Old 10-15-2008, 12:41 PM   #1
Dave_Pletcher
Dave_Pletcher is on a distinguished road
2006 ION-2 Quad Coupe
Default Changing the APP sensor (2006 Ion)
Has anyone performed this operation?
I plan on doing this in the coming days and it appears pretty straight forward.
Any guidance will be appreciated (neither the dealer or secondary mechanic will be acceptable suggestions).
"I will sell you my Saturn for a nice pair of sneakers..."
Add to Dave_Pletcher's Reputation
Rate the quality of this post and help Dave_Pletcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dave_Pletcher is offline   Reply With Quote
Old 10-15-2008, 04:17 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Changing the APP sensor (2006 Ion)
You can just replace the sensor, as a matter of fact that's all I can find info on.
remove the left lower closeout panel
remove the left lower heater duct
using a flashlight, locate the app on the top of the pedal arm
it's on a bracket, remove the electrical connector
follow the pedal arm all the way to the top where it connects to the APP sensor linkage by a link rod and heim joint, remove the retainer and disconnect the link rod from the APP linkage arm.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
2006 Ion Knock Sensor Replacement JrmyCrss Ion Tech 3 02-24-2009 10:34 PM
APP Sensor, Reduced Power, what else to try? guitar_stitch Vue General 3 07-24-2008 12:55 PM
Changing the Engine Temperature Coolant Sensor saturnpuppy Vue Tech 4 04-26-2008 10:15 PM
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 12:58 PM
Buying an ION - Nervous about GM app. Shadowyng General Saturn Discussion 43 05-16-2004 04:13 PM
