Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay Tech
Old 04-28-2018, 12:28 PM   #1
jeff.harlan
jeff.harlan is on a distinguished road
Default Relay van warning dinger sounds all the time.
2005 Relay. The seatbelt or 'key in ignition' warning dinger sounds whenever vehicle is in reverse or drive. No dinger when shifter is in park. No warning lights on the dash. Any ideas????? This is driving me nuts!!!
Add to jeff.harlan's Reputation
Rate the quality of this post and help jeff.harlan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeff.harlan is offline   Reply With Quote
Old 04-29-2018, 02:20 PM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: Relay van warning dinger sounds all the time.
Wow thatís a good one. Iím assuming not backup sensor. Some had that some didnít. Does it also do it in neutral? Seatbelt light not on? Does seatbelt light work?
Add to onefunkar's Reputation
Old 05-04-2018, 12:09 PM   #3
2NDSOUT
2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice
2NDSOUT's Avatar
1994 SL2
1999 SL
What is the condition of the Battery in your Van?
If it is older then 5 years old, it may start to do strange stuff from an electric standpoint.
We have a 2007 Chevy Uplander, which is a clone of the Relay/Terraza/Montana. We had to replace the battery after getting the trans rebuilt.
The battery is not difficult to replace- but is a bit cumbersome if you have to replace- as there is a large sway bar that is over the battery, held in with 13MM bolts, as well as a bolt down that is on the back side of the battery that is also a 13MM bolt. You also have to undo the 10MM bolts that hold the Fuse box in place, in order to get to the Battery.
Hope this helps.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Is There A Hazard Warning Relay Fuse? Midlander Ion Tech 1 08-27-2014 05:02 PM
Turn signals silent when flashing, "dinger" not working when doors open, etc. rcote20 Ion General 3 06-12-2013 10:27 PM
Warning lamp relay - 1993 sc2 Disophisis S-Series General 2 06-06-2010 10:56 PM
Door Dinger DrPimper S-Series Tech 4 03-07-2009 09:03 AM
Quick warning for Saturn techs (RE: 2005 Relay) WopOnTour Relay Tech 14 12-08-2004 09:21 PM
