Old 06-07-2007, 01:45 PM   #1
hydromech
hydromech is on a distinguished road
hydromech's Avatar
Default Code p0507 in warm weather
Another warm day in Chicago.
Again I’m getting p0507 (Idle Control System RPM High). It only happens on really warm days.
My RPM looks normal – about 700 in “D”.
What is it – bad Idle Control Motor ? Old antifreeze ? Coolant Temp. Sensor ?
Anybody, please advise....
2000 Saturn SL1, SOHC, Automatic, 189K
Add to hydromech's Reputation
Rate the quality of this post and help hydromech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hydromech is offline   Reply With Quote
Old 06-07-2007, 04:22 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Code p0507 in warm weather
Try cleaning your throttle body.
Add to BarnOwl's Reputation
Old 06-07-2007, 06:25 PM   #3
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: Code p0507 in warm weather
Or just be hearder on the gas I dont even know if that will work..
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-08-2007, 04:13 AM   #4
hydromech
hydromech's Avatar
Thanks for reply
I did clean Throttle Plate also I removed and cleaned the IAC motor (was very dirty). That improved thinks a little.
Still have rough idle in "D"when hot and also I noticed "puff-puff" sound from exaust pipe. Is that a misfire ?
Air filter is clean, spark plugs are 1 year old, gas milage is OK - 31 MPG....
Old 06-08-2007, 10:06 AM   #5
BarnOwl
BarnOwl's Avatar
Improved things...Does that mean it fixed your high idle problem and now you just have a rough idle? If so, it could be just about anything. ECTS if it hasn't been done, is a prime candidate. Sticking EGR maybe...plugs, wires, dirty coil towers and/or corroded back on the DIS module.
Old 06-08-2007, 11:39 AM   #6
hydromech
hydromech's Avatar
I recently replaced TPS sensor – that fixed intermittent high idle problem : RPM used to jump up to 1800-2000 till I restart the engine…
Now Idle is smooth when cold. As the engine warms up it runs rough – I can see it on tachometer…
I did not yet replace ECTS. I did removed and cleaned EGR valve (also replaced the gasket).
I also checked resistance for each ignition wire – 2500..3000 Om… I pulled the boots and checked sparks to grounded surface - look strong...
“…corroded back on the DIS module…” – I’ll take that off today and check. Do I have to apply any grease to the bottom ?
P0301 and P0507 boojunji S-Series Tech 11 06-27-2009 12:10 AM
I just got a P0507 Frankd1 S-Series Tech 11 06-05-2009 10:16 AM
P0507 theamcaddict S-Series Tech 11 03-17-2009 11:40 PM
New Saturn: OBD Code P0507 ?? TIMSPEED S-Series Tech 6 02-27-2009 11:36 AM
Code p0135, p0303, P0507 Fortigan S-Series General 9 02-22-2006 02:31 PM
