Old 02-23-2009, 07:01 PM   #1
chuzz
chuzz is on a distinguished road
Default Testing column switch
This is for any of you Saturn techs. Is there any way to run a continuity test on the switch in the column of an Ion? This is a known problem according to the techs, with cold weather starting problems. A friend of mine just got hers replaced to the tune of $267.00. The part # is 10392423. I think part of the problem may be that it's made in Mexico. The service manager told me the way they test them at the dealership is to put them in a freezer for a couple of hours and then re-install them and try to start the car. If it doesn't start, they consider it bad and replace it. Seems like a half-assed way to do something to me.
Add to chuzz's Reputation
Rate the quality of this post and help chuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chuzz is offline   Reply With Quote
Old 02-23-2009, 09:30 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Testing column switch
since when is it half-assed to recreate the fault? that's exactly what you should do.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 02-24-2009, 10:44 AM   #3
chuzz
Dude, I just want to know if there's any way to run a continuity test on the switch. I'm guessing from your reply that you don't know either.
Old 02-24-2009, 12:07 PM   #4
2006 ion2
2007 ION-2 Sedan
disassemble it, degrease it, and regrease it, or to trouble shoot it, use the previously mentioned method. No, there is no procedure for a continuity test.
2007 Saturn Ion 2
Old 02-24-2009, 01:51 PM   #5
chuzz
Okay, thank you. That's what I needed to know. I do appreciate it. I guess it's just one of those things that's either good or faulty. Hopefully the new one will last her longer. They gave her a 12 month or 12,000 mile warranty. Which ever occurs first. I'm betting on the 12 months.
Old 02-24-2009, 04:42 PM   #6
2006 ion2
2007 ION-2 Sedan
in the mean time you can degrease and regrease the old one and keep it for a standby, they seem to stay good once degreased.
2007 Saturn Ion 2
Old 02-24-2009, 05:08 PM   #7
chuzz
Is it possible that the grease they're using in them just gets hard and won't let it make contact while it's cold? In this day and age, that wouldn't be that much of a surprise, would it?
Old 02-24-2009, 05:11 PM   #8
2006 ion2
2007 ION-2 Sedan
that's exactly the problem
2007 Saturn Ion 2
Old 02-25-2009, 10:59 AM   #9
chuzz
Very easy to take apart. I did that and sure enough, the grease was kind of hard. I cleaned it out, put some new di-electric grease in it and will keep it as a back up for her. If it happens again next winter, I'll be ready. LOL Now, if only someone would explain to me how to re-set the security system that they told her had to be done via the computer, I'd really be ready.
Old 02-25-2009, 11:57 AM   #10
2006 ion2
2007 ION-2 Sedan
do a search through the tech section, it's been posted many times.
2007 Saturn Ion 2
Old 02-25-2009, 02:27 PM   #11
chuzz
Thanks, I'll see what I can find.
2000 LS2 Brake Switch - hard switch to find finder216 L-Series Tech 2 08-21-2008 09:48 PM
Will a '95 column switch fit a gen-2 car? madpogue S-Series Tech 2 11-28-2006 05:35 PM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 08:55 AM
Ignition switch assembly loose on steering column tmaugham General Saturn Discussion 1 03-30-2006 12:27 AM
Available: 97-02 almost new steering column switch ArghIGiveUp Classifieds 0 04-20-2005 05:56 PM
