#1 | ||||
![]() Join Date: Mar 2011
my truck is currenly down and me and my wifes only other vehicle is a 2005 saturn vue 2.2lt 5sp, well the vue is starting to act up it idles fine but as soon as u start to get the rpms up the motor starts to cut out like its not getting fuel. the rpms dont jump so spark plugs are fine. its bogging out evry time u drive it. the check engine light came on so we had it read and no codes found,so i figured it was bad gas or fuel filter got a filter and went to find it no where to be found i was just wondering if any one had this problem before thanks
#2 | |||||
Fuel filter... inside the tank... If you turn on the A/C, does it act any different at idle? Check the picture in post #9 of the thread below to make sure of which light is on... http://www.saturnfans.com/forums/sho....php?t=180894# ... Avid Apple, car and vacuum enthusiast. Don't hate! ;) Current: '04 FWD 3.5L Previous: '05 AWD Red Line '02 L200 http://www.facebook.com/SaturnFansNorthEast
#3 | |||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
Its OK to drive like this for awhile as the ECM will revert to default fuel program. If the stumble remains the next step is check fuel pressure. If stumble goes away - replace the O2 sensor. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#4 | ||||
ok so i checked out the link and the light that comes on is the service engine soon, the vue has just over 100,000 miles.
#5 | ||||
so i unplugged the o2 sensor and gave it a shot no real difference and in repley to the ac i tured the motor on it idled fine but as soon as i turned the ac on the rpms acted up and the motor shook badly
#6 | |||||
You could pull at least one plug to check condition. See attachment for a list of possible suspects. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#7 | ||||
![]() Join Date: Jul 2011
I'd be leaning towards ICM and/or coil pack. Should be a CEL stored, just gotta find a reader that can read it!
... 2005 Dragonfly Green 2.2L MTX Vue
| Thread Tools | |
| Display Modes | |
| Fuel delivery issue | dwarffortress | S-Series Tech | 17 | 04-07-2012 03:45 AM |
| fuel pump issue | christopher55 | L-Series Tech | 7 | 02-17-2011 09:51 AM |
| 98 sl2 fuel issue? | 76oldsguy | S-Series Tech | 26 | 01-03-2011 02:47 PM |
| Is This a Known Issue With The Fuel Level? | zallen777 | L-Series General | 16 | 05-05-2005 11:54 AM |
| Fuel Pump Issue | SoUp | S-Series Tech | 4 | 12-31-2004 11:17 AM |
