Old 04-18-2010, 11:23 AM   #121
gizmokat
gizmokat is on a distinguished road
Dizzy Re: S-Series Swap Guide
another idea . can i take a 2002 sohc engine and put my dohc top end stuff on it. lots of sohcs around here dohc are hard to find in good cond and cheeep lol
Add to gizmokat's Reputation
Rate the quality of this post and help gizmokat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gizmokat is offline   Reply With Quote
Old 04-25-2010, 01:39 PM   #122
lonewolfncubs
lonewolfncubs is on a distinguished road
lonewolfncubs's Avatar
1997 SL1
Default Re: S-Series Swap Guide
thanks!
Add to lonewolfncubs's Reputation
Rate the quality of this post and help lonewolfncubs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lonewolfncubs is offline   Reply With Quote
Old 04-29-2010, 10:08 PM   #123
Mgg4591
Mgg4591 is on a distinguished road
Mgg4591's Avatar
so a 92' exhaust manifold will not work on my 99' SL2?
2002 Mitsubishi Galant 2.4, 94,500 miles
2007 Toyota Camry 2.4, 29,600 miles
1999 Saturn SL2 1.9, 93,700 miles
Add to Mgg4591's Reputation
Rate the quality of this post and help Mgg4591 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mgg4591 is offline   Reply With Quote
Old 04-30-2010, 01:47 AM   #124
rc1488
rc1488's Avatar
Ok lets see if I can do this all at once:
Nope. Different Bolt pattern. OBX makes a header for '99+ cars.
Originally Posted by gizmokat View Post
ok nice forum lot of good info . i have a 2002 sl2 need to change engine or block [cracked cylinder] i guess i can swap a 99- engine with not tooo much problems ???/ am i right in assuming 93 and up blocks are all the same??? sohc and dohc same blocks??? thanks and good job you guys are doing .:
'93-'00 blocks are the same. The 3rd gen block only has a difference in the oil pressure sender I believe. You need a '99B+ DOHC engine or any '99 DOHC engine with a '99b+ DOHC exhaust manifold.
Yes. The compression ratio will decrease using SOHC pistons however.
Originally Posted by Project84 View Post
Rear bumper covers interchange for all 2nd gen sedans? What about from a '96 to an '01-02 SLx? My '96 SL2 needs one.
Yes. They are all the same. Pretty sure the '01 covers will fit the 2nd gen also
What about starters? Again, for my '96 auto.
starters are all the same.
Originally Posted by airon1974 View Post
Ok I have a question. I'm swapping a blown 99 block for a pristine 96 with about 60-70k on it. I noticed that the 99 pistons had a valve relief on one side, and the 96 pistons are dished. obviously this is going to change the compression ratio, but what I'm really worried about is valve interference. Has anyone ever run into this? If all else fails, I'll have to preassemble the head and check the valve clearance with clay. Thanks in advance, Aaron.
Your putting SOHC pistons with your DOHC head. It will not interfere (guys do this for turbo builds) but you do lose power.
Add to rc1488's Reputation
Old 04-30-2010, 07:35 AM   #125
spencerforhire
spencerforhire will become famous soon enough
spencerforhire's Avatar
2001 SC1
I have read(and re-read) this swap guide but I still don't know for sure exactly what year motors will work with what year ECM's in what year cars. I have even started threads asking specific questions which usually get answered with "you're always safe with the same year". I now have no less than 6 96-98 Saturns and it's time to do a round of motor and trans swaps. I need to put a motor out of a 96 SL2 into into a 96 SC1- that one's easy; both cars are 5-speed, so I just swap in the motor, trans, cluster and computer. But I also have to change the motor in the 97 SW2(after 390,000kms it's no shame). I have a perfect motor in the smashed 98 SL2, and I just acquired another very rusty 96 SL2 with under 200,000km as well. All 3 cars are 5-speed; so what I'm asking is which is the best fit(96 or 98) and do I even have to mess with swapping computers and/or fuel rails/injectors? The other question I have concerns the 96 SW2; the automatic trans is acting oddly, and I need to know what other years will swap in without upsetting the computer, or if I can get the computer that goes with the trans which years will work in the 96.
01 SW2-#1 son's
01 SC2-#2 son's
00 SW2-wife's
00 SL2-daughter's
99 SW2-mine
00 SL1-spare
98 SC1-parts
+ 25 scrapped
Visit www.spencerforhire.ca to see what I do other than fix Saturns
Add to spencerforhire's Reputation
Rate the quality of this post and help spencerforhire reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerforhire is offline   Reply With Quote
Old 04-30-2010, 09:38 AM   #126
rc1488
rc1488's Avatar
Nope. You usually need to change computers when changing tranny, or engine type. Either the '96 or the '98 will work. Its personal choice really.
'93-'97 DOHC MP7 tranny will work. However 9/10 times its not the tranny but the Valve body or sensors (specifically the ECTS) that cause tranny issues.
Old 05-13-2010, 12:49 AM   #127
viper32435
viper32435 is on a distinguished road
so i shoulnt have any problems as long as i get the dohc head from 2000-2002 to swap out for my sohc? and computer of course
Add to viper32435's Reputation
Rate the quality of this post and help viper32435 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
viper32435 is offline   Reply With Quote
Old 05-13-2010, 01:30 AM   #128
viper32435
ok with doing the sohc swap for the dohc head would it b safe to run a full built dohc and hope the t66 turbo dont kill me ? lol i mean would it b safe to run such a powerhouse on the dohc compared to the t3 or the t4
Old 05-13-2010, 07:52 PM   #129
rc1488
rc1488's Avatar
Start your own thread please. I have no idea what your talking about.
Old 06-02-2010, 11:07 AM   #130
rc1488
rc1488's Avatar
AC Compressors? Their were 4 designs, and they don't interchange. Years of compatibility?
Old 06-03-2010, 06:55 PM   #131
litlrdhdgirl
litlrdhdgirl is on a distinguished road
Can someone tell me if I can put a 95 SL2 starter in a 99 SL2?
Add to litlrdhdgirl's Reputation
Rate the quality of this post and help litlrdhdgirl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
litlrdhdgirl is offline   Reply With Quote
Old 06-03-2010, 09:35 PM   #132
rc1488
rc1488's Avatar
Yes you can.
Old 06-06-2010, 12:38 AM   #133
shavelieva
shavelieva is on a distinguished road
So knowledgeable rc1488,
I'm working on a 99 sl2 with a useless DOHC(seized). I see SOHC's all day long, what would I be getting myself into if I choose to replace the DOHC for a SOHC? Can I keep most of the parts located on the DOHC and place them on a bare SOHC(water pump, alternator, power sterring pump, starter,etc)? Will I need to modify any parts of the harness? Or would such a move be a waste of my time and I should stick with replacing it with another DOHC? What years am I limited to in swapping?
Add to shavelieva's Reputation
Rate the quality of this post and help shavelieva reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shavelieva is offline   Reply With Quote
Old 06-06-2010, 09:25 PM   #134
airon1974
airon1974 will become famous soon enoughairon1974 will become famous soon enough
This is what I'm in the process of doing right now. Basically all I used was the block, crank, and connecting rods from the SOHC. I put new pistons rings and bearings in and all new gaskets. Not exactly a direct swap but all the accesories swap over.
Add to airon1974's Reputation
Rate the quality of this post and help airon1974 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
airon1974 is offline   Reply With Quote
Old 06-08-2010, 08:48 PM   #135
rc1488
rc1488's Avatar
You can just use the SOHC block and use the DOHC Head...then having a new DOHC engine with slightly lower compression.
Your compatibility years is limited by your current Engine and PCM Type. If you have a '99a engine, then '95 - '99b will work. If you have a 99B engine, then only a '99b engine will be a direct plug and play replacement. A '00-02 will work, but modifications will be needed as the Intake Manifold changed '00.
'99a engines have No AIR provision located above the A/C compressor. '99b engines do. This is an emissions device, so if your state has emissions testing then you must choose the correct engine type to ensure the SES light stays off.
Going from DOHC to SOHC is an option only if you have a standard tranny...but something that is rather rare to do. You'll need to find a SOHC PCM that matches your cars options (since the DOHC body usually comes with more options then the SOHC you may loose some features) and also matches your tranny type. I think its best to put a DOHC engine in it.
Old 06-08-2010, 08:59 PM   #136
rc1488
rc1488's Avatar
Air Conditioners
'95 - Model DKV - 11A
'97 - Model DCV - 11A
'98 - '99b - Model DCV - 11G
'01- '02 - Model DCV - 11J
Identification
You can figure out the model of the compressor by looking at the pulley and the connector position/location.
Known Compatibility
'01 with 11G - Leaks slightly, but an annual DIY charge is all that is needed
I cannot comment on any other years since I do not have those cars.
Old 06-18-2010, 02:57 AM   #137
shavelieva
My state does not have emissions testing(KY). I'm trying to stay budgeted around $300 for this and have seen numerous SOHC from early 90's -01.'
So say I buy an 01 SOHC? I will remove the heads from the seized DOHC, and place it on the block of the SOHC? or am I swapping the good block off of the SOHC to the seized DOHC? this part I'm kinda perplexed at, I can do it, I'm just not understanding what order I would be swapping the parts of the engine in.
The PCM, does it matter as long as its for an 01' 1.9L Saturn?
btw I have a automatic transmission if that is what you meant by "standard"
thanks for all the help btw.
Old 06-18-2010, 12:26 PM   #138
rc1488
rc1488's Avatar
Put the '99 head on the '01 block. Compression will decrease with the SOHC pistons. Then put the now good engine into the '99. Use your current PCM. Use your current Flexplate from the '99 engine. Use your '99 harness and sensors.
A '93-'02 block (sohc or dohc) will work for you. You will need to look into the knock sensor location as the 3rd gen block has a different style. IIRC it can accept the older style (your '99).
Standard transmission = 5 speed manual shifting transmission
Old 06-19-2010, 04:42 PM   #139
BLUERAM
BLUERAM will become famous soon enough
1993 SC2
I have a 93' SC2 and need a new ignition control module, Does anyone know what years will work? I have searched this forum but have not found this info, sorry if I missed it and thank you for such a good resource.
Add to BLUERAM's Reputation
Rate the quality of this post and help BLUERAM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BLUERAM is offline   Reply With Quote
Old 06-19-2010, 08:43 PM   #140
rc1488
rc1488's Avatar
Originally Posted by blueram View Post
i have a 93' sc2 and need a new ignition control module, does anyone know what years will work? I have searched this forum but have not found this info, sorry if i missed it and thank you for such a good resource.
'92-'95
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
i know theres the engine swap guide, but... KawaiiBoricua S-Series Tech 7 03-18-2008 08:00 PM
i read the swap guide lowwSC2 S-Series Tech 17 01-07-2008 11:57 PM
Swap guide richamer1 S-Series Tech 8 12-05-2007 11:01 PM
what happened to the swap guide 94503 S-Series General 1 05-14-2007 07:43 PM
