Old 03-04-2019, 09:38 PM   #1
SuperCookie
SuperCookie is on a distinguished road
Default Do think my crazy plan could work?
I have a list of all of the ideas i come up with for cars and car companies (yes i dream big) and one of my ideas is a lw300 sleeper. My idea was to convert it to AWD with a chevy 4.3L v6, a small turbo (max SAE gross 350hp and lbf) and a modern automatic transmission. Do you think given enough money this could be done and still be driven comfortably. the L series wasn't designed to have a driveshaft and a center diff, so the interior in my mind might not be able to be conformable with modification to the floor plan that could fit these things. Do you thing i could pull it off given enough money?
2001 Yellow Special edition SC2 (not the bumble bee)
SuperCookie is offline   Reply With Quote
Old 03-04-2019, 09:50 PM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: Do think my crazy plan could work?
Just skin the car and use the blazer frame and floor boards.
2002 L200/5 loaded, coming attractions LSJ and an F40 if I can make the axles work. Otherwise an LSJ and a 4.05 ratio F35.
02 LW300 is online now   Reply With Quote
Old 03-04-2019, 11:00 PM   #3
SuperCookie
i could do that but that would mean 4wd. and you can't drive that on the road
Old 03-05-2019, 12:20 AM   #4
02 LW300
02 LW300's Avatar
When you said AWD that is what I thought you meant. Stick it on an s10 frame and go play drift car then. Just use the shell and it would be stiff and light and fun.
Old 03-09-2019, 05:18 PM   #5
SuperCookie
The olds bravada used an AWD system and a 4.3l v6 with the balance shafts. i think swapong in the power train be the best way to do it
Old 03-10-2019, 01:41 PM   #6
Anything can be done....... with money. Any thought exercise is easy. Translating ideas into reality takes some serious thoughts on yanking existing drive train components then shoe horning in your drive train of choice with an experienced person(s) able to make things fit. Adding to the complexity of attempting to replace front wheel drive for all wheel drive, you're creating additional problems attempting to add turbo charging. Anyone without a clue about super or turbo charging simply blows up their pet project without any serious research on the subtle differences between conventional EFI systems and EFI systems with boost. Adding a super or turbo charger is just not that simple. The secrets are not secrets and well known, just not brought out in plain layman's terms for everyone to understand.
Old 03-12-2019, 02:40 PM   #7
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
2002 L-Series 3.0L Sedan
Just go buy a BMW M5M instead. What your trying to do isn't worth the cost/labor even if it's a pet project. That dream is long gone. The age of the Saturn is more beneficial for a everyday driver not a StreetRacer. The plan isn't crazy it's just plain lack of common sense here.
Old 03-12-2019, 08:00 PM   #8
pierrot
pierrot's Avatar
As noted by fdryer, "Anything can be done....... with money." Based on your OP you're already are aware of the problems presented by attempting such a conversion relating to the powertrain, chassis, and floor pan (let alone major wiring changes and possible smog law concerns [depending upon which state you reside in]). With all of that in mind this is a pipe dream, a fun pipe dream, but a pipe dream nevertheless. Please don't stop "dreaming big," but consider a better dream.
You're certainly correct in recognizing the "sleeper" aspect of the L-Series cars with the V-6s. Some members here who own those cars have appreciated that and written some posts about surprising BMW owners who think they're going to leave this "unknown" car in the dust only to be left there themselves.
337,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Plan to buy '06 V6: FWD or AWD? Speedy Vue General 20 02-15-2006 02:38 PM
there goes that plan the_skin_eater S-Series General 8 09-01-2005 10:04 AM
My Plan... GreyDuck Mods and Performance 10 04-19-2003 07:22 PM
Here is what i plan on doing: GreyDuck Mods and Performance 10 04-08-2003 02:32 AM
What is GM's Plan? OPEC General Saturn Discussion 1 01-18-2001 08:33 AM
