Old 06-20-2019, 10:28 AM   #1
onlinebiker
Default Replace or no?
When you put a DOHC timing cover on - do you replace the oil pump seals every time?
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 06-20-2019, 11:19 AM   #2
onlinebiker
Default Re: Replace or no?
Aka timing cover seals..
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 06-20-2019, 11:28 AM   #3
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
1996 SC2
I've not bothered. Unless of course you're having issues.
-Robert
Old 06-20-2019, 12:31 PM   #4
I can confirm that not having seals is bad.
Old 06-20-2019, 12:53 PM   #5
Are you talking about the O-rings for the oil passages, the front crank seal, timing cover to pan, VC gasket, what?
I would leave the pan gasket there and evaluate the valve-cover gasket, but replace all else. Those are pretty cheap, and it is sure a hassle to get the cover off and replace them later if a leak does soon develop.
At minimum, replace the pump O-rings, those are very cheap and very vital; and you might not even be aware that one is leaking before there is engine damage, as the leak would be internal to the engine.
Old 06-22-2019, 09:16 PM   #6
TomM96
+1 Old Might work, but seals compress with duration >risky<
Some places sell just the oil pump seal orings alone.... or used to.
Old 06-22-2019, 10:32 PM   #7
Yes, because they age and can fail. When they fail, either one, the engine is now also scrap aluminum.
Rock Auto called a Timing Cover Seal kit and includes the crank seal but I only use a FelPro or Victor on that crank.
There is no oil pan gasket. Always use a new cam cover gasket.
need to replace front coil springs/replace struts too? dapper S-Series Tech 24 05-13-2015 02:42 PM
To replace engine, or not to replace engine? That is the question. MT128 S-Series Tech 4 04-30-2013 05:00 PM
Tire replacement- replace one, replace them all? MRink Vue General 4 07-20-2010 09:56 AM
02 SL1 SHOC with oil in coolant: replace head vs replace engine - need advice surreyman S-Series Tech 3 05-02-2010 01:24 PM
EGR Valve: To Replace or Not to Replace? SL1Joe S-Series Tech 36 03-31-2008 09:56 PM
