Old 02-09-2010, 12:20 PM   #101
Default Re: S-Series Swap Guide
Engine cradle swaps, from this thread.
Per Low Saturn (paraphrased):
1994 and up engine cradles all swap interchangeably.
Sedan, wagon, coupe, SOHC, DOHC, auto, and manual cradles are all the same.
For 1991-1993.
1991, the mount provisions are different than other years.
1992/1993 puts the radiator in a different position.
You could use a 92/93 cradle in a later year car if you buy a 91-93 radiator.
Old 02-10-2010, 12:50 PM   #102
praveen
praveen is on a distinguished road
I am in the middle of changing out an engine in my 99' SC2. I am trying to get the replacement engine prepared to put into the car. I'd like to get the engine in today but am having a tough time getting a hold of a Haynes manual (Library and stores closed due to snow storms in our area) and therefore don't know the bolt tightening torque specs on some of the parts. I am wondering if anyone would happen to know this information and can help me with it? Here is a list of what I need the torque specs on:
-Flywheel bolts
-Clutch Pressure Plate bolts
-Transmission bell housing to Engine bolts (2 upper and 2 lower)
-Bracket (located on bottom) from engine to transmission. 4 bolts into engine and 2 into the trans.
-Transmission mounts (2 upper and 1 lower)
-Engine mounts (5 upper and 1 lower)
Thanks for any help you can give me.
92 SL1: 275,000 miles - May it RIP.
98 SC2: 105,000 miles
99 SC2: 153,000 miles
Gotta love them!
Add to praveen's Reputation
Rate the quality of this post and help praveen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
praveen is offline   Reply With Quote
Old 02-10-2010, 04:37 PM   #103
rc1488
rc1488's Avatar
-Flywheel bolts Criss cross
-Clutch Pressure Plate bolts Criss cross in steps. See Richpin Video
-Transmission bell housing to Engine bolts (2 upper and 2 lower) No order
-Bracket (located on bottom) from engine to transmission. 4 bolts into engine and 2 into the trans. No order, but I criss cross
-Transmission mounts (2 upper and 1 lower) No order
-Engine mounts (5 upper and 1 lower) Do the engine bracket first to the fram, then the engine mount to the engine
Torque Specs:
http://saturnwiki.net/index.php/Torque_Specs
Add to rc1488's Reputation
Old 03-25-2010, 06:45 PM   #104
chevyjoe
chevyjoe is on a distinguished road
chevyjoe's Avatar
1994 SC2
Steering wheels?
Mine's a 2001 SL2 and I need to know if any other models besides the S-series will fit and function on an S series with cruise?
01 SC2 so far, NGK plugs, epoxied resonator leak, welded door guide d/s, patched exhaust under engine, will weld soon... lazy for now.
01 SL2 sold
94 SC2 RIP in the boneyard
Add to chevyjoe's Reputation
Rate the quality of this post and help chevyjoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chevyjoe is offline   Reply With Quote
Old 03-25-2010, 09:01 PM   #105
rc1488
rc1488's Avatar
Originally Posted by chevyjoe View Post
Steering wheels?
Only 3rd generation steering wheel will work when you have cruise. The cruise was relocated from a switch near the windshield wiper switch on the 1st and 2nd gens to thumb buttons on the wheel. On the 1st and 1nd gen wheel the thumb buttons were the horn
Old 04-02-2010, 02:24 AM   #106
weiss27md
weiss27md is on a distinguished road
2002 SL1
What about stock springs between different year models and configurations?
Add to weiss27md's Reputation
Rate the quality of this post and help weiss27md reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
weiss27md is offline   Reply With Quote
Old 04-02-2010, 09:25 AM   #107
rc1488
rc1488's Avatar
All S-series springs are the same and transfer through out the production years.
Front springs are no the same as rear springs though. Different diameters
Old 04-02-2010, 03:23 PM   #108
weiss27md
2002 SL1
Thanks. I found some but there are 2 different options for the front and 2 different options for the rear.
FRONT
Springs, Front Coil, Cargo Control, Saturn, SC, SL, SW-Series, FWD, Pair
Part Number: MOG-CC664
Springs, Front Coil, Cargo Control, Saturn, SC, SL, SW-Series, Pair
Part Number: MOG-CC662
REAR
Springs, Rear Coil, Cargo Control, Saturn, SL/SW-Series, FWD, Pair
Part Number: MOG-CC677
Springs, Rear Coil, Cargo Control, Saturn, SC, SL, SW-Series, FWD, Pair
Part Number: MOG-CC673
Old 04-02-2010, 03:52 PM   #109
rc1488
rc1488's Avatar
FRONT
REAR
There most likely the same. Sometimes anything for the coupe is classified as a different number. Link to the site you found this?
Old 04-02-2010, 04:13 PM   #110
weiss27md
2002 SL1
I PMd you the link because I can't post links yet.
Old 04-02-2010, 07:50 PM   #111
Uzzy
Uzzy's Avatar
2002 SC1
Do you need Springs? I've got a set of Factory Springs from a 2002 SC1 in my basement that had 40 or 50 thousand miles on them.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 04-03-2010, 02:30 AM   #112
weiss27md
2002 SL1
I do need some that will fit an 02 SL1.
Old 04-03-2010, 02:41 AM   #113
Uzzy
Uzzy's Avatar
2002 SC1
I see you're in Texas. I'll see what shipping will cost and get back to you.
Old 04-04-2010, 09:36 AM   #114
BlackSatGuy
BlackSatGuy is on a distinguished road
Anyone know if the power window console switch changed over the years. I have a 99 SL2 and I found an earlier version at the junkyard that looks good.
Add to BlackSatGuy's Reputation
Rate the quality of this post and help BlackSatGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlackSatGuy is offline   Reply With Quote
Old 04-04-2010, 09:40 AM   #115
BlackSatGuy
And- are all of the gen2 headlights interchangeable? Thanks.
Old 04-04-2010, 12:10 PM   #116
rc1488
rc1488's Avatar
Yes
'99 is a 2nd generation interior. '95-'99 S-series with power windows will work.
Old 04-11-2010, 01:19 PM   #117
airon1974
airon1974 will become famous soon enoughairon1974 will become famous soon enough
Dizzy Re: S-Series Swap Guide
Ok I have a question. I'm swapping a blown 99 block for a pristine 96 with about 60-70k on it. I noticed that the 99 pistons had a valve relief on one side, and the 96 pistons are dished. obviously this is going to change the compression ratio, but what I'm really worried about is valve interference. Has anyone ever run into this? If all else fails, I'll have to preassemble the head and check the valve clearance with clay. Thanks in advance, Aaron.
Add to airon1974's Reputation
Rate the quality of this post and help airon1974 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
airon1974 is offline   Reply With Quote
Old 04-14-2010, 04:43 PM   #118
cam covers (which some people are referring to as valve covers) exchange in this thread
Old 04-16-2010, 09:28 AM   #119
Project84
Project84 will become famous soon enough
Project84's Avatar
2009 AURA XR
Rear bumper covers interchange for all 2nd gen sedans? What about from a '96 to an '01-02 SLx? My '96 SL2 needs one.
What about starters? Again, for my '96 auto.
I'm headed to the junkyard tomorrow and it would be nice to get these things.
John
'09 Saturn Aura XR 2.4L
Previous - '01 SL1 daily driver and '96 SL2 auto 40+mpg hypermiler.
Add to Project84's Reputation
Rate the quality of this post and help Project84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Project84 is offline   Reply With Quote
Old 04-18-2010, 11:02 AM   #120
gizmokat
gizmokat is on a distinguished road
Wrench Re: S-Series Swap Guide
ok nice forum lot of good info . i have a 2002 sl2 need to change engine or block [cracked cylinder] i guess i can swap a 99- engine with not tooo much problems ???/ am i right in assuming 93 and up blocks are all the same??? sohc and dohc same blocks??? thanks and good job you guys are doing .:
Add to gizmokat's Reputation
Rate the quality of this post and help gizmokat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gizmokat is offline   Reply With Quote
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
i know theres the engine swap guide, but... KawaiiBoricua S-Series Tech 7 03-18-2008 08:00 PM
i read the swap guide lowwSC2 S-Series Tech 17 01-07-2008 11:57 PM
Swap guide richamer1 S-Series Tech 8 12-05-2007 11:01 PM
what happened to the swap guide 94503 S-Series General 1 05-14-2007 07:43 PM
