in cold weather bdball Ion General 13 02-21-2008 12:44 AM
2004 ION Cold Weather Issue (no start) ajpdla Ion General 43 12-30-2007 02:43 PM
Ion Over-Revving in Cold Weather gregoryblock Ion Tech 25 12-13-2007 08:10 PM
ION 3 works well in cold weather scion Ion General 1 01-10-2004 01:36 AM
