Old 09-06-2006, 09:07 PM   #1
Jinjo
Jinjo is on a distinguished road
Jinjo's Avatar
2001 SL2
Default quick quick quick question about flywheel.
hi, I know I have another post but I just want this to be a simple answer.
When you follow the clutch replacement how-to, and you have the transmission out and sitting where they tell you, is there enough room to remove the flywheel to get it machined? Like, is there enough room to be able to undo the flywheel bolts, take it out and put it back in with the bolts?
Thank you very much.
Add to Jinjo's Reputation
Rate the quality of this post and help Jinjo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jinjo is offline   Reply With Quote
Old 09-06-2006, 09:11 PM   #2
wolfman
wolfman's Avatar
Default Re: quick quick quick question about flywheel.
The third quick sukered me in...
YES, BUT, the bolts (flywheel to crankshaft) are on VERY TIGHT and must be torqued back on accordingly (89ft lbs IIRC) when putting it back on.
Add to wolfman's Reputation
Old 09-06-2006, 09:13 PM   #3
Jinjo
Jinjo's Avatar
2001 SL2
Thank you very very VERY much wolfman
Old 09-07-2006, 09:31 AM   #4
eljefino
eljefino's Avatar
1995 SW1
^ and loctited too. Ask low_saturn.
Add to eljefino's Reputation
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 10:27 PM
Ecu...quick Quick!!! Elementkng20 S-Series Tech 3 01-06-2008 02:17 PM
Quick tranny fluid change or quick screwing? ken b. S-Series General 4 05-12-2006 08:30 PM
quick question for those that know... Trashcan Vue General 5 10-15-2004 09:22 PM
Quick Question and not so quick one... John Marshall Miscellaneous Tech 5 02-19-2004 10:22 AM
