Old 09-16-2018, 01:26 PM   #1
Milly
Milly is on a distinguished road
Default Timing chain on 2009 Astra XE
Hey Saturn lovers!
I am thinking of buying a 2009 Saturn Astra XE and I read that the model does not have a timing belt but a timing chain. Is it true that the chain (if the oil is changed regularly) does not need to be changed?
What is your experience with the timing chain? Did you have to change it or not? Approximate cost of changing it?
Thank you
Add to Milly's Reputation
Rate the quality of this post and help Milly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Milly is offline   Reply With Quote
Old 09-16-2018, 02:50 PM   #2
AstraFasta
AstraFasta will become famous soon enoughAstraFasta will become famous soon enough
Default Re: Timing chain on 2009 Astra XE
Search the threads here m8. Fake news!
Timing belt needs to be changed from time to time. If you have no written proof that it was changed, then 10 years is more than long enough to require immediate change as the rubber degrades with use and with time. While at it a few of the pulleys should be changed at the same time.
You can leave it but failure will likely destroy the engine and leave you on the road with a sudden loss of power.
I did it DIY for less than $100 but used a lot of my friend's tools. There are plenty of guides here to help you.
Shop might charge you a bit more. In my area probably closer to $1000.
Old 09-17-2018, 06:22 PM   #3
Milly
Thank you AstraFasta!
Are you sure that you are talking about the timing chain? Two people have now told me that this model has a chain instead of a timing belt ...
I appreciate your replies
Old 09-18-2018, 10:49 AM   #4
JFS
JFS has a spectacular aura aboutJFS has a spectacular aura aboutJFS has a spectacular aura about
JFS's Avatar
2008 Astra XR
PLEASE take 5 minutes and follow the suggestion to search "timing belt."
Anyone telling you these cars have a timing chain vs. belt is delusional and has no experience with this model car, none whatsoever.
Chrissakes, the man just told you he changed his TIMING BELT.
The above exasperation is done only to protect you from not knowing what you are buying.
Add to JFS's Reputation
Rate the quality of this post and help JFS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JFS is offline   Reply With Quote
Old 09-18-2018, 04:52 PM   #5
AstraFasta
Originally Posted by Milly View Post
Are you sure...?
I am sure
4-cylinder eco tech on 2009 Vue; timing belt or timing chain? canoecraft Vue Tech 2 05-17-2018 10:48 PM
timing chain do pull chain after I turn crank 3 oclock Packard S-Series Tech 2 08-15-2016 09:51 AM
timing chain sounds like it could be coming into contact with timing cover prioris Sky Tech 0 12-07-2012 10:31 PM
Timing Chain? Chain loose, engine cranks, no start DJboozeAlot S-Series Tech 18 10-21-2012 02:23 PM
New Astra making me sick (2009 Astra XE Automatic) burp Astra Tech 21 01-29-2010 02:44 AM
