Old 11-26-2007, 09:35 PM   #1
Outofideas
Outofideas is on a distinguished road
2001 L-Series 2.2L Sedan
Default L200 brake noise
Hi, this is my first post here. I have searched and not found anything related to the noise I'm getting.
We have a 2001 ls200 and since bought used, it has had a recurring rotational brake noise. We bought the car and heard a rubbing noise from the brakes when applied. The dealer "took care" of the problem by claiming to resurface the brake drums and rotors and new brake pads. Afterwards the problems continued including getting a low brake pedal due to a spring that would keep coming off the left rear brake shoe e-brake adjuster. Even new hardware, wheel cylinders and shoes would do the same after driven a few days. We now have that problem fixed but the noise is still there.
I work in a dealer service dept (not Saturn or GM) and my techs have done several things to try to get the noise gone to no avail. It sounds like a pad or shoe scrubbing a rotor or drum but they say it all looks o.k. If the place we bought it from did all they said (not where I work) then there should be no issue with the rotors/drums although I think resurfacing again or replacing may eliminate one more thing in my quest for quiet brakes.
Has anyone run into something similar like this before? Otherwise the car is great.
Add to Outofideas's Reputation
Rate the quality of this post and help Outofideas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Outofideas is offline   Reply With Quote
Old 11-26-2007, 10:15 PM   #2
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
Default Re: L200 brake noise
check the pistons on your brake calipers and see if they are hanging up or they are damaged.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Add to Robman's Reputation
Rate the quality of this post and help Robman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robman is offline   Reply With Quote
Old 11-30-2007, 06:58 PM   #3
Outofideas
Well the noise is now gone. Had to machine the rear drums, the left rear was very out of round and had a slight lip on the outside edge, even though it never vibrated or felt a shake.
Rear Brake noise after brake job kim_lombard S-Series General 5 04-22-2007 10:40 PM
L200 brake job unkle bik L-Series Tech 2 06-21-2006 10:45 PM
2001 L200 brake noise gbalbach L-Series General 0 11-06-2005 03:05 PM
L200 brake job unkle bik L-Series General 14 04-07-2005 09:50 PM
L200 Parking Brake AZguy L-Series General 10 12-13-2002 06:43 PM
